Problem with installation printer all in one Canon MP600, Pc can see usb connection but not recognizing as a printer, I have try few times on my pc and laptop on vista and xp with two different usb cables and it's all same, please help ! :) peterb
  • piotrbator Dec 07, 2008
    Yes, I have done everything as per installation. I can't return printer, warranty expires. I had very same problem last year, when I went to the shop they tried on different pc and work without and problems. And works for me at home after that as well. In the usb connection in printer maybe loose? I don't remember exactly if problems from last year was same as now, but now. In the end of instalation there is a 3 screens shows first to plug-in usb into the pc, then into the printer and finaly tun on printer. and only what I having is "USB Device Not Recognized-one of the USB devices attached to this computer has malfunctioned, and windows does not recognize it. For assistance in solving this problem, click this message." when I try installing printer with usb conected and turned on printer in the end of it aks me to manualy select the port, I slect one of them, I didn't know into which my printer is conected and computer recognize my printer, even model MP600, but coldn't print enything.
    I'm using canon cd. Yes I have tried xp on my pc and vista on laptop
    and it's exactly same. I sure on 99.9% that printer will works
    perfectly I even try do scan picture and print. Works perfect. I have
    tried 2 different systems, 2 different usb cables and and both
    computers can see usb cable but can not recgognize divice, is the usb
    connection in printer may be loose/damage ?
  • 4,472 Answers
Did you make sure to install the printer first before you plug it in? This can cause an issue the printer cannot be plugged in when you install it. If you still have problems you may have to return it or have it repaired under warranty. Please take a moment to rate my solution fixya.
Thanks,
Lee
Posted on Dec 07, 2008
  • Lee A.
    Lee A. Dec 07, 2008
    Being that you have had the same problem on all the operating systems and different systems it sounds like a problem with the printer itself. You can not get the printer to work right at all correct? Are you installing from a cd or from a downloaded installation?
    Thanks,
    Lee
  • Lee A.
    Lee A. Dec 07, 2008
    http://www.usa.canon.com/consumer/contro...
    If you follow this link you can download the latest software to ensure it is not your installation disc.
    Thanks,
    Lee
I am unable to re-instal canon pixma mp600 on my windows 7 it suddenly stopped working it now has fout RPC unable to connect when I try to re-instal the disc says that it is not compatable for windows 7
You can download "Drivers & Software" for Win7 (32bit & 64Bit) @ http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#DriversAndSoftware
Select your OS ie Win7(32bit) or Win7(64bit).
Disconnect the printer from the PC, and delete the printer you have installed & remove all the software previously installed on the PC. Reinstall the download "Drivers & Software".
Hope it helps.
Hope it helps.
Jul 14, 2011 | Canon PIXMA MP600 all-In-One InkJet...
My computer does not recognize my printer
Ensure you use the right driver to install your printer. Browse www.support.dell.com to get your printer model driver. And you will find it work.
Jun 10, 2011 | Dell 946 All-In-One InkJet Printer
Hi, I have brand new Canon MP140 3 in 1. I am getting the error message &cannot communicate with scanner. Cable may be disconnected or scanner may be turned off. Check status. scanner driver will be...
1. If you are connected correctly (via a USB cable), first be certain that the cable is snug on both sides (PC and Canon MP140).
2. If still a problem, remove the Canon MP140 icon from Printers and Faxes.
3. Then, disconnect the USB cable.
4. Restart your PC and log into Windows.
5. Connect the USB cable.
6. The PC should recognize the Canon MP130 and ask for a driver.
7. Install the driver.
If #6 does not happen, your USB cable could be faulty or may be a problem with USB port or your Canon. Move USB cable to a different USB port on the PC. Replace the USB cable. Try to install the Canon on a different PC to test.
Hope this helps.
Aug 11, 2009 | Panda ANTIVIRUS ED PLT 7.0 1YR 26-50...
Pixia MP600 had been working fine but now computer with Vista fails to recognize it and says something on connected to USB has malfunctioned. Also where can I get a installation cd that is in English. The...
while you install the software cd . you can see the language settings for display there you can change your own language. dont connect the devices before you install the software cd while you install the cd it will ask you the default settings from there you can change the setings.
Jun 16, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma mp600 stopped connecting to computer
try to transfer the usb cable to another USB port..or swap with the another working USB port..and restart your computer..
May 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Pc doesn't recognize the MP170 printer
sure..i'd recommend that you go to printer panel, and enable the printer as online
Aug 20, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA MP780
The problem is not the printer or the make of printer: The problem lies with the PC
Jul 06, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon MP600 printer
Did ur driver's installed suksesfully on pc?
If not download and install from here:
http://driverscollection.com/?H=PIXMA%20MP600&By=Canon
If u still need help do not hesitate please
If you got help RATE ME AS FIXYA!
Dec 21, 2007 | Canon PIXMA MP600 all-In-One InkJet...
MP600 canon printer computer cannot recognise USB device
Try different USB ports on the computer to see if its a porblem with the port connection and if there's no change there then try using another USB cable that you know is working perfectly fine.
Nov 25, 2007 | Canon PIXMA MP600 all-In-One InkJet...
MP600
Here you can download those drivers :
http://software.canon-europe.com/software/0024902.asp
if u got help plese rate this solution as  " sloved "
Beni
Oct 15, 2007 | Canon PIXMA MP600 all-In-One InkJet...
144 people viewed this question
k24674
jasbo
jasbo
