Question about LG WM-3677HW Front Load Washer / Dryer
I cannot find my manual, so I am asking about my washer here! I have the LG WM3677HW washer/dryer combo and am wondering where the lint screen is that I should be cleaning. I just moved into an apartment with this unit and figure it's time to clean the lint screen, however I cannot find one.
Download it from http://www.retrevo.com
Posted on Apr 29, 2009
    Problem Solver:
  • 16 Answers
You can contact lg at 800-243-0000, they will probably send you a new manual.
Posted on Dec 07, 2008
LG Washer/Dryer Combo not spinning
If you can make the motor spin a few revolution by manual intervention, then the issue is most likely a faulty motor 'start' capacitor which is located near the motor: this replacement involves a dangerous MAIN AC VOLTAGE device and I would advice getting a qualified technician to check/repair your dryer.
Hope it helps.
Apr 06, 2014 | LG WM-2277HW Front Load Washer
I replaced the hot & cold water valves on my LG Washer/Dryer .Now it just humms and no water goes into the washer..What can cause this problem?
have you tried both the cold and hot?hot only has one solenoid while the cold has three.just because it is a new part dose not mean it is not mean it is a good part.try this,turn off the cold and hot water,remove the cold hose from the washer and put it in a bucket and turn it on at the hose bib.if you do not get water,you may have a screen in the hose bib end of the hose.if no screen on that end you may have a metal fitting rusted up just under the hose bib.check the hot side also.hope this helps,if not repost and i will try to dig deeper.thanks
Mar 15, 2014 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG WM3677HW combo unit sets a LE code and stops in mid cycle. Motor was replaced but still does it.
Sensor maybe???
Here is a tip about the LE code that gives other thoughts also...
heatman101
Apr 23, 2010 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Where does the lin tgo on my LG TROMM Model WM3677WH
Per the LG web site, the combo units are self cleaning. The trapped lint is washed out of the system automatically.
You should pay attention to the "cleaning" instructions for this unit. It is important to keep excessive soap buildup cleared out. Also be sure to use the correct soap - special, low suds.
Oct 11, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Lg wm3677hw combo washer drain pump repair question
You replace the whole drain pump. Pretty easy to do from the opening in the bottom by resting the unit on its back. (Make sure you drain the unit completely) You should be able to get the drain pump (pt #4681EA2001D) from http://www.encompassparts.com/lgconsumer/ for less than $50 + s&h.
Aug 31, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
WM3677HW - no rinse cycle (not rinsing)
Possible door switch not closing or opening.
Jul 30, 2009 | Washing Machines
I'm looking to find acopy of the owners manual
au.lge.com
Go to this site and download the pdf file for your
model
Jun 13, 2009 | LG WM-3677HW Front Load Washer / Dryer
LG Senseclean washer dryer combo won't dry
The problem is likely due to lint build up in the condensing unit. I found a solution here:
http://www.motusconnect.com/blog/2009/1/5/lg-washer-dryer-drama-%E2%80%93-diy-fix
I also had a softball size ball of wet, packed lint in the condensing unit. I found that the unit can be cleaned without tools or dis-assembly by:
  1. draining the water.
  2. laying the washer on it's back.
  3. removing the hose clamp on the rubber bellows that connects the drum to the condensing unit (right hand side of machine).
  4. digging the lint wads out with your fingers and a small screwdriver.
Happy drying!
Jan 15, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG WM-3677HW Front Load Washer / Dryer Logo
401 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
