Question about D-Link DSM-G600 (DSMG600) Network Storage Server
Wlan light not on
This unit has been set up an working fine for years. Today, I lost my wireless network connection. I turned off the D-link device and repowered. But the WLAN light doesn't go on, and no network
Thanks
  • Anonymous Dec 22, 2008
    i have the exact same problem. i have a dsl g604t router and the adsl connection is fine just the wlan light is off and i cant get a connection at all via wireless. i have plugged the router via cat 5 into laptop and it works fine. something is wrong with the wlan? does that mean its time to get a new one?
Try this italian guide for 604/624 models :
http://www.darkshock.altervista.org/forum/viewthread.php?forum_id=25&thread_id=3
Good Luck
Posted on Dec 26, 2008
How to turn ON WLAN?
Here are some essential step that you have to follow.
Connecting to a WLAN
To connect to the WLAN, follow these steps:
1. Be sure that the WLAN device is on (the wireless light is white). If the wireless light is amber, press
the wireless action key (f12).
2. Click the network icon in the notification area, at the far right of the taskbar.
3. Select your WLAN from the list.
4. Click Connect.
If the network is a security-enabled WLAN, you are prompted to enter a network security key, which
is a security code. Enter the code, and then click OK to complete the connection.
NOTE: If no WLANs are listed, you are out of range of a wireless router or access point.
NOTE: If you do not see the network you want to connect to, click Open Network and Sharing
Center, and then click Set up a new connection or network. A list of options is displayed. You
can choose to manually search for and connect to a network or to create a new network connection.
After the connection is made, place the mouse pointer over the network icon in the notification area, at
the far right of the taskbar, to verify the name and status of the connection.
Mar 11, 2012 | Compaq Presario Notebook
The WLAN light will not come on
On most routers, the WLAN light will only light up when a wireless device is connected. If the wireless feature has been disabled, then light will not turn on.
If it WAS working normally and now it is not, AND no one reprogrammed the unit to disable it, then I suggest you perform a factory reset on the unit per the owner's manual here:
http://www.dlink.com/products/default.aspx?pid=DI-624&tab=3
You need to identify the exact version of the model you are running.
Aug 13, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
Dear sir, i can not see the wireless icon on my laptop
do you have the drivers for your wifi card installed properly. if not then go to manufactures website and download driver software for your wifi unit, are you using xp or vista? find device manager and see interfering hardware.
Dec 02, 2010 | Dell Vostro 1500 Notebook
D-Link DWL-G132 just stopped working today, no flashing lights
You can try first connecting this device on different port and check if it will be working but if still not working, the next thing that you can do is to try this on a different computer and if still not working device is already dead...
Oct 09, 2009 | D-Link AirPlus Xtreme G DWL-G132 802.11g/b...
Connection and wireless network with DI-514 disappeared
there is a very small reset button on the unit. Press it and hold it for 5 seconds. This will reset it to the factory specs. Then proceed to set it up like you did when you got it new.
May 27, 2009 | D-Link DI 514 Wireless Router (DI-514)
Need the security code for my network so i can add an other compu
Log into the router's setup page 192.168.0.1
Type in the password, the default password is admin.
Go to wireless Security and you will see your key there.
http://tinyurl.com/phexxc
http://www.ehow.com/how_2091715_obtain-lost-network-key-dlink.html
You can reset the router to default and set a new password and encryption key.
D-Link Router reset
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | D-Link DI 514 Wireless Router (DI-514)
Does my HP s7750 have wireless internet connection. if so how do i turn it on or if not do i need to buy a wireless usb adaptor
check the box that the machine was packed. if you find a antenna, then, your machine have wireless LAN.
to set up the Wireless
1 Click the Windows Start Button on the taskbar.
2 Type Device Manager into the Search box, and then click Device Manager to open
the Device Manager window.
3 Click Network adapters. Your WLAN device should be listed here. The WLAN
device may include the term wireless, wireless LAN, or 802.11.
4 Click the Windows Start Button on the taskbar.
5 Type Network and Sharing Center into the Search box, and then click Network
and Sharing Center
to open the Network and Sharing Center window.
6 Click Add a device to the network and follow any onscreen instructions.
For more information about setting up a wireless network:
 Click the Windows Start Button on the taskbar, click Help and Support, and
then type Setting up a wireless network into the Search Help box.
NOTE: If no WLAN device is listed, either your computer does not have an integrated
WLAN device, or the driver for the device is not properly installed.
Feb 26, 2009 | HP Computers & Internet
Wireless signal offers sometimes & not many times
could be interference but have you tryed to reset the device? your settings will be lost? I supose you use a encryption so your going to have to enter it again to the settings.
Mar 25, 2008 | D-Link AirPlus DI-524 Wireless Router
Vaio wireless lan not working, but Ethernet cable works,
most of the times in your right lower corner there is an icon that looks like two arrows pointing diffrent dirrection....the name of this one is vaio smart utility..let enabled the wlan box and then try to connect it
Dec 31, 2007 | Sony (PCWA-C100) 802.11b Wireless Adapter
D-Link 514 model
the key number will be listed in the router settings as you must have security enabled in the router, if you cannot find it then simply reset the router at the rear of the unit and start again as there will be no security key number and all the settings will be back to factory default.
Oct 23, 2007 | D-Link DI 514 Wireless Router (DI-514)
Open Questions:
D-Link DSM-G600 (DSMG600) Network Storage Server Logo
2,156 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
