Question about Nintendo Wii Console
The wiimote keeps cutting off on me and the battery is fully charged. so what do I need to do?
    Sergeant:
    Novelist:
  • 192 Answers
Hi there. I had the same problem. I found that one of the battery springs had come loose and needed re-soldering. Open the back of the WiiMote and have a look, just in case
Posted on Dec 07, 2008
My phone keeps cutting on and off
You need to replace the battery, and charge it fully when it is new.
Nov 17, 2013 | Samsung Galaxy Cell Phones
Cursor on wii control hand held won't show up on tv screen
Make sure your batteries are new or fully charged if you have rechargeable batteries in. I would re-synchronize the wiimote, by opening the face flap down on the front of the Wii, pressing the red button to start synchronization while the wii is on, and then the red sync button on the back of the Wiimote where the batteries are. If this does not work, it probably means that the cable that connects the sensor bar to the Wii has been cut by either a cat or a child, which happens often to these thin guaged wires. All you have to do if that is true, is make it a clean cut on both ends, then melt away about 1/4 inch of the insulation with a flame and pull it off with your fingernails, keeping the exposed wire. Do this on both ends and re-connect them and use black electrical tape to insulate each wire first, then the both together to enforce strength. If this doesn't work just switch the two wires you just connected and it should. Re-synchronize after doing so.
Nov 24, 2011 | Nintendo Wii Remote Controller
My wii remote would not work so i bought a new wii wireless sensor and it still does not work can you help please
Have you checked the battery in your Wiimote? It seems like a very basic thing to do, but sometimes the wiimote might not hold a charge if you placed the batteries in incorrectly. If your Wiimote is showing a charge, then you may have forgotten to sync up your wiimote with your sensor bar.
  1. Open the battery door to your Wiimote
  2. You'll see a red button on the bottom of the opened hatch, it says SYNC.
  3. Press that and the sync button on your Wii.
If that still doesn't work, check the connection of your wii sensor cable to your wii. Try pushing the cable in securely.
Mar 08, 2011 | Nintendo Wii Console
Wii remotes will not connect
Have you tried synching the Wiimotes to the system? To do that, just remove the battery cover on the Wiimote, hold down the red button, and hold down the red button on the front of the Wii itself. (under the disc drive, covered by a flap)
Then press 1 and 2 together on your remotes in the order you want them to be assigned.
Nov 28, 2009 | Nintendo Wii Console
Engine on the aerobird swift plane keeps cutting out
the battery pack needs to be fully charged, it may take charging it 5 to 10 times in order to achieve this.keep an eye on it while charging and when warm to touch it should be charged.
Aug 18, 2009 | Hobby Zone Aerobird 3
Can't get 2nd player working on Indiana Jones Lego Wii game
The thing to get the two Wiimotes to work is to press the reset button on the Wii and on all the Wiimotes at the ame time. If you after that restart the Wii, it should automatically connect to both Wiimotes when you press A on them. If you then luanch the game, the two Wiimotes should still be connected. If not, just press A again. Then press whatever button you ned for multiplayer (+ I believe) and you shold now have 2 players. I hopethis helps, Yannick.
Jun 10, 2009 | LucasArts Entertainment Company Lego...
Wii remotes have stpped sending signals.
When you first press a button on the Wiimote, how many lights blink? If the answer is 1, then your batteries may be too low. 4 blinking lights mean that you have fully charged batteries.
Other than that, you may want to consult the user manual with regards to re-syncronizing your Wiimote to the console. If you don't have the manual any more, and you have at least two blinky lights, then press the red syncronizing button on the console first, then the corresponding button inside the battery cover on your Wiimote. Reboot the Wii and see if it works.
Mar 22, 2009 | Nintendo Wii Remote Controller
Cannot get the gun sights to move in wii play
Ensure that your not too close and not too far from your TV, and make sure that your sensor bar is properly set atop (or below) the screen.
Aiming takes a minimal amount of movement once you get your cursor on the screen. Big motions are not necessary to move your sights around the screen - just little movements with the wrist. Once you find that sweet spot, you should get good experience with the Wiimote.
Finally, make sure the batteries in your sensor bar (if you are NOT using the one that came with your Wii) and the batteries in your remote are fully charged. To know if the batteries in your Wiimote are charged, the first time you press a button on the Wiimote after turning on your Wii, you'll notice that 1 to 4 of the blue LEDs will be blinking. If all four are blinking, the batteries are good. If only one blinks, time to replace them.
**NOTE: If you don't like my advise, that's fine. But please don't rate me a '1' just because my answer doesn't help. That's what 2 diamonds are for. Thanks!
Feb 04, 2009 | Nintendo Wii Play for Wii
Control do not work, but is fully charge
you have to sync the remotes to the wii..in the front part of your wii where the sd card goes push sync open your batterie case and push sync on you wiimote within a 5 sec timespan or so
Jan 08, 2009 | Nintendo Wii Console
Wiimote no power
replace the batteries
Apr 10, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
37 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
