Question about Plumbing
I am having trouble justifying the handle on a Hansgrohe Thermoballance III . I have reviewed the manual and find that the cartridge high temp limit stop is in the 3 o'clock position instead of the 6 o'clock position shown. I was trying to move the temp control from the 100 degree mark to the 110 degree mark (not enouh how water - yes I have adjusted the tankless water heater treashold) When I went to replace the handle via the justifying procedure, I find that the temp control knob doesn't move anymore. Before it rotated, but the water high temp was set at 100 degrees.
    Problem Solver:
  • 18 Answers
Try to remove the handle and rotate the stem inside the cartridge 180 degrees and reassemble. The cartridge should only fit in the valve body at a fixed position. If it won't turn don't force it as it may be necessary to remove the cartridge completely from the valve body before the stem will rotate to prevent damage to the ceramic. [Reminder] turn off water supply to valve first! and see if that will correct the problem.
Posted on Dec 11, 2008
Adjust handle stop on Metro high arc
Is it possible that you have installed the faucet incorrectly . Loosen it off and turn 90 degrees facing you so that one way is cold the other way hot.
May 08, 2013 | Hansgrohe Metro E Single Handle Deck Mount...
Manual for hansgrohe 14010 faucet
The 14010 faucet does not have any adjustment for handle tension. It uses a cartridge to control the on/off functions. If it is hard to turn on and off it may mean the cartridge has debris in it or has worn out over time. You may need to replace the cartridge. This should be part number 92730000. List is $48 and it is available through your local dealer or online dealer. If you need further help feel free to contact Hansgrohe Tech at 1-800-334-0455.
Jan 28, 2013 | Hansgrohe Plumbing
This Hansgrohe 04231000 S Thermostatic Trim With Volume Control And Diverter, was installed recently. The lever gradually moves down, to hot, when turned up towards the center at warm. When turned to...
The first thing to check is if the hot and cold lines are crossed. If they are correct the water should get cold when turning the thermostatic handle clockwise and hot when turning counter clockwise. The next thing to check is if the handle is properly justified. Properly installed the temperature will be 100 deg. when the handle lever is pointed down at six o'clock. If not properly justified it will increase the possibility of the handle not staying in place. If you need further help feel free to call Hansgrohe Tech at 1-800-334-0455.
Nov 19, 2012 | Plumbing
Leaking tap
This is most likely a cartridge that has worn out and needs to be replaced. Most of the kitchen faucets use cartridge number 92730000. This is available through your local dealer or online dealer. If you need further help feel free to contact me at Hansgrohe 1-800-334-0455. Press 2 for tech and ask for David Scarborough.
Oct 10, 2012 | Hansgrohe Plumbing
Need to replace cartridge on hansgrohe talis high arc faucet
The cartridge should come with instructions on replacement. The part number for the cartridge is 92730000. It is available through your local dealer or online dealer. If you need further help with obtaining the cartridge or installation feel free to give me a call at Hansgrohe. 1-800-334-0455. Press 2 for Tech and ask for David Scarborough. I'll be happy to help.
Oct 04, 2012 | Hansgrohe 32070821 Talis S Single-Hole...
How to replace hansgrohe M2 cartridge
First you will need to tighten the set screw all the way back in. The use your 4mm hex wrench to turn the screw 4 complete turns counter clockwise. Then remove your hex wrench and the handle should come off. There will be a dome shaped cover with blue and red indicator marks. This will simply pull off the cartridge nut. It is held on by o-ring tension only. Once removed you will see the large hex head of the cartridge retainer nut. Loosen this nut and the nut and cartridge will come out of the faucet. Don't be alarmed if your new cartridge is smaller than your old one. There has been a design change in the cartridge so it will fit smaller bodied faucets but will still replace the older thicker cartidge. If you need any further information feel free to give me a call at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'd be glad to help.
Aug 04, 2012 | Hansgrohe Plumbing
Adjusting water temp
Behind the handle there is usually a scald gaurd on the newer faucets. You can adjust it from there. If your not sure, follow this link and download the installation instructions to your faucet. There you will find how to adjust it step by step. http://www.hansgrohe-usa.com/us_en
Mar 05, 2009 | Hansgrohe Thermo II Rough-In Valve Chrome...
Hi folks, seems stupid, but I'm changing the cartridge on my american standard kitchen faucet. If I line up the holes on the botton of the cartridge with the holes in the fixture, I don't have the ability...
Most likely you need to adjust the hot limit safety stop which restricts handle swing to limit the high temp of the water and avoid scalding... check out this link to the install manual for your faucet. Also includes detailed diagram of cartridge alignment just in case you need it.
http://www.americanstandard-us.com/Assets/pdfs/as/install/Install_1859.pdf
Hope this helps, Tripp
Dec 13, 2008 | American Standard Kitchen Faucet 6310 020...
Plumbing Logo
233 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
