Abs light stopping on
Finding the fault code will not clear the problem if you reset the system without finding the cause the light will just come on again or the fault code will not clear.
Anything related to brakes should be checked out by a garage/mechanic and not ignored.
Its probably just an abs sensor failed but its better to be safe than sorry.
Sorry for the lecture but I wouldnt like to see anyone hurt due to brake system failure.
SOURCE: mazda tribute abs fault. abs
These vehicles have a recall on the ABS system for faulty wiring. You may want to check with your local dealer to see if your vehicle is included.
SOURCE: need radio code vauxhall astra 2000
could you tell me the make of unit in car & could you get the serial no. & part no. for unit it means having to take out thanx.
SOURCE: vauxhall astra horn
The problem is in the loom in the steering wheel, it requires removal of the airbag and a new wheel loom to be fitted. The loom costs about £15.00 I think.
SOURCE: my vauxhall astra engine is reving on its own at
have you had it on diagnostic machine cos i did with mine and ended up being the EGR valve?
SOURCE: my car wont start, 1997 vauxhall astra 1.7 turbo diesel
IVE JUST PUT A NEW IGNITION ON MY 1996 VAUXHALL ASTRA DIESEL VAN,NOW WHEN I TURN THE IGNITIN IT STARTS AND THEN CUTS STRAIGHT OUT. HOW DO I CURE THIS?
