Question about Microsoft Windows XP Professional
Not able to open Word documents
For the last two days I have not been able to open any of my Word documents. I get the same message, A yellow warning triangle with an exclamation point and the words, "The file_______ is not available."
How do I fix this?
    Sergeant:
  • 302 Answers
Somehow, it is corrupted and you will need to reinstall microsoft word. This has happened to me so you will need to uninstall and reinstall it. Hopefully you made backup copys of your word documents. I always send me a copy of my word documents to my email so in case anything like this happens, I have a copy of it stored.
Posted on Dec 07, 2008
I have a 2005 porsche cayanne that when you start it up has a yellow light comes on looks like a i or!
As stated in your handbook under "warning symbols" this is a general warning light which is basically informing you of a message that needs to be addressed by accessing your menu messages. It's located on the end of the arm with the rocker switch and another switch right below it. Navigate through the menu to find "warning messages". Here you'll find what needs to be addressed. Hope this helps.
Feb 14, 2015 | 2005 Porsche Cayenne
Is not opening
Yellow Hibiscus, Mothers Day gift. My son brought it home last night.
2 blooms lots of buds. Blooms closed last night, today still not open. Transfered to larger pot. Added water and a little extra soil.
Nov 26, 2013 | Spooky House Studios UG Bubble Explode
Looking for word document I did not save
Open Microsoft Word if it's not already open.
This may automatically open a list of your recent unsaved files, which with any luck includes the one you're looking for.
If this happens, simply open this document from the list.
Click the blue "File" tab in Word, and then click "Info" on the left side of the screen.
Click the "Manage Versions" icon to bring up a list of options.
Click "Recover Unsaved Documents" from this list. This opens a list of your unsaved documents.
Select the document you're looking for in this list, and then click "Open."
This opens the document, which now has a yellow bar across the top.
Click the "Save As" button in the yellow bar.
Save your document with your desired name to your preferred location.
or
The power just went out while you working on an important document you forgot to save.
Do not panic because Microsoft Word comes equipped with a feature that automatically will recover files you did not save.
Typically, this feature works by default.
The program allows you to change how often Word saves your documents and you can adjust the location where Microsoft Word saves these "Auto Recover" files.
Open up Microsoft Word.
Do not click on a file to open the program.
Instead, open the program by double-clicking on the program's icon.
Allow the program to load for a couple of minutes before clicking on anything.
Look on the left side of the screen.
If Microsoft Word recovered the file, a "Document Recovery" task pane will load.
Find the file's date.
Double-click on the file in the "Document Recovery" pane.
This will open the file in Microsoft Word.
Click on the "File Menu" and select "Save As."
Save the document as a ".doc" file type, and type a name for your document in the "File Name" box.
or
Open Microsoft Word to determine if the program auto-recovered your document.
If your software is set to auto-save your document every couple of minutes, when the program is restarted, any document that was not saved prior to closing, may appear in the auto-recover window on the left side of the screen.
Click on your document, and the last-saved file will open.
However, anything you typed after the last auto-save is gone, but at least you haven't lost the entire document.
Search the auto-recover files manually if the auto-recover pane did not appear when you opened MS Word.
Click the Start menu at the bottom of your computer screen, and click "Search." Some operating systems have the search option as a part of the Start menu.
Search for "*.asd" to search for any recovered files.
If you find the file, open Word, and click "Open" in the menu.
Search through all files, and locate the file that ended in .asd. Click "Open" to view your file.
If you are using Word 2002 or 2003, you need to restart your computer after clicking "Open." Re-open Word after your computer re-boots to view the recovered file.
Check your backup files.
If you have the "Always create backup copy" option selected in Word, you may be able to find a backup copy of your document.
Find the location where you last saved the document.
Check for the extension .wbk.
If there aren't any, search your whole computer for files with that extension.
Open your file by clicking "Open" in Word, and search all files for the .wbk extension.
Once you locate the file, click "Open."
Look in the temporary files on your computer.
Complete a search for files that end in the extension .tmp by typing "*.tmp" into the search box.
Narrow the search down to specific dates of when you were working on the document.
If the file does not show up, try searching for the "~*.*" convention.
Some temporary files are in this format instead.
If your document is now in your temporary files, you will need to recover the damaged document.
Search for it within Word.
Click "Open and Repair" when you find it.
Hope this helps
Nov 06, 2012 | HP Pavilion Slimline s3600f Desktop PC
Failure to save document copy for annotation
If you are on Android KitKat version, check the details listed on the app in the Play store for information about how to open the files in a way that will allow them to save. There is some restriction on savingto the SD card.
May 11, 2012 | Unidocs ezPDF Reader
How do I clear all information from a LG VX5500 Cell Phone before returning it.
Steps to Reset Settings
This resets the phone to factory default settings.
  1. With the flip open, press the OK key [Menu].
  2. Press 9 or Settings & Tools.
  3. Press 6 or Phone Settings.
  4. Press 7 or Security.
  5. Enter lock code. The default lock code is the last 4 digits of your phone number.
  6. Press 5 or Reset Default.
  7. Press OK after reading the warning message.
  8. Select Revert by pressing OK. A confirmation message is displayed briefly before the phone resets itself.
Steps to Restore Phone
This erases all user data and contact information entered in phone memory.
  6. Press 6 or Restore Phone.
  8. Enter lock code. The default lock code is the last 4 digits of your phone number.
Sep 14, 2011 | LG VX5500 Cell Phone
I'm experiencing the following problem two to three times a day in Microsoft Outlook 2003 and Microsoft Word 2003: Outlook I'll open a message in my inbox and the message body will be blank. This...
It could be your computer needs more ram memory, or if you have enough you need to reload office. Also go into control panel, click on system-->& advanced tab click the button that sayes best performance,& try that.
Good luck,
Jdrumboy. .
Mar 03, 2011 | Computers & Internet
I have bought a new toshiba A665 a week ago. I have a problem saying. ' A problem in the cooling system has been identified. Switch off ur computer and return it for service.' Cooling fan is working but...
At a week old, get a replacement or fix it right away. Fix should be free, but no computer during service.....
Toshibas run too hot, in my opinion.... so you have to keep after the fans and keep lint cleaned out of it....
Overheating will yield un stable system,
Feb 26, 2011 | Toshiba (K000831860) Cooling Fan
DVI warnings when you connect HDMI cables
TV IS IN DEMO MODE GO IN OPTIONS MENU OF VIDEO AND TURN OFF. READ OWNERS MANUAL PAGE 80,81,82
Sep 22, 2009 | LG 32LH20 32 in. LCD HDTV
My tft hpl1908w,is not starting up immediately when i switch on my pc.you have to switch off and on again several times so that it can start up.but onece started up there is no problem untill you switch it...
HP SUPPORT COMMUNICATION - CUSTOMER NOTICE Document ID: c01764371
Version: 1
Notice: HP Flat Panel Monitors - Pressing Menu Button Or Power Button Has No Effect Other Than To Display A Warning Message NOTICE: The information in this document, including products and software versions, is current as of the Release Date. This document is subject to change without notice. Release Date: 2009-06-05
Last Updated: 2009-06-05
DESCRIPTION Many newer HP monitors have a feature that allows users to disable the front panel Menu and Power buttons. When they are disabled, pressing them has no effect other than to display on-screen warning messages.
DETAILS If the Power button is disabled; pressing it displays this message:
Power Button Lockout
If the Menu button disabled, pressing it displays this message:
OSD Lockout
The buttons can be re-enabled as follows:
If the Power button is disabled, press and hold it for 10 seconds to unlock it.
If the Menu button is disabled, press and hold it for 10 seconds to unlock it.
NOTE If the Power or Menu buttons are not disabled, pressing and holding them for 10 seconds will disabled them. Here's the site.....
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3548687&prodTypeId=382087&objectID=c01764371
Jun 28, 2009 | Computers & Internet
Warning message being displayed when magicjack is plugged
My Magic Jack was working fine. One day I got some viruses in my computer and I ran setup CD.After that magic jack is not working, it always display "Warning you must plug magic jack into usb".
I tried to chat with tech persons so many times and tried many methods but when they say "now unplug and plug in" , then magic jack home page opened on chating window (always) and stopped chating.
and still I'm getting same 'warning' message.
Oct 23, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
