Question about Home
Leaks from top
At times when the pump runs, water leaks from the rubber grommet/seal at the top through which 2 electric lines pass through. It seems as though the water level inside the box is rising too high. Could it be in the float/ballast adjustment that monitors the water level inside?
  • stevie o Dec 14, 2008
    I have a Maytag #PSD2350DR that leaked until I installed an adapter that clipped to the condenser coil that kept the the drain that sits under it from freezing. (At the time I dropped a screw into the drain hole. ) This worked for awhile until now. I tried pouring hot water down the drain hole to melt the ice that is clogging it and this doesn't work.
    Does this drain direct water down into the pan under the refrigerator? Do you know of a way to clear this passageway?
    Steve
  • Roscoe007 May 11, 2010
    Im not sure what it is thats broken.
  • 101 Answers
Yes it goes to the pan.. you can ues a hair dryer but do not leave it unattended.Or your drain line is clogged to the pan .
Posted on Dec 16, 2008
Trying to replace my fuel pump on my bmw 325s i need to know how to get to it
ASSUMING ......it is the same as a 325i
-fuel pump located under rear seat (right side looking forward )
-working inside the car lift the rear seat
-Pull up rubber grommet which cable goes through
-remove circular steel cover plate
-disconnect mutliplug on top of pump
-unscrew bezel using hammer & punch
-Pull up pump from tank
-replace with new pump ensuring that rubber seal doesnt get kinked
-replace bezel
-connect mutliplug and test before replacing steel cover
-Ensure no leaks, even take car for a ride to ensure no leaks
-if tests ok then replace steel cover and grommet, & seat.
should take about 30mins taking you time.
Aug 25, 2010 | 1994 BMW 3 Series
Pontiac Bonneville with water leaking into trunk
same problem happened to my 2005 bonneville. inside the trunk and behind the carpet covering the wheel wells there are two water drain tubes. these tubes run down the inside of the "c" pillar and drain the water from the sunroof. they make a 90 degree bend at the bottom back of the wheel well(inside the trunk) and fit inside a round rubber tube/grommet at both of the rear wheel wells that lets the water drain outside.either the plastic 90 degree tube has come out of the rubber tube/grommet or the drain tube could be plugged up with debris. also make sure the two round rubber tube/grommets are installed correctly and seal the hole going through the trunk to the outside of each wheel well. this is of course only for those bonnevilles that have a factory sun/moon roof.
Sep 03, 2009 | 2002 Pontiac Bonneville
Leaking dishwasher
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Oct 27, 2008 | Maytag 24 in. DWU7402 Built-in Dishwasher
Westinghouse 906 leaks from front door
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Oct 05, 2008 | Westinghouse 24 in. MDP531 RF...
Leaking
The pumps usually have rubber hoses fitted them and they can deteriorate over time, moreso around the clamps that hold them onto the pump. Also, maybe the pump has been slightly opened via a worn seal. Either way, there may be a risk of fire if any water gets onto the electrical connections of the pump or spray onto any other open electrical connection inside the machine. It would certainly be advisable to have it checked with some urgency.
During the final rinse and spin, I would think the pump may not be used during these cycles.
Hope this helps somewhat.
Sep 14, 2008 | Whirlpool WTW6400SW Top Load Washer
Leaking coffeemaker
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
Jul 21, 2008 | Cuisinart DGB-600 Coffee Maker
DGB-600 grind & brew thermal coffeemaker
Water leaking from the base of the unit.
Jul 17, 2008 | Cuisinart DGB-600 Coffee Maker
Frigidaire Dishwasher leaking but not from door
hi there,
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
Door gasket or seal
Water-inlet valve
Hoses
Jun 30, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Water leaking
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great! But I must say that i have seen better engineering in child's toys!
Aug 31, 2007 | Cuisinart DGB-600 Coffee Maker
Home Logo
186 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
