Takes numerous tries to get TV to turn on from set or remote
    Genius:
  • 1,199 Answers
Sounds like your flyback is bad (around 70.00 for part) they will get you in labor costs
Posted on Dec 07, 2008
I bought a replacement remote for Toshiba TV and it was the same model number CT-90325 same as the original. but it won't operate the TV, does it have to be programmed to the TV somehow?
Sounds like the manufacturer did an upgrade. You can look up the remote control codes for that TV. Turn the TV power on. Then using the codes you found set each one into the remote you have and check the functioning by trying to turn the TV off. If you are unable to see instructions for setting the codes into your new remote, or if they weren't supplied by the seller, you'll have to find it's manual online and follow those instructions. It could be that Toshiba used the same control model for more than one TV set model. Often just putting in batteries will work but when it doesn't you have to treat the remote as a universal remote. If you can't use the primary unit setting to work you can try to set it up as an"AUX" unit as you would do for a second TV.
Dec 20, 2016 | Televison & Video
I have a samsung tv i am trying to trying to program for this jvc remote. Could you give me some instructions?
Hi wnowens, to program your tv to that remote follow these 3 easy steps.
Samsung code = 12
1 Holding down TV/VIDEO, enter the code "1 2" by using the numeric buttons (0 - 9).Do not release TV/VIDEO. Keep holding it until the next step is completed.
2 Press STOP button while holding down TV/VIDEO.
3 Now try to operate your TV by pressing DVD POWER - TV POWER while holding SHIFT.
If your TV turns on or off, you have successfully set the control signal.
If you want a PDF copy of the user manual click HERE to download it.
Hope this helps enjoy : )
Feb 11, 2011 | JVC Rm-sxv521j Remote Control
How do i program tv aND DIRECT TV BOX FROM SCRATCH?
You need to turn on your television set.
  • On your DirecTV remote, press the "TV" button once.
  • Now, press and hold the "Setup" button until the "TV" light goes off.
  • Enter "991" on your remote control, using the numeric keypad. The "TV" light on the remote should blink twice.
  • Aim your remote at the television and slowly alternate between pressing "TV and "Power" on your remote, until the television set turns off. Once it turns off, press "Setup" on your remote control to lock in the code.
  • To search for codes for other devices and program them into your remote, repeat Steps 1 to 5, but use the appropriate key for your device instead of "TV."
  • Feb 04, 2011 | RCA RCR311B Remote Control
    Will not power on. Takes numerous tries till you here the fans and it will power on.
    If the tv wont turn on then it has a power issue. Try to use the remote. if same, then unplug tv for 1 min. plug it back in to a known working outlet. service may be required if the same. visit eservice.sony.com to get service options for your tv
    Dec 20, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
    Power button has to be pushed 5 or 6 time before TV will turn on.
    Hello; I don't know if you are using the power button on the remote or the TV. If it's the remote button you are using, try the one on the set. If the set button turns it on 1st try, you have a bad remote. These buttons do wear out. If the set takes 5 to 6 tries on either, you likely have a bad main board in the set. John
    Dec 17, 2010 | Emerson LC320EM8 32 in. LCD TV
    After turning on Samsung TV with Logitech 890, the tv does not right away. I hear the tv trying to turn on but it takes about 30 seconds to do so.emote
    This may not be a remote control problem. try turning on the tv directly from the tv and see if it takes longer than normal to power on. Sounds like a problem with the tv.
    Dec 08, 2010 | Logitech Harmony 890 LCD Remote Control
    The remote doesnt work and a universal one will not work for this tv to watch video or play games
    Your set needs the following numered remote control to fuction it properly. Try to get it from somewhere and try.
    Remote cONTROL Number : TOSHIBA CT-9914
    Oct 13, 2010 | Sansui DTV2760 27" TV
    Need Dish DVR ViP722 remote code.
    If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
    Feb 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
    Sharper image universal remote
    1) Turn on TV;
    2) Press TV on the remote control;
    3) Press and hold SETUP, until the red LED indicator blinks twice;
    4) Enter 9-9-1-1 on the numeric keypad;
    5) Press POWER on the remote;
    6) If the TV doesn't respond, repeat #3, #4, #5.
    Feb 17, 2008 | Televison & Video
    Sony TV power and volume not working
    Since remote does not work, try taking out batt and turning on by set. See if still turns up. It could be that the up button is jammed inside set. Does everything else works? See if you can go to menu and turn speakers off, this will allow you to work on set and not worry about noise.
    Sep 04, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
    Televison & Video Logo
    24 people viewed this question
    Top Televison & Video Experts
