Question about Fellowes 59493 Keyboard
F keys My F keys just quit working all of a sudden. I must have hit something but I'm not sure what. How do I turn them back on?
    President:
  • 8,637 Answers
Try pressing the F LOCK key before using the F keys. Hope this helps. Bud
Posted on Jan 17, 2009
The computer says that my wireless capabilities are turned off
Look on both sides and in the front of the laptop for a switch or button that controls the wireless.
If the wireless switch is turned on then maybe you hit the keystrokes that toggles the wireless On or Off.
Normally to toggle the wireless with keystrokes you have to Press and Hold the FN function key then hit the correct key (F1 thru F12) that toggles the wireless. The correct key will have the wireless icon on it and it may look something like this )))). Or it may be a tower with ))) on it.
Apr 14, 2012 | HP Compaq Presario CQ61410US Notebook
Hi I have a Fujitsu Siemens Amilo pi1505. I cannot connect to any network via the LAN connector. Also the wireless LAN which used to work has suddenly stopped working. I went into the BIOS setup and...
Whenever you can't connect to a network it is rarely the computer that is at fault, especially if it has been working.
Step 1, however, is to turn off your modem, router, and computer for 10 to 30 seconds, then turn on the modem and router (often the same unit), then the computer. If the computer is connected to an Ethernet cable, make sure you see lights on both ends of the cable, on the router and on the computer, if not, unplug and re-seat the plugs.
Step 2, If step 1 did not resolve the problem, bring up your command line on the computer. In Windows, click start and type cmd then hit the enter key or Win+R, type cmd and hit the enter key... this will bring up a command line tool. In Linux, find the terminal app.
Step 3, in the command line tool, type: ipconfig (ifconfig if you are using an Apple or Linux product) and hit the enter key.
You will be presented with a list of items, look for your IPV4 IP Address. Your IP address should look something like 192.168.0.048. If the first number is 169 you are not connected to any network. Look for a default gateway and write down that IP address (usually 192.168.0.1, but could be something like 10.10.0.1)
Step 4, type the command ping 192.168.0.1 (use your gateway address). If you get replies back from that, you are able to talk to your router.
Step 5, type the command ping google.com. If you get no replies back, your internet service provider is most likely down, and you should call them. It could also be that your DNS server is not properly configured in your network settings, but if your computer WAS working, it should still be OK.
Step 6, If none of the above solves your problem surfing the web with a browser, then your browser may have been hijacked, you will want to run a couple of good anti-malware utilities to find out. I use two to solve most problems: HitManPro (www.hitman.com) and MalwareBytes (malwarebytes.org)
Oct 25, 2017 | Fujitsu Siemens Computers & Internet
My hp 9020 stopped working suddenly. Although the battery was charged, the notebook just broke down and will not turn on. The battery led turns orange when I press the power key. I took the battery out,...
dont they all , eventually. all do a fact. but why ? so leave that old battery out, run on AC for ever if you wish and for SURE TESTING. they love to fail and overload the PC. so with AC good power pack no main battery does the power turn on? y/n does the fan run (above is yes) does the cd tray eject does the bios message show on the screen, it must "hit f10 to setup?" means BIOS page. does it, or is the screen back totally no text EVER. even hitting the F10 key or the key it told you to hit for 10 years. that is called fan running and not packed up. the black screen of *****. we have no idea what YOU can do, your skills your tools, ? how can any person know that. if not black screens of deathh then say so and say what you saw fully this time. http://pcdied.com/black-screen.html its a nx9020 (2004, 13 long hard years old.!!!) not 9020, the nx matters . big time top black screens fan ok are? COIN cell dead. CMOS RTC battery coin main battery shorted, nah its parked on shelf. CCFL lamps it PC are dead. as all are this old do the flash light trick yet, fan blowing.
Nov 22, 2017 | HP Compaq nx9020 Notebook
2001 ml320, remotes quit working. new batteries,
Synchronization
Turn ignition switch to position II. Turn ignition switch to position 0 and remove key. Within 1 minute: Press and hold key lock button. Press unlock button 5 times. Remote control should now operate system. If not: Repeat procedure.
Programming
When
Key remote control added or replaced. System malfunction.
How
Keys can only be programmed using diagnostic equipment
Jan 09, 2010 | 2002 Mercedes-Benz C-Class
Both printer and 9 pin serial ports not working
What has changed? One solution is to go into BIOS when you first turn on your PC hit <del> key. Make sure the ports are enabled. The second solution is to make sure you didn't add a device with serial ports or something which is sharing the same IRQs, which is 3 4 and 7 traditionally (for COM1/2 and parallel port).
If you tried all this and it doesnt work, then somehow the chip on the motherboard which handles these (the UART chip) has broke, you need to replace the motherboard or buy a card with serial and parallel ports on it (this should be quite cheap, ie 10-20 dollars).
Nov 07, 2009 | Intel Computers & Internet
While typing, all of sudden, the screen scrolls
Hit the Fn key and see if that solves your problem.
Post back if you require anymore help.
Regards.
Oct 01, 2009 | Lenovo ThinkPad T400 - Intel Centrino 2...
Both of my keys suddenly do not work.
It sounds like the tumbler that the key goesd into has broken, and the componets inside of it have made contact so that it is stuck in the start position. disconnect the wire from the switch in the column and hook the batt. back up if problem still prosists get the starter checked to see if it has malfunctioned
Jul 16, 2009 | 1998 Ford Explorer
I have a 1994 Toyota pickup suddenly Friday the ignition key would not turn. Not wanting to break the key off I jiggled worked the wheel back and forth the transmission lever nothing seemed to help. I...
Hi. sounds like your ignition lock is stickey not retracting all the way thus meeting partially with the ''hole'' its supposed to lock in, in the steering coulomb. i suggest you remove ,properly clean and inspect the lock for problem areas, kindly lubricate the involved bits and test, if all fails replace the ignition lock.
Jul 22, 2008 | Toyota Pickup Cars & Trucks
18" mower suddenly stopped working
motor problem.if you hit something stone our water springler may be the motor magnetic ring broke & jam the armature & not
to start & house pop. see toolpartsdirect.com looks for the model of the mower. black & decker
Feb 08, 2008 | Black & Decker 19" Electric Lawnhog...
Fellowes 59493 Keyboard Logo
69 people viewed this question
Top Fellowes Computers & Internet Experts
Gary Paul
Level 1 Expert
Are you a Fellowes Computer and Internet Expert? Answer questions, earn points and help others
