Washer will not do final spin
SOURCE: Maytag MAH20PD washer does not do the High Spin Cycle
with what you have described the problem should be in the door lock unit. there is a check switch that gets pressed down and sends a signal to the computer board telling it that it is locked. if the switch isn't working then that signal will not be sent and the washer will just turn and never enter spin. replace the switch and this will clear up the problem
SOURCE: Whirlpool 8255e makes ''whirry'' sound when pumping - not spinning
there is probobly something small jammed into the pump
common for that sound would be a underwire for a bra.
is it still draining ok?
SOURCE: Whirlpool® Commercial Washer Model
There is a rubber bushing like thing with a plastic piece with three fingers that go into the rubber bushing, between the motor and transmission. Lay the machine on its back and you can see how the motor has screws holding it in place. undo the and move the motor apart just enough to remove the old parts and install the new ones. Its not hard to do. You can find the parts from a appliance store that dose repairs, when you see them you will know what to look for when you go to take it apart. I hope this helps you.
Ed
