Question about Toshiba DKT-2010 Corded Phone
Handsets bypassed; need to restore
I bought two DKT-2010 SD phones on ebay, as replacements for my company's system. All is well except that the handsets appear to have been bypassed, most likely for telemarketing headsets. I do not know how to restore these phones to their original state so that we may use the handsets as a conventional telephone. The PDF user's manual I found online suggests a code that I can type to enter programming mode, but that is not working.
  • Matt Scheidler Feb 22, 2007
    Pat,
    These steps did not work. Maybe I didn't explain myself properly. Not only is the handset inoperable, but the switchook is also disabled. Picking up/hanging up the handset has no effect whatsoever on the telephone.
    I was able to find a free manual online. I don't recall the address, but I found it via Google.
    If this additional information helps shed some more light on my situation, please reply. Thank you.
    Novelist:
  • 201 Answers
These phones have a horrible problem with the hook switch. If you can only get the phone to work in speakerphone mode, most likely the hook switch is shot. If nothing happens when you lift the handset a bad hookswitch is likely. If the hook switch works but the talk path in the handset does not work, there may be a cut jumper wire. The wire is cut when a headset adapter is installed and if that adapter was later removed it will effect the talk path for the handset. If you take the back of the phone off you can see the jumper (visible from the back of the circuit board through a notch next to the speaker) If you can use a soldering iron, a cut jumper can be repaired easily by bending the wire back so there is only a small gap and soldering it. -Ben
Posted on Jul 07, 2007
I found some old notes of mine you could try, but they're involved: 1. [Spkr],#,603,500,[Speed Dial],[Redial],[Spkr],pick up hand set, hang up. 2. [Spkr],#,656,9,phone extension,[Redial],[Spkr],pick up hand set, hang up. 2. [Spkr],#,657,#,phone extension,[Redial],[Spkr],pick up hand set, hang up. Were you able to find a free manual online? Pat
Posted on Feb 21, 2007
Turning msg light off - I have no messages
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jul 14, 2014 | Toshiba DKT-2010 Corded Phone
Create a voicemail for toshiba DKT 2010-sd
Hit your main voicemail interrupt greeting by pressing pound enter box 999 enter password usuallu 999 or 999997 but could be anything listen to prompts ti create mail
Feb 06, 2014 | Toshiba DKT-2010 Corded Phone
Does teh DKT 2010-sd have a PRI card slot for voip
Since a DKT-2010 is just a phone that attaches to a Toshiba Key System, it's hard to say.
PRI and VoIP are two entirely different protocols. PRI is delivered on two pairs of wires and it contains up to 23 circuits and a data channel. It requires a card in your system, a DK, CTX, or CIX Key service unit.
VoIP can be delivered via an Analog Terminal Adapter, or directly into the KSU if you have a CIX-100 or higher system. Likewise, faxes are deliered on trunks to analog stations, or it just requires an analog line to receive. It can work within your system or outside of your system.
If you look at the manual, starting at page 21-23, this will give you an idea of the capabilities of a CIX system. http://cdgenp01.csd.toshiba.com/tsd/docum/gen_desc/CIX/CIX-GD-ALL-VF_E.pdf
Carl
Apr 15, 2010 | Toshiba Lands Phones
Trying to change the time on my Toshiba dkt2020-sd phone. I don't know how to do it.
FOR THE TOSHIBA DKT 2020-SD:
From main console phone (lowest extension number i.e. x100) pick up handset2_bing.gif and dial following codes:
For Time: Press "Intercom" and the numbers 652 enter the time in military format HHMMSS (HH=hours in 24hr clock, MM=minutes, SS=seconds) press "Redial".
Mar 15, 2010 | Toshiba DKT-2010 Corded Phone
Set the clock
The link below should provide all the info you'll need.
click here
Mar 11, 2009 | Toshiba DKT-2010 Corded Phone
Toshiba DKT-2010 SD acts only as a speakerphone
The Phone has to be replced or sent out for repair. It's a hook switch problem. It's Cheaper to just the phone off Ebay.
Oct 09, 2008 | Toshiba DKT-2010 Corded Phone
Long Distance Block
Unfortunately you have to access the system programming to do the changes and I'm sure your tech company has a secure password on the system.
Jul 23, 2008 | Toshiba DKT 3010 Corded Phone
Having trouble with a Toshiba model, Need to fix time .
I have DKT3010, so it might be the same, to change time in mine I press Intercom, #652, HH/MM/SS #. It changes it on all of the extensions.
Mar 10, 2008 | Toshiba DKT3010SD Corded Phone
Toshiba DKT-2010 Corded Phone Logo
248 people viewed this question
Top Toshiba Lands Phones Experts
Marvin
Marvin
Computer Links
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
