There is a exclamation mark in the device manager beside the microsoft ISATAP adapter#5. Should this exclamation mark be here?
  • 27,725 Answers
Right click on the exclamation mark select update driver
if your computer came with a motherboard disk the drivers could be on it or you might download one
http://download.cnet.com/microsoft-isatap-adapter/3000-2112_4-68853.html
hope it helps
Posted on Nov 22, 2011
  • Brian Sullivan
    Brian Sullivan Nov 22, 2011
    if you dont have an internet connection either downoad this or find a computer with an internet connection download it save it a usb drive then take it home and install it from there http://download.cnet.com/microsoft-isata...
    Problem Solver:
  • 11 Answers
No. If you have the driver for it try reinstalling it. If you don't I would delete the device and reboot. This will force the drivers to be reloaded unless they were deleted...If they were deleted and you are not very good in computers, you may need a bit more troubleshooting than on line help.
Posted on Dec 07, 2008
Need new download of ISATAP drivers
Greetings,
On a Windows Vista-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark (!) next to it in Device Manager.
You can safely ignore this error message. This error message does not indicate a problem with the adapter. The adapter will continue to work correctly.
Check out this article for more information on this:
http://support.microsoft.com/kb/932520
If this is still not working,
First try to reset Winsock from command prompt, this will reset all the Network components to default:
Click on start, type CMD,'Right click and Run as Administrator'.
At the command prompt type:
netsh winsock reset catalog
In such a case, I suspect this problem to be caused by network adapter missing or corrupt. Please firstly reinstall the driver for your wireless network adapter. Then try to reinstall Microsoft ISATAP using following steps:
1.In Device Manger, right-click the item of Microsoft ISATAP and select Uninstall.
2.Still in Device Manager, click Action and select Add legacy hardware.
3.Click Next, and select Install the hardware that I manually select from a list (Advanced), click Next.
4.Select Network Adapters and click Next.
5.Select Microsoft in left panel and Microsoft ISATAP Adapter in the right panel.
6.Click Next and finish the remaining wizard.
Hope this helps you to solve the issue. Please do vote or provide feedback on this solution, your response will be appreciated.
Thank you and Kind Regards
Gowtam R
FIXYA Solutions Engineer.
Mar 18, 2013 | Microsoft ISATAP Adapter
ISATAP Code 31?
receive error code 31 if the device driver is not updated.
As you have already updated the device try reinstalling the device driver and check if that works, if that does not resolve the issue you may ignore the error message, below link will you go more information related to this issue:
On a Windows Vista-based computer or on a Windows Server 2008-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark next to it in Device Manager, and you also receive an error message
http://support.microsoft.com/default.aspx/kb/932520
Steps to uninstall and reinstall the device driver:
Uninstall and reinstall the device from device manger. Steps to uninstall the device:
i. Click Start, type devmgmt.msc and press enter.
ii. Locate Microsoft ISATAP Adapter device
iii. Right click on the device and select uninstall
iv. Restart the computer for the changes to happen
Uninstall and reinstall the adapter from Program and features. Steps to follow
i. Click Start and choose Control Panel
ii. In Control Panel double click on the "Programs and Features" icon.
iii. Here you can find all the programs and items which are installed in Windows Vista.
iv. To remove adapter click once on the program and then click on Uninstall/Change and follow the prompts.
hope this helps
Jul 03, 2012 | Microsoft ISATAP Adapter
I need microsoft ISATAP adapter #3 driver
you can try this:
Step1:
However, try the below steps to fix the issue you are experiencing:
1. Click on Start, type Device Manager in the search box.
2. In Device Manger, right-click the item of Microsoft ISATAP and select Uninstall.
3. Still in Device Manager, click Action and select Add legacy hardware.
4. Click next, and select Install the hardware that I manually select from a list (Advanced), click next.
5. Select Network Adapters and click next.
6. Select Microsoft in left panel and Microsoft ISATAP Adapter in the right panel.
7. Click next and finish the remaining wizard.
Step2:
The ISATAP is related to Internet Protocol 6.
Please check if IPv6[Internet Protocol version] is enabled on your computer to obtain an IPv6 address.
however this driver only pertains to ipv6, so your internet adapter should still function properly. if it is, you can do this:
Disable but leave ISATAP in the hardware list and go to your manufacturers Website
and check for Post SP1 Driver updates for your computers Chipset.
Feb 01, 2012 | Toshiba Computers & Internet
In Device Manager under Network Adapters the following have a yellow triangle in front of each one; 1. Microsoft 6 to 4 Adapter, 2. Microsoft ISATAP Adapter, 3. Microsoft ISATAP #2, 3. Microsoft Teredo...
the yellow mark on device manager means the driver has not been installed and the driver is connected to the motherboard use your motherboard drivers CD and install them or you can download them from the net
Dec 15, 2010 | HP Pavilion m7640n PC Desktop
In Device Manager, under Network Adapters I find a new entry called "Microsoft ISATAP Adapter".The yellow explanation mark indicating a problem is present. Status shows "Windows is unable...
Hi.
Let me explain you about the Microsoft ISATAP Adapters.
ISATAP (Intra-Site Automatic Tunnel Addressing Protocol) is an IPv6 transition mechanism meant to transmit IPv6packets between dual-stack nodes on top of an IPv4 network.
It is a Windows Operating System Generic Driver.
This Driver will be installed automatically.
As this is a Windows default Driver, it has no specific functions.
As you are able to view the "yellow exclamation mark", you may just un-install the Driver..
This should not change the functionality of the Computer.
1) Right-click on the "ISATAP Adapter" in the Device Manager. 2) Then, click on "Un-install". 3) This should un-install the Driver. 4) Once you have done the above steps, restart the Computer for the settings to be enabled.
Performing the above steps should resolve the issue.
Hope this helps.
Please feel free to contact for further information and assistance.
Nov 23, 2010 | HP Pavilion dv6000z Notebook
Hi my Microsoft ISATAP is not working I followed the steps to reinstall it, is still not working
Hi j_lorcy,
As per Microsoft, you can safely ignore this error message. The Microsoft ISATAP adapter appears with a yellow exclamation mark (!) next to it in Device Manager does not indicate a problem with the adapter. The adapter will continue to work correctly. Microsoft has confirmed that this is a problem in the Microsoft Windows Vista-based Computer or on a Windows Server 2008-based Computer.
Hope this helps.
Please post back if you have any questions or require any further assistance.
Thanks for using FixYa.
Nov 02, 2010 | HP Pavilion dv6000z Notebook
I have windows vista home premium on my home computer and have been experiencing some internet disruptions. The only two ways I have found to reset the internet connection is (1) unplug my router and then...
In the Control Panel, update the drivers. If still unsuccessful, delete those adapters, restart your workstation and reinstall drivers. Helpful to have another workstation nearby in case you need to download the drivers from the Internet.
Jun 10, 2009 | Computers & Internet
EXCLAMATION MARK IN THE DEVICE MANAGER
Regarding the Microsoft ISATAP Adapter error, you can ignore it safely. Please refer to the following link:
http://support.microsoft.com/kb/932520/en-us
Dec 07, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
