Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Sony Grand Wega 55" LCD ml # KDF-55WF655 goes protective shutdown
The TV is around 3 1/2 years old. When we turn the TV on the green light will flash 11 times, picture will come on and color is normal for about 45 seconds to 1 minute. Then the picture and sound go away and the green light will flash 37 times before the picture and sound come back on. This will do on for the duration the power is on. The lamp light (red) has not came on to indicate the bulb has completly gone. From reading this thread for similar problems it seems like this could be the thermal fuse or just the bulb needs replacement, but I'm not sure. Also it seems as though the fans DO NOT come on when the power is turned on ( they normally spool up loud enough to hear). I have cleaned the back of the TV for any dust that may have "clogged" the ventilation. Any help would be greatly appreciated as I would like to do this repair myself. Thanks
  • isitthachad Dec 09, 2008
    Thanks, I'll try the replacement. So the cooling fans not running is part of the lamp going bad?
  • 505 Answers
The fans should run as the tv is trying to come on. they may click off for a minute in the reboot cycle, but should run. if they stop when the set is working, you will get a 4 red blink fan error. the fans have a feedback to let the tv know how fast they're spinning. if they're off and the tv is on, it may be cool enough to not need them yet, but typically they run all the time.
Posted on Dec 09, 2008
  • 505 Answers
This is the lamp going bad. For some reason, it doesn't spit out that lamp error, it just keeps refiring the lamp and it just cycles forever. When the lamp totally fails, you will get the lamp led lit. Replace the lamp to resolve.
Posted on Dec 07, 2008
My sony grand wega 55 constantly will turn off picture and sound, green lamp light stays green and then after about 30 seconds the picture and sound return, it has the original bulb in the tv and is around...
The LED light "LAMP" indication stay on or flashes in this problems?Yes,the projection lamp is the causes and problems.Change the projection lamp,should solved the problems.
Jan 30, 2011 | Sony KDF-E55A20 55 in. LCD Television
I turn on my KDF-55WF655 Sony TV. The green power light flashes about 10 seconds and then the picture fades in to full intensity for about 305 seconds then goes blank. The green power led flashes about...
If lamp has not been replaced in tv in last 2-3 years, then replace the lamp as symptom shows that lamp has reached to end of its working life span and causing that problem.
Lamp is not dead or broke but weak so you get above said problem in tv.
Thanks.
Oct 05, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Thanks.
Apr 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
TV repeatedly goes into standby mode and then comes back on
Resolder Horizontal section & SMPS Power Supply with Soldering Iron
Jan 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Picture will come on and then go off after a couple minutes
This usually means the Lamp is failing. Replacing the Lamp usually fixes it. I would only use a Sony Replacement.
You can order one from Sony at 1800-222-SONY or you may be able to pick one up from a local Sony Retailer.
Skyassoc
Nov 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
SONY WEGA 55 INCh
maybe you should change the light bulb
Jun 14, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Flashing green light no picture
The bulb was loose, pulled it out, put it bakc in and tightened the screww. Works like a champ
Mar 06, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony TV Screen
Is you model listed below?
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Dec 13, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
237 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
