Linksys router mod BERSR41 V4.2 after firmware upgrade 2.00.4.1 router does not work power light just flashes
    Problem Solver:
  • 5 Answers
If your firmware upgrade went bad, you now have a rock. Try to reset the unit.
Posted on Dec 07, 2008
My linksys wrt160n wireless router light is blinking
Welcome to FixYa
Indication of Router Lights:
  • Power light blinks. If LAN or WAN cable is plugged in, their respective lights will flash on activity.
  • Power light turns off for several seconds.
  • All lights, except power light, turn on and then off.
  • Power light blinks slowly, then faster, and WLAN light will turn on.
  • Once Power light and WLAN light are on solid, the router is fully rebooted.
A working router should show solid green power light. upgrade the firmware of the router.
If this Helped you-Rate me..Thanks for Using FixYa
Jun 30, 2010 | Linksys WRT160N Wireless Router
I`m use linksys rv042 router I can try firmware upgrade. after firmware upgrade my router`s DIAG light comes on at that point. If I do a power cycle to it, often times, the DIAG light comes on a stays...
sounds like a bad firmware updgrade,
roll back the firmware by redoing the upgrade with your backup that you made prior to the upgrade.
you made a backup right? they may provide older firmwares on the manfactures website linksys is usually good about this.
Jun 11, 2010 | Linksys RV042 VPN Router
My spa3102 has a flashing orange light can not do a reset with phone or with computer what can I do.
You may just press and hold the reset button for 30 seconds with the Power cable connected, then leave the unit unplugged and wait for 1 minute and re-connect the power cable... Download 67.3 MB, re-install using the Utility... You can also try upgrading the firmware for PLK300..You can find the Upgrade tool with firmware on www.linksys.com/downloads.
1. Go to: http://www.linksysbycisco.com/US/en/support/PLK300/download 2. Download Upgrade Instructions 3. Download Quick Installation. 4. Download latest firmware upgrade 5. Do the Upgrade first. This will completely wipe out your security settings. -This is a good thing as you probably know. -Do the upgrade on all units (PLE300 and all PLS300s that you have. -For the 4 port PLS300 just plug right in to your router) 6. After firmware upgrade, follow the instructions in Qucik Installation TO A TEE. Do exactly what in says in the exact order it says.
Feb 26, 2010 | Linksys SPA3102 Router (745883569519)
Losing connection constantly, when I hok up computer directly to the modem I have no problems, but with the router my internet does not work. The lights on the router are flashing and indicate that it is...
have you done a chat with Linksys? What do you use to manage your network?
May I suggest you get Network Magic, a free download and eval period.
Using Network Magic, you may find you have settings on the router that prevent your getting past your 'fire wall'.
Oct 12, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Firmware upgrade fail
If the firmware upgrade has failed there's a possibility that the router went bad already, first thing to try here is to reset the router by doing this steps, Press and hold the reset button of the router for 30 seconds while power is ON, then after that unplug the power of the router for 10 seconds and hopefully all the light will be back to its normal but if still the same and you cannot access the router setup page better contact Linksys and if its still under warranty have it replace....
Nov 05, 2008 | Linksys WRT350N Wireless Router
I can't connect to wireless
looks like a firmware corruption. try running a firmware update from http://support.dlink.com/products/revision.asp
Oct 15, 2008 | D-Link DI-624M Router (DI624MRE)
Firmware Upgrade Failed
Firmware upgrade is a simple but a delicate procedure. Make sure you are loading the correct firmware. You should get your firmware from the website of your router. Installing a THIRD PARTY firmware to your router voids the warranty of your router. Here is a tip for a successful firmware upgrade. BEFORE FIRMWARE UPGRADE(push the reset button of the router for 30 seconds then unplug the power of the router for 10 seconds). Upgrade the firmware. After the upgrade push the reset button again for 30seconds, unplug power for 10 seconds.
Mar 10, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless B BEFW11S4
That router should have a small hole on the back of the router (near the power plug, I believe) with a button inside. Use a paperclip to hold that button down for 5 to 10 seconds, then reset the power to the router, and it should be back to it's defaults.
If that doesn't work, the firmware is probably corrupted, and there's not a whole lot you can do about it.
Feb 12, 2008 | Linksys Wireless Ap + 4 Port Router...
Green Power light flashing
Hi, Have you tried a hard reset? Your model has a small reset button at the rear between the Internet/WAN connection and one of the antennas (Press for 10 seconds +). Also flashing power led is an indicator of firmware problem which might have been caused by a failed firmware upgrade/update. Instruction on how to correct this problem is also included in the firmware upgrade/update. A more detailed instruction is in the User Manual. With regards to firmware update/upgrade , pls be reminded that firmware is very version specific. To locate the version number, you have to look underneath the unit and download the appropriate firmware from LinkSys website. (http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859878881&packedargs=sku%3D1115416826220&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=7888126220B03&displaypage=download) The download is a zip file which you have to extract to a folder. The .bin file plus instructions as well as specific instructions on how to make the power led stop flashing. Hope this works out for you. Pls post again how things turn up. Good luck and kind regards.
Jul 28, 2007 | Linksys BEFW11S4 802.11b Wireless...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
