Question about Teac AG-370 Receiver
TEAC AG-370 STEREO RECEIVER There is no sound when I connect the speakers Speakers test out fine
5 Suggested Answers
SOURCE: Teac AG V8050
try using an antenna.
Posted on Jan 31, 2008
  • 4234 Answers
SOURCE: Receiver keeps flashing "PROTECT"
The protect message indicates that a problem was detected in the last stage of the amplifier and that it has shutdown to prevent further damage. Usually this indicates that the output transistors have failed. Any shop that works on audio should be able to repair this. Expect a part cost in the $20-$40 range. Add in the local labor rate for the total repair cost.
Dan
Posted on Dec 17, 2008
SOURCE: Teac AG-V8525 Stopped producing sound. Has legend says "protect"
hit reset button back of receiver
Posted on Dec 02, 2009
SOURCE: Teac AG-V8520
same problem exactly
Posted on May 31, 2010
Why does my Teac ag h500 keep saying protect?
Hi. Unfortunately the protection circuit is saving your speakers from a fault, most likely one side of the amplifier in the unit is defective.
This needs an engineer.
Service manual is here if you need it. TEAC AG H500 Manual AM FM Stereo Receiver HiFi Engine
Oct 02, 2016 | Teac Audio Players & Recorders
Can I connect an active speaker to the Teac AG d7900 output
http://produto.mercadolivre.com.br/MLB-184407791-av-digital-home-theater-receiver-teac-ag-d7900-_JM
It would have helped to know something morwe about the 'active' speaker.I imagine its manual would tell you what it needs for input.
Active speakers are usually designed to be driven by volume-controlled Line Level inputs. This receiver has none except for the Subwoofer PRE Output.
Aug 17, 2011 | Teac AG-D7900 Receiver
MY Teac AG-370 reciever only plays one speaker , I know the speakers are good ,I checked them , what other things can I check?
If you've already swapped them left to right to prove the speaker works bt the channel doesn't then you know the problem is in the electronics. Is it one or more sources? Turn the receiver off and manually operate all the switches and knobs throughtout their ranges (particularly the Tape controls) and see if that helps. No? Take it to someone to look at it.
Dec 28, 2010 | Teac AG-370 Receiver
Surround Sound won't go on. Connected and setup all speakers. Did the speakers test. And playing a DVD surround sound won't go on.
You don't say what the DVD model is and how it's connected. What DOES work? Is surround not working for other sources, too? Have you connected the DVD player to other inputs to see if the problem is in it or the receiver? Is the digital input on the receiver assigned to the DVD player? You have some homework to do.
Jan 19, 2010 | Teac AG-D8900 Receiver
I cant get the speakers to work the speakers have wire does the wire with the white stripe go in red or black?
well on the back of the receiver it should say whether or not the wire you plugged in is positive or negative, all you do from there is match positive to positive and negative to negative (red is positive)
Oct 11, 2009 | Teac AG-370 Receiver
Teac AG-V8520
Oct 13, 2008 | Teac AG-V8060 Receiver
Connecting An Equalizer
you will need 6 equalizers or 3 stereo equalizers.
connect the 5.1 analogue outputs of your media player (DVD Player) to the equalizer and then connect the analogue output of the equalizer to the AVR.
now you can equaize the sound for extra boost and cut.
Warning: it is not recomended to do so unless you have a powerful amp and high quality and higher wattage speakers, as equalizers are ment to be used mainly for entertianment zones and outdoors in professional applications.
the home speakers annd electronics are not really capable of taking such electronic stress as they are designed to work indoors in a confined space.
but if you are confident go ahed.
Jan 21, 2008 | Teac AG-D8900 Receiver
Teac AG V8050
Dec 09, 2007 | Teac AG-V8600
Teac AG-370 Receiver Logo
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
