Question about Dell Inspiron 8600 Notebook
USB port malfunction
I keep getting this error regarding my usb port: "A USB device has malfunctioned and exceeded the power limits of its hub port." Problem is that I have nothing in the port. The error message pops up every 15 seconds or so - very annoying. How do I fix this problem???
  • 20 Answers
CHECK THE RATING ON YOUR POWER SUPPLY BECAUSE SOME LAPTOPS WILL REGISTER THE POWER CONNECTION PORT AS A USB PORT AND IF YOUR POWER SUPPLY VOLTAGE IS TO HIGH FOR THE COMPUTER IT WILL REGISTER IT AS SUCH, "HUB-PORT" IS SHORT FOR MAINBOARD PORT ON SOME DELLS. UNPLUG YOUR POWER SUPPLY AND CHECK THE RATING ON IT COMPARED TO THE DELLS INPUT VOLTAGE, THE INFORMATION IS NEXT TO YOUR SERIAL NUMBERS AND LABELS ON BOTH PEICES KEEP ME POSTED... JON-T
Posted on Dec 07, 2008
Apple mobile device usb drivers has malfunctioned and exceed the power limits of its hub port.
ok this is common with usb and high output devices try time machine or using two different ports
Feb 28, 2013 | Computers & Internet
Ewwwwwww... no fun.
You should try a "POWERED"
4 Port USB 3.0 Hub It's important that it's a "POWERED HUB" because you need the HUB to supply it's OWN power and not depend on your Apple E to provide power to your connected USB devices!
The good news is they don't cost much: $8 on eBay
Auction: 202096902632
Note that they include the power supply! Many other HUBS don't.
Your HUB is even LESS if you pick on the USB 2.0. Version, AND YES, each HUB MUST have it's own power supply and that's just what YOU need.
The ONE thing I didn't like about this HUB is the LED lights that are provided for each port! They are TOO bright so I opened it up and plucked all but one LED out. I also bought the 8 and 10 Port HUB versions and 'fixed' them too.
I also didn't need the switches to confuse things (accidentally turn one or more ports OFF)... so my trusty hot glue gun fixed that! All are constant ON now.
Anthony
Black 4 Port USB 3 0 Hub On Off Switches AC Power Adapter Cable For PC...
Oct 27, 2017 | Sony VAIO Computers & Internet
I am trying to upload pictures from my razer phone to my dell latitude d410 laptop and when I plug into to the usb port I get a message saying power surge on hub port...a usb device device has...
Using a different USB port might solve the problem, turn the phone off completely and plug the phone in after doing so turn the phone on if the same problem persists then contact the phone manufacturer and ask if its a common fault
Jun 27, 2011 | Computers & Internet
A usb has exceeded the power limits of its hub port
Simply put its what it says.
you have too many devices drawing power from the USB ports of your laptop.
A fix for this is to use a USB hub but it MUST be one with its own power supply.
Sep 07, 2009 | Microsoft Windows XP Home Edition
Error power surge on hub port
Some USB devices draw too much current from the computer's USB port and you get an exceed power error message.
To get around this problem, get a powered USB hub and connect it to the Computer's USB port and then connect the troublesome USB device into the powered USB hub.
Apr 09, 2009 | Lenovo 3000 N500 Notebook
Power surge on hub port
Try this to find out which one of your components has an issue. Turn off your machine then unplug all of your USB cables. Turn your machine back on and plug in one of your USB cables. Verify the component you just plugged in works correctly and if it does plug in another cable and verify that component is working. Continue these steps until you have the one component that displays the error you have seen. That component is most likely the cause of your issue and should be replaced.
Good luck, Greased.
Jan 28, 2009 | Dell Dimension 4700C PC Desktop
Maxtor OneTouch lll Mini 120 GB
If your using a USB hub, unplug another device (i.e printer or scanner, fax, etc.). Plug in your One Touch. Then turn off your pc and turn it back on. This should work.
If you use a alot of USB devices, you may need to get a USB Power Hub.
You can try an plug in the One Touch straight to the pc and unpluging all other usb device except the keyboard and mouse.
Let me know if this helps. You also may need to move the ac power to another outlet.
Sep 01, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Power Surge error message
BUDDY FIRST TELL ME TYPE OF USB DEVICE U CONNECTED PREVIOUSLY. THEN COMES SOLUTIONS.
Jan 02, 2008 | Compaq NX6110 TFT XGA Notebook
I guess that this could be your error message:
"Error message when you wake up a Windows XP-based computer from hibernation or from standby: "Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port"
If it is the case, please try below solution:
SYMPTOMS
When you wake up a Microsoft Windows XP-based computer from hibernation or from standby, you may receive the following error message:
Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port. This error message is displayed even if there are no USB devices connected to the computer.   WORKAROUND loadTOCNode(1, 'workaround'); To work around this issue, disable the USB 2.0-enhanced host controller.
Note When you disable the USB 2.0-enhanced host controller, you lose USB 2.0 functionality. That is, you revert to USB 1.1 functionality.
To disable the USB 2.0-enhanced host controller, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. In the Device Manager pane, expand Universal Serial Bus controllers. 4. Right-click the USB 2.0-enhanced host controller, and then click Disable.
Note The name of the USB 2.0-enhanced host controller may vary. 5. When you receive the confirmation message, click Yes. 6.
Close Device Manager.
I hope that this should resolve the issue for you.
Please let me know the result.
you can mail me at thumuvikram@rediffmail.com for any further assistance on this issue.
I'll be glad to help you.
Oct 18, 2007 | IBM ThinkPad T43 Notebook
Dell Inspiron 8600 Notebook Logo
360 people viewed this question
Alun Cox
