Question about Car Audio & Video
Audiovox Prestige P-88 wiring harness
Can someone direct me to a place where I can get s wiring harness for a Audiovox Prestige P-88 cd player. the cd player itself is 4 or 5 years old. Any help would be appreciated.
robotek
  • 1512 Answers
SOURCE: kenwood MP4029 4 code reset
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Posted on Dec 14, 2007
SOURCE: Kenwood stereo Won't turn on
look and see if there is a reset... usually a tiny hole you can push a pen point into...(lightly)
Posted on Feb 15, 2008
tech48
  • 624 Answers
SOURCE: Wiring/Installation of Pioneer CD Player
You need to get an installation kit that also has the universal wiring harness to connect to the factory harness in the car. That way you only need to match the wire colors of the Pioneer harness to the wire colors of the universal harness and made good connections and insulate those connections. Then the Pioneer harness plugs into the Pioneer radio and the universal harness plugs into the factory harness in the car.
Let me know if this helps, or if you need more help.
Dave
Posted on Jul 07, 2008
  • 6 Answers
SOURCE: need a wiring diagram for my 92 volvo 940 gl
Go to the following site and enter the make and model of your vehicle and it will give you a free diogram of the wiring to your stereo. The colors do not have to match up.
Posted on Apr 14, 2009
taran_2005
  • 10515 Answers
SOURCE: wiring diagram for audiovox cd radio in dash
The diagram would be :-
Posted on Jun 24, 2009
Need to find new wire harness for Jensen MCD5100
Jensen is now owned by Audiovox. Try going to audiovox.com.
Aug 02, 2011 | Jensen MCD5110 CD Player
Cd changer connections
Hi, On your Audiovox ACC56 10-Disc CD Changer with a Prestige P-165/P-185 FM Modulator, the wires: black - goes to the body (-) ground (as you correctly posted); Green/white - (with a small filter box) goes to the constant/always on 12V supply such as the + terminal of your battery Orange/White - should be connected to a switched power source such as the accessory terminal of your ignition switch or to the blue or yellow wire of your head unit or car stereo or whatever wire that will have 12V+ only when the head unit or car stereo is switched on. Hope this be of some help to you. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 21, 2007 | Audiovox ACC56 10-Disc CD Changer
My daughter has a 98 olds 88 i removed the stock stereo and put in a pioneer cd player but i didnt see any wire on the stereo side for the elec. antenna i was wondering how i can wire it to work
Most aftermarket pioneer cd/radio decks have the electrical connector for the antenna that I've seen.
Is this a cd only deck, or does it have radio functions?
Did you use a new harness wiring adapter to get the pioneer radio to work with the old harness?
There should be a color coded set of wires for the power antenna on that. And, then the Pioneer radio should have wires that were labeled for the power antenna.
Oct 08, 2010 | 1998 Oldsmobile 88
I have an Audiovox uv7i and I dont have the 16 pin for it. Is there anywhere that I could get one?
just make one dude its easy its the ending of wires of any harness just pull one out of a different wireing harness and push in that harness and wala yup that simple get back at me theses harnesses everywhere old stereo or buy one cheap on from walmart stereo dept.
Apr 26, 2010 | Audiovox UV7i Car DVD Player
How to deactivate a prestige car alarm
remove the fuse in the main harness going in to the alarm unit under the dash, if you have a starter kill feature you may need to bypass this. you will need to make up a jumper wire and place it in pin 30 and 87 on the relay
Feb 07, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
Installation manual
http://www.audiovox.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=14504&langId=-1
May 21, 2009 | Audiovox Vehicle Parts & Accessories
VM9512 no audio
Run your blue wire on your harness plug the blue and white of the head unit. The blue wire on the deck is for your radio antena and turns off when you switch to cd. This should fix your problem.
Jun 28, 2008 | Audiovox VM9512 Car DVD Player
Wiring
You might have to go to Best Buy and get a wiring harness adapter for Cadillac
Dec 29, 2007 | Durabrand DB1200 CD Player
Car Audio & Video Logo
100 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
