Williams-Sonoma Stick Blender Handheld
Problem for Williams-Sonoma Stick Blender Handheld
What if my Blender is leaking?
By Grant - usenet poster
Same Problem
Jan 27, 2009
-   Bottom of blender leaks.-   ljbrinkmann
Dec 12, 2008
-   My blender part is leaking will not hold any liquid.
-   towthis1
Aug 26, 2008
-   My blender is leaking and I can'at figure out how to fix it or get a replacement. Can someone help?-   stone976
Aug 17, 2008
-   blender is leaking
-   Guest
Jun 26, 2008
-   My blender leaks and I need to know how to replace the cutter blades - I can't get the nut loose. Help.-   Guest
Best Solution
posted on Jan 01, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
1) Wet the seal between the blender body and base BEFORE attaching them together. Seal snugly.
2) If the leak is from the blade/center shaft assembly, consider a new blender. The price of parts to repair a shaft leak is not cost effective except on the most high-end units.
Solution #2
posted on Jan 19, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Check the rubber bad seal around the bottom, they get chopped many times when using it, which can ruin your blender if you are not careful.
Solution #3
posted on Aug 08, 2005
Somewhat Helpful)
Bomber
Rank: Apprentice
Rating: 0%, 0 votes
During routine operation, 10 drops per minute is considered normal.
Was this helpful?
Yes
No
Solution #4
posted on Jun 16, 2008
Not Rated)
fossilruins
Rank: Guru
Rating: 89%, 106 votes
If the blender is leaking at the base, the seal is probably missing or the blade base needs to be replaced.
Here is the website to see about replacement parts and also contact info:
http://www.focuselectrics.com/catalog.cfm?dest=dir&linkid=82&linkon=category
Was this helpful?
Yes
No
Solution #5
posted on Jun 18, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
replacement of plastic base - cracked
Popular Solutions for Williams-Sonoma Stick Blender
Questions and Unsolved Problems for Williams-Sonoma Stick Blender
Do you recommend Williams-Sonoma Stick Blender Handheld?
Answer
Answer
I need to replace the coupling drive base on a kitchenaide 5 speed blender, model no. ksb5wh4
Answer
My William Sonoma Stick Blender runs, but the blade does not spin. Any ideas?
Answer
I bought a brand new one at a thrift store and when I got it home, I realized why it was such a... (More)
Answer
I lost the blending tools for my william sonoma magic wand. Where can I buy more.
9 Other Users Have The Same Problem - Continued
Comment by kitt48, posted on Jun 24, 2008
How do you remove the nut connected to cutter blade without damge?
Comment by Guest, posted on Mar 06, 2008
The company that bought the company that made the blender express said they were sending a new gasket months ago; however, I never received it and dont remember the company's contact info.
Comment by windchime, posted on Feb 12, 2008
My blender leaks a dark fluid that sprays onto the underside of the plastic jar where it fits over the blender base.
Comment by bcomplex, posted on Nov 25, 2007
Back to Basics Pro 600 Smoothie maker leaks ALOT more than 10 drops, the spout leaks as if it does not close all the way even though it appears to. This is my 3rd one and it leaks the most even on the first use. Is there anything to screw on to do away with the pour spout?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Williams-Sonoma Stick Blender...:
Top Blender Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Blender Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
