Question about Epson Stylus 880 InkJet Color Printer
Epson i880 Waste Ink pad location
I have an Epson i 880 that had all the lights flashing so I followed instrctions on how to reset and its working fine now.
Im told I should replace or clean the Waste Ink Pads. I removed the cover but can seem to locate this washable pad. Help !!
jodysdee@sbcglobal.net
  • dreeddesign Jan 02, 2009
    I also need to kow how to remove the waste pads on an 880. Can anyone post step by step instructions. I got the printer reset, but the black is still prining messy so I want to clean.repair the pads.
    thanks for any help
  • Epson Master
  • 541 Answers
Try this plz dont for get to rate
1. Turn the printer off.
2. Hold down the ink and paper buttons, and turn the printer back on.
3. Within a few seconds, the paper light will start flashing quickly. When it does, let go of both buttons.
4. Within 3 seconds press (and hold) the ink button.
5. Hold it until all three red lights start flashing (about 10 seconds).
6. Let go of everything.
7. Turn the printer off, and back on.
Posted on Dec 12, 2008
When i turn on the printer all the lights are blinking, i have reset the printer many times, restarted my computer and nothing has worked to help the problem. I just printed yesterday with this printer...
The Epson Stylus Color 880 has 4 LEDs. If all 4 are flashing or blinking then the printer has a maintenance request error. It means that the waste ink counter has reach its limit. The remedy is to replace the waste ink pads and reset the waste ink counter. You can use the SSC service utility to reset the protection counter. You can download the utility from here http://inkjetprinterhelp.us/epsonSSC.html
You can also use the control paler to reset the counter. Timing is the key to success when you reset the counter using the control panel so keep that in mind. To reset the protection counter using the control panel (front panel):
Step 1.Turn the power on while holdint the following buttons doen. Paper feed, cleaning button. (thr paper out light will flash for 3 seconds)
Step 2.While the paper out light is still flashing press the cleaning button for 10 seconds. The following leds will flash in sequence Ink out lights black and color, Paper out light. Once the printer starts to initilize the counter should be reset. This will reset the protection counter.
Feb 17, 2011 | Epson Stylus 880 InkJet Color Printer
Both ink and paper light are flashing alternate and I cant get the printer to work epson d68
Your printer needs to be reset. Flashing lights means that your waste ink pad is full when that happens printer stops working to prevent flooding of waste ink inside your printer. Google search for a resetter program for epson d68. You need to replace the waste ink pad or create a tube line to divert the waste ink out of the printer. Good luck.
Jan 11, 2010 | Epson Office Equipment & Supplies
Flash feed paper & ink light my epson r1800 printer
Do you mean that the paper light flashes at the same time as the ink light or do they flash alternately (ie: paper on, ink off -> paper off, ink on)?
If so the waste ink pads are full and you need to do the following:
1. Reset the waste ink counter:
Grab the tool linked from the wasteink.co.uk site (see bottom).
2. Redirect your waste ink into an external tank OR replace your waste ink pads.. (external tank is easier).
Instructions for the R1800 are available from this site
If the lights are doing something different, please post again with detailed information about how they flash and I can what else it might mean.
Hope that helps.
Mar 10, 2009 | Epson Stylus Photo R1800 InkJet Printer
Epson 2400 paper red light and ink red light
It sounds like your printer has reached what is often called the "service required" stage...
To solve this you need to handle two things.
1. Get the printer protection counter (or waste-ink as it's sometimes called) reset.
2. Replace the waste ink pads OR redirect your waste ink flow to an external tank
It's important to note that Epson will encourage you to do a waste pad replacement through one of their service centers, but if you're out of warranty this will cost a significant amount of money (approx: $100 - 200)
To solve these as a DIY you can do the following:
1. Resetting the counter...
Get a resetter, either the SSC utility (google: epson SSC utility) or the IPR utility that Epson have now made available via their website here
The latter is only available to North American printer owners so the SSC is a safer bet.
2. Redirecting waste ink to an external container.
This is something I'd heartily recommend instead of trying to change the waste pads yourself... It's simple enough to do and a little googling using keywords "Epson R2400 waste ink tank" should get you all the info you need.
There are simple kits available that offer everything you need or you can easily go for a DIY with bits you have to hand.
Hope that helps...
Mar 07, 2009 | Epson Stylus Photo R2400 InkJet Printer
All lights flashing on the epson stylus photo 870. Printer not working.
Unfortunately, the Russian software does not work on a Mac, and it crashes at launch when installed in WZ98 under Virtual PC. However, I found this on another site, and it worked immediately:
The sequence to reset the waste ink counter is as follows:
WASTE INK ROM RESET ONLY 870, 1270
1. Turn the printer off using the power button on the panel of the printer.
2. Disconnect the interface cable at the back of the printer.
3. Hold down the "LOAD/EJECT" and "CLEANING" buttons simultaneously.
4. Turn the printer on. Release all buttons as soon as paper out light flashes.
5. Quickly press (within 3 seconds while PAPER OUT light is flashing) the "CLEANING" button for 10 seconds.
6. Release the button and the printer will initialize.
7. Once initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on
Works great, no muss...no fuss!
Feb 26, 2009 | Epson Stylus Photo 870 InkJet Printer
Reset waste ink counter on Epson C60 printer
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can restore your printer to a working condition immediately by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Feb 24, 2009 | Epson Stylus C60 InkJet Printer
Epson c46 printer
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C46 Service Manual". You will often find them for sale very cheaply on E-Bay.
Oct 19, 2008 | Epson Stylus C46 InkJet Printer
Location of waste ink pads Epson Stylus Color 880
Remove your cartridges and clean the area where the cartridges are seated with warm water or a little alcohol
Aug 06, 2008 | Epson Stylus 880 InkJet Color Printer
Epson C46 has stopped printing with message saying service needed but nobody wants to make it carry on working
If both printer lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens.
If you wish to pursue this matter further, report back.
Apr 12, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson stylus 880 all lights flashing
timsmilefam found a tech forum that solved this by jflan/mentor - give credit where deserved - THANKS! IT WORKED!!
his may be a call for your waste ink pad to be serviced.
Every time your printer goes into a cleaning cycle ink is pulled through the head and stored in this waste ink pad.
There is a procedure for this but it is more involved than the average owner will want to get.
A way to temporarily silence the flashing until the printer can be serviced may be :
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons, then press and hold down the ink button for 10 seconds. This allegedly resets the printer to "new" condition."
Nov 12, 2007 | Epson Stylus 880 InkJet Color Printer
Epson Stylus 880 InkJet Color Printer Logo
484 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
