Question about Maytag Neptune MDE5500AY Electric Dryer
My neptune mce8000ayw will start squeaking
After 15 minutes or so it will squeak and get louder the more it runs. I can spin the drum before ever starting it and it is quiet but it will squeak as I turn it after running. The glides look good. The belt was flipped so the smooth part was on the pully and drum. I switched this but no help. I saw that someone said it was the roller but wouldn't it squeak all the time if it was the roller? Some one said to pull off the back cover to get to it but the back doesn't come off. The drum has to come off before accessing the belt. what is the best way to put the belt back on if it or the roller/pully is bad? Thanks.
shaggyrat
  • 1224 Answers
SOURCE: Neptune MDE4000Ayw squeaking when running
if its squeaking it means that in wants to be grease or lubed
all mechanical devices need some form of maintence to run properly lube the motor the drum the track wheels but not with wd40 use appliance lubericant or call your local maytag man to come out and do routine maintenance on your neptune
also to the guru if there was a foreign object stuck between drum and body it would be like throwing a monkey wrench into a clock towers gears it would slam to a hault so i dont believe in the object stuck theory
Posted on Jun 05, 2008
abhishek33
  • 1239 Answers
SOURCE: Maytag Neptune Dryer Model # MDE3000AYW
Motor malfunctions usually call for service by a professional. There are three main causes of motor failure: lack of lubrication, a defective motor switch, or worn or frozen bearings. A humming sound can be related to a burned-out motor or a defective switch. Check these trouble spots before you call a professional service person or take the motor to a repair shop. Here's how to check a dryer motor:
Step 1: Remove the back access panel. Then reach behind the drum, motor pulley, and idler arm pulley. If these areas are clogged with dirt and lint, undue strain on the motor may be causing the humming noise. Worn or broken belts can also cause a humming noise. Check the belts for wear and damage. If the belts look all right, you may be able to stop the noise by spraying them with fan belt dressing, available at automotive and hardware stores and home centers.
Step 2: Turn the dryer on. The noise you hear may be the whirl of the spinning drum, not the motor. Some noise is normal.
Step 3: Force a little 20-weight nondetergent motor oil (not all-purpose oil) around the ends of the motor shaft. This lubrication may stop the humming noise. If this doesn't solve the problem, remove the motor and take it to a professional service person.The centrifugal switch on the dryer motor may be located on top of the motor. Humming, no motor power, and no heat can be caused by a faulty centrifugal switch. If the switch is externally mounted, check the terminals of the switch to make sure they are tight and not burned. If you spot trouble, remove the switch and take it to a professional service person for testing. A faulty switch will probably have to be replaced. Some centrifugal switches are located inside the motor housing; you won't be able to remove the switch in this case. Remove the entire motor and take it to a professional for repairs.
If the motor hums, but won't run the pulley on the end of the motor shaft, try turning the pulley by hand.Caution: Before turning the pulley, make sure the power to the dryer is turned off.
Posted on Sep 12, 2008
SOURCE: Maytag dryer squeaks during cycle
How do you replace the glides/slides? I have a Maytag dryer that's squeaking, took off front and it's clear it's the glides. Found where to buy them just need directions for replacing. Anyone know how?
To change the glides you have someone lift the drum--after taking off the front panel--and pull out the glides. We bought the glides locally and just ordered on line the felt pads that go under the glides, as one was missing. So I haven't actually completed the project but should easily be able to once the felt pads arrive.
Posted on Mar 24, 2009
protek480
  • 1723 Answers
SOURCE: How do you remove the bottom cabinet of a Maytag Neptune Dryer
OR..... you could watch the video...
Posted on Aug 07, 2009
localwonder
  • 6784 Answers
SOURCE: maytag neptune dryer makes a loud squeaking noise
This noise will normally come from a defective idler pulley. Access to the idler pulley varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
When reaching into the dryer be careful of sharp edges on the cabinet and interior supports. Reach in to the belt and give it tug. It should be taught and have only a little give. The belt should go under the idler pulley and over the motor pulley. Lift the idler pulley toward the motor to relieve tension on the belt and remove it from the motor pulley.
Turn the idler pulley wheel, it should turn smoothly, quietly and without any wobble. Inspect it for cracks or uneven wear. If the idler pulley does not maintain proper tension or is damaged it should be replaced. Depending upon your model, the entire assembly or just the wheel or bearing may be replaced. Check the bearings as well for excessive clearance also(roller bearings)
Posted on Sep 29, 2009
Drum squeaks on rotation. can drum be lubed?
would not lube the drum but the two small wheels that the drum rotates on sometimes their "axles" get dry and rusty and will squeak. Put some antisieze on them and see if the noise goes away.
Mar 16, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
Dryer sqeaks while it's running
This could be the result of a loose/worn belt, or worn drum roller bearings. Is it a constant squeal or a squeak......squeak.........squeak, basically in time with the RPM of the drum? If that is the case, get new drum bearings. If the former is the case, get a new belt.
May 24, 2011 | Maytag Neptune MDE5500AY Electric Dryer
The dryer squeaks - noise is coming from left hand front of dryer. I've take the cover off, there is a plastic piece that if I press toward the front of the dryer stops the squeak. The heavier the...
The squeak is actually the rear bearing WE3X75.
98fbf6b.jpegOddly enough although this might be your part you should use your model number to order the part. Different production runs I guess. Theis dude mounts in the rear
66ec823.jpgright in the center of the heater. This bearing gets real thin and when almost gone starts the squeal. You must remove the drum to get to the backside and replace that dude. I have a pictorial and more HERE.
Oct 12, 2010 | GE DBXR463GB Gas Dryer
Dryer squeaks when it runs
Do Not Use oil.
Replace the drum rollers,clean the belt tension roller and the front drum glides.
Repeat...No Oil.
Jul 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Loud squeaky noise when dryer starts, noise stops after several minutes
I would replace the belt that turns the drum. It is probably wearing out and that is causing your noise.
Jul 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Gradual squeaking increase
Check the drum's roller bearings - they sometimes look like large rollerblade wheels. The may need to be replaced. They are relatively inexpensive, and can usually be found at your local appliance parts store.
Too, check for a  felt "ring" around the front of drum (if applicable). Again, if too worn, replace it.
Jul 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Squeak in Kenmore HE 2plus front load washer when drum spins
Squeaking noises are hard to find unless u open it and pin point where its coming from.. you can open the back cover if you are comfortable doing so.. let it run to see if you can heard... sometimes the bolt holding the pulley to the drum is loose and need to be tighten. Other possible is the shocks came loose or when install new.. the shipping materials were not remove..
Dec 13, 2008 | Kenmore Elite 45986 Front Load Washer
Makes loud squeaking noise, cuts off after a few minutes
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
