Question about Whirlpool GSW9800PW Washer
Machine hums Machine fills but just humswhen it goes to agitate or spin. Will continue humming untill limit kicks out. No smell. Motor or gearbox?
    Problem Solver:
  • 5 Answers
There is a coupling between the motor and the gearbox that has probably broken. It is two pieces of rubber that fit together like a puzzle. It acts like a weak link to protect the far more expensive components. Check under the machine for some fine black shavings in a little pile at about the middle of the machine.
Posted on Apr 11, 2007
Washing machine fills and agitates but won't spin or drain, just hums.
When the machine beeps it is giving you a code with the 8 wash progress lights along the top. Some will be on some will be off. With OFF = Zero and On = 1 Can you give me the 8 digit code. An example is (01001001) It is normal for the pump motor to get very very warm. Make sure you can spin the pump impeller easily.
Aug 09, 2014 | Fisher Paykel EcoSmart GWL15
Top load frigidaire washer will not spin, it agitates, it drains
You need to replace the starter cap on the motor this is why it will not turn and the smell is the cap that's not starting the motor it also will hum.
Dec 29, 2013 | Frigidaire FFLE2022MW Electric...
My Kenmore washer (series 90) stopped working in between the rinse and spin cycles. It will not drain (half full as we speak), agitate or spin. It will fill with water but once it reaches the proper water...
Something stuck in Pump. Pump on your model is driven by washer motor, so if Pump can't turn, motor can't work and will hum until it overheats and shuts down.
Sep 28, 2017 | Washing Machines
Washing machine filled but wont agitate after the fill,it humms
Maybe the agitator isnt agitated enough.....yell at it for a bit...see what happens....if it that dont make it spin poor a lil rum in the tub....
Mar 01, 2010 | Whirlpool Washing Machines
No spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Jul 08, 2009 | GE Washing Machines
Intermittent agitation and spin, mostly just hums, burning smell after replacing drive coupling
sound as if the motor or someting else is sticking release the belt on the motor. check belt for damage. check motor by turning it by hand to see if it is free.
May 12, 2009 | Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Hotpoint washer
Your machine has multiple issues. First, the obvious: are the water lines turned on? When you try to fill it with water, can you hear the water valve humming? Try different temperatures, too. If it lets one temp in, but not the other, you need a water valve. If it doesn't hum at all, you could have a problem with the pressure switch or the timer.
The motor humming is the issue that worries me. Try removing the belt from the motor pulley. If the motor turns now, it's a transmission problem. If it won't agitate (you'll have to satisfy the pressure switch first) or spin at all, your transmission could be locked up. I've had limited success by pulling on the belt (hard) in both directions. This has only worked once to unjam the transmission.
Mar 01, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 110 Series will not agitate, spin or drain but will fill
you may find that the motor is not going because of faulty capacitor or faulty timer
remove the motor from machine and try running with no loadif it works them maybe the pump is jammed or worse still gearbox is faulty
Jan 28, 2008 | Kenmore 15864/15862 Top Load Washer
Whirlpool GSW9800PW Washer Logo
80 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
