Question about Eureka 4874 Bagged Upright Vacuum
There is no suction when the Eureka model 7685 is turned on. Is there an Air filter? If so, where is it located? The belt turns slowly when the vacuum is turned on. Is that normal?
    Sergeant:
  • 229 Answers
No you vacuum tub is clogged. Shut off machine and remove hose where attachments go. Use a long handled kitchen appliance like a spaghetti stir to work the jam back and forth. You will be amazed at what comes out. Then remove string etc from the brush assy on each side so it can move fast again. You'd be surprised at how many of these calls I get and they can be fixed at home!!! Good Luck Matie!
Posted on Dec 07, 2008
I have a Eureka Contour model 2900 type A upright vacuum, the roller works fine nothing clogged, took it apart motor blade is free of debris, no suction from tube and blasts OUT air from the front HEPA...
Even with your explanation,it seems the hose is clogged.Try taking the hose off,then blow through it or pour water through it.If this doesn't do it,make sure the suction canals are going to the proper areas.
Apr 04, 2012 | Eureka 2900A / 2901A Contour Bagged...
My roller brush isn't turning. I've replaced the belt even though it didn't need to be changed. It still is not working. I have suction. I have cleaned all the filters. This vacuum is 3 years old and used...
Make sure that the brush is turning freely and that there is no thread or lint preventing it from turning. Do not run the motor in this condition, you will burn the belt out.
Feb 03, 2011 | Eureka Altima Upright Vacuum Model 2996AVS...
Does not suction/pick up trash and debris.
we have an eureka 4495 model and it doesnt want to pick up the dirt off the floor but the hoses are clean and the hose it self has suction and the roller and belt are ok and turn
Feb 02, 2011 | Eureka True Clean Upright Vacuum (Yellow)...
My eureka vacuum won't suction and starts to smoke when I try to use it. It sounds like it is suctioning when I first turn it on, but after about 20 seconds it begins to smell like burning and does not...
The problem is that your belt is stretched and worn. This causes that burning smell and it also causes the vacuum to not pick up well. You need to replace the belt. Here is the belt you need and the manual with instructions:
Eureka Altima Belt and Manual
Jan 31, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
The spinner bush turns really slowly. It doesn't
u need to get a new belt. a local hardware store or walmart carries it. also u need to take the vacum apart further so u can clean out where the motor spins u will get much bettter results
Oct 06, 2009 | Eureka Vacuums
Eureka Optima vacuum has suction at the hose but not at the floor. I took out the filter and it still isn't suctioning so I don't think it is the filter.
it sounds like you have a plug. check where the hose goes into the back of vac. it should have a clip remove this and see if there is a plug there
May 18, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Motor runs fine and hosed not clogged will not pickup dirt
Check your fan for damaged or worn blades, then following the flow towards the bag check for blockage. Does your bag inflate when the vacuum is on? If so, it is less likely that you have blockage, than it is that there is an issue with the fan.
Jan 19, 2009 | Eureka Vacuums
Vacume cleaner
Check the hose and see if it has a clog, also the hose at the bottom. The filters may be clogged, make sure they are clean and that air flows thru them, if not then replace them.
Dec 09, 2007 | Eureka 5892AVZ Bagless Upright Cyclonic...
Eureka 4874 Bagged Upright Vacuum Logo
74 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
