Question about Panasonic SC-PT960 Theater System with Wireless Speakers
Wireless speakers for Panasonic Sc Pt-960 will not work!
The light on the wireless reciever blinks from red to green, the w1 flashes on the dvd box. I have everything hooked up correctly, and the sound is great from the front and center speakers but I can not get any sound our of the wireless speakers. When I turn on the wireless box it sounds as if the speakers come on then shut right back off and then the light starts to flash. Is this a problem I can fix? If so, how? Or is it a problem with the system itself and it needs to be returned?
  • 4,472 Answers
How long have you owned the unit? It sounds like an internal problem with the wireless transmitter/reciever. If the system is under a year old it is still covered under the manufacturer warranty. Follow this link to locate the nearest authorized service center.
http://www.pstc.panasonic.com/WhereTo/FindServicer.asp?Pass=1
Please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
Posted on Dec 07, 2008
  • Lee A.
    Lee A. Dec 07, 2008
    No sound.
    ≥Ensure that the digital transmitter is fully inserted into the slot of the main unit.
    ≥Ensure that the wireless system is plugged into the AC outlet and is turned on. Ensure “ [W1] ” is
    displayed on the main unit’s display.
    The indicator on the wireless
    system keeps flashing between
    red and green.
    ≥ There is a power supply problem. Consult the dealer.
    That is all you really can do other then that get it serviced by the nearest authorized service center.
    Thanks again and good luck,
    Lee
    Guru:
  • 558 Answers
Thanks for using FixYa.
Please adjust the distance of the Reciever and the Wireless speaker. Any obstacle in the way can cause this type of problem.
Thanks, Scott
Wirless speakers are conntected no sound
you sound like an idiot. please stop talking and call in the big boys to fix your problem.
Jul 14, 2012 | Panasonic SC-PT960 Theater System with...
I have SC-PT750 Wireless system with SH-FX65T and SE-FX65, the wireless does not work and the screen flashes W1 to W2 and the SE-FX65 red light stays on
1 Turn on SE-FX65 2 While pressing [>>/>>'] ] press the numbered button [3] on the remote control until "P" lights in the home theater unit's display The indicator on SE-FX65 turns green. 3 While "P" is displayed, press [I/D SET] 4While pressing [>>/>>'} press the numbered button [3] on the remote control.
This worked for me. I moved and lost the FX65A, and Had to buy a replacement off ebay,
Used this manual http://www.specsserver.com/CACHE/FRQUJVMNXTYS.PDF but I have to give mosyzlak props, cause he gave me the idea to look for it.
Nov 28, 2010 | Panasonic Home Theater System System
Wireless digital transmitter doesn't work
I'm having this same problem; it worked all ok in the beginning then one day it didn't and no matter what I try it doesn't seem to connect. Similarly im getting the W1 flashing and even when I take the receiver and move it closer (even within a few feet) it still wont pick it up. I've removed the wireless home phone and baby monitor from within the room without any result. I cannot think of anything else that could be interfering. Any advice or resolution would be much appreciated.
Oct 06, 2009 | Panasonic Audio Players & Recorders
SA-PT750 rear wireless speakers don't work
Just solved this one thanks to another posting on this site.
Turn all components off.
Check to make sure your wireless card is snugly plugged into the back of the home theatre unit. (Of course you already have. Check again, though, while everything is off.)
Turn wireless unit on first.
Turn on home theatre unit.
The W1 light should be on and blinking red at you (darnit!)
Here's the magic.
Hit the >>/>> button on the front of the home theatre unit WHILE you hit the number 3 on your Panasonic remote.
The screen changes to a P
Then, the wireless unit light should change from red to green (HOORRAAYYYYY!)
If you have multiple wireless units, at this point, you should also hit the Set/ID button on the back of the wireless unit (it is the kind of button that requires something to poke into it to set it).
Then simply hit the >>/>> and 3 at the same time again.
All's good.
And by the way, shame on Panasonic. not only do they not seem to carry these manuals anymore (how hard would it be to have a PDF file and a link on a web page?) but the support info they did have did not contain these steps. Thanks to the FixYa member willray411 for posting this first!
Mar 29, 2009 | Panasonic Audio Players & Recorders
SC-BT !00 Panasonic wireless speaker connection won't link
If you go into the set up menu and go to the speakers set up - it only shows the right, left, centre and subwoofer on the screen. You need to go down to the box below these speakers and activate the rear speakers which are not shown. The wireless section will then light up w1/2 on the display at the front of the scbt100 - i had to call panasonic to figure this out and they advised me it was missing from the instructions!!!
Feb 23, 2009 | Panasonic SC-BT100 Theater System
My wireless speakers are not working i don't know why
After some research i came with the solution!!! First Turn off the home theater and turn it on again,lower the volume completely. Then on the dvd unit press the fast forward key>>>> while at the same time you press the number 3 on the remote control. A letter p is going to show oh the display. When this is happening there is a small button on the receiver on the back, you might need a thin object to reach the botton and press it. Press it once and the light will change from red to green. To finish up repeat the fast forwar>>>> key on the unit while pressing #3 on the controller and boom!!!!! the w1 will stop flashing and your surround speakers are rocking!!!!! enjoy it!!!!!!
Dec 13, 2008 | Panasonic SC-PT960 Theater System with...
Panasonic SC-PT950 Wireless Speakers Question
It is pairing process again.
Inside the Main set operating instruction can help you solve it.
Aug 13, 2008 | Panasonic Home Theater System System
Panasonic wireless speakers
did you play with the settings on the remote? turn the pro logic on.
Aug 08, 2008 | Panasonic SC-PT960 Theater System with...
My panasonic wireless surround sound won't work out of the Rear speakers
I have finally got my rear speakers to work. wireless internet or cordless phones will stop the speakers from working, i switched off my wireless internet and hey presto speakers work fine, i just cant have both at the same time.
Jan 20, 2007 | Panasonic DMR-E50 DVD Recorder
Panasonic SC-PT960 Theater System with Wireless Speakers Logo
195 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
