Question about Panasonic RF-544 Radio
Bad reception w/ Panasonic RF-544
I live in Arlington, VA, and I use the Panasonic RF-544 (an old radio) in the basement to hear the news and weather. Sometimes reception is good, but usually it is bad, fades in and out, gives out static. When I take the RF-544 upstairs and out of the basement, reception is fine. Question: can I add some type of antenna to this radio that will cure the bad reception in-the-basement problem? (FYI: I just bought a brand new Sony ICF-38, and it brings in the channel----WTOP 103.5 FM----that I want to hear clear as a bell.) Thanks! Tom
I solved the problem, but I did not "fix" the problem. Rather than rig an antenna to the old Panasonic RF-544 radio, I put it upstairs where it has good reception. I put the new Sony ICF-38 downstairs where it brings in the stations I listen to. The advertsizing claim for the Sony ICF-38 is that it has "Good Sound and High Sensitivity." I believe it does have "high sensitivity" because even in the basement it brings in my desired stations. (I am still curious to know if I could have rigged an antenna to the old Panasonic RF-544.) RL
Posted on Dec 08, 2008
Tell me the requirements to guard the Unknown soldier grave site in Washington D.C.
Who guards the Tomb of the Unknown Soldier in Washington DC?
The Tomb of the Unknown Soldier is guarded 24 hours a day, 365 days a year, and in any weather by Tomb Guard sentinels. Sentinels, all volunteers, are considered to be the best of the elite 3rd U.S. Infantry Regiment (The Old Guard), headquartered at Fort Myer, Va.
Arlington National Cemetery > Explore > Changing of the Guard..
or try this link..
requirements to guard the Unknown soldier grave site in Washington Google...
Oct 27, 2017 | The Computers & Internet
Panasonic RX-D10
Wireless devices do use radio frequencies. Have you taken it elsewhere ? This is just a bit of knowledge I found floating around in my head. It could be that the device won;t work work in that area.
Aug 07, 2008 | Panasonic RF-544 Radio
Volume switch on Panasonic radio has scratchy static sounds
Sounds like oxidized contacts.
If volume is a turn-knob, then wiper-track (inside potentiometer) is worn.
If it's a PTM (push-to-make) standard button, the button contacts may be dusty/dirty/oxidized.
Suggest you:
buy a contact cleaner such as Servisol,
open case,
identify controls
and squirt liberally to wash out any gunk.
Move/press/wiggle scratchy one to help 'scrub' the contacts clean.
If this doesn't help try have control replaced.
Oct 11, 2017 | Panasonic Radio Communications
Cant get weather on my motorola MH370CR
Setting the Weather Channel
Your should radio receives weather frequencies if you are close enough to a reporting station:
1. After turning weather reception on, press . The current
Turning Weather Channel Reception On and Off
1. To turn weather reception on, press and hold + (plus) for three
seconds.
2. To turn off, press + or turn the radio off and then back on.
Your radio receives weather frequencies:
1. After turning weather reception on, press MENU . The current
channel flashes.
2. Press + or - to select the appropriate channel with good
reception in your area.
3. Press PTT to save the weather channel setting.
Here's a link to the MH user guide.
Best regards.
http://www.motorolasolutions.com/web/Business/Products/ConsumerTwo-WayRadios/Talkabout-MH230R-Two-Way-Radio/_Documents/MH230.pdf
Feb 02, 2014 | Motorola Radio Communications
Where can I get a replacement antenna?
Radio Shack carries a variety of antenna rods of all shapes and sizes.
Jul 19, 2011 | Panasonic RF-544 Radio
Panasonicgx700 instruction book
I'm glad to provide the Instruction Manual for the Radio. Please click hear to download the Manual.
Please let me know if you require further assistance.
Jul 02, 2011 | Panasonic RF-544 Radio
I can hear people talk but they can't hear me I have a cobra29 nwst what should by settings be at
Set the switches to: 1) S/RF, 2) OFF, 3) CB, 4) HI and 5) NOR. You may change any of these to any desired position except for the CB / PA switch. This switch must remain in the CB position to transmit "over the air" - whereas the PA selection simply sends the audio to the PA jack on the rear of the radio to an external, Public Address speaker and the WX position is to select Weather Band radio reception. It is not possible to transmit on the Weather Band channels.
Choose a channel and set the squelch to MIN and Volume to a comfortable level (you can increase the Squelch slowly just until the speak shuts off if you don't want to hear static sounds). Dynamike and RF Gain both should be set to MAX. Delta tune should normally be left at the mid point. The Dimmer and SWR/CAL knobs should be set to any position you like.
Make sure you have a properly tuned 27 Mhz CB antenna connected to the back of the radio. You should review the Calibrate for SWR procedure in the manual - SWR of 1.5:1 or less are ideal, and those greater than 2:1 are bad. SWR of 2.5:1 and up may damage the radio if left unfixed. Check this list of articles of how to tune a CB antenna if you have more questions about this very important subject.
You should download & review the manual . I hope this helps
Oct 08, 2010 | Cobra GPS
Have cobra 29wxnwst radio. Truck sat for 3 months
Turn up the RF gain all the way and leave it.
RF gain is basically how open your receive is. There is really no reason ever to have it down unless you are trying to hear only close stations to you.
If you RF gain is up, your mic pins my be oxidized, or mic bad.
Try a different mic, and or clean the contacts in the connectors.
Sep 18, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Panasonic RF-544 Radio Logo
466 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
