Question about LG LRFC25750 Refrigerator French Door
Sears/LG French Door * water leak in door
I have a Sears 795.75192401, made by LG. In the door where the water dispenser is on the inside there is a slow leak at the connection of parts 615A Tank Assembly and 619B Valve Assembly. Is there a simple fix I can do to stop the leak (droplets, not a steady stream) or which of the two parts is most likely the problem?
Thanks!
catriver
  • 878 Answers
SOURCE: Water tank inside fridge for water dispenser leaking
peah, I had a couple of these tanks leak. I think they had an issue with this. The last one I had they had a kit where the substitued coiled tubing with 2 john guest fittings to replace the tank. This solved the problem. The part number I have for the tank is 4838jj1003a, you can get it at http://www3.sears.com/ for 17.95. I don't know if they will send you the tank or kit. You can inquire. Catriver...post back.
Posted on Apr 13, 2007
  • 583 Answers
SOURCE: I have an LG french door fridge and its water flow is very slow
it indicates the problem of a leaky water tube or a jammed ice chute,check it. most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs. please do not forget to rate the solution.thanks
Posted on Jun 12, 2009
Richie_asg1
  • 1036 Answers
SOURCE: Water is slowly trickling out of water dispenser
This is usually because the water filter on the supply line needs replacing.
If it has not been replaced within 6 months, then this will probably cure it.
Thank you for using Fixya,com
Posted on Aug 05, 2009
SOURCE: lights stay on inside Sears (really LG) french door refrigerator
That should be a covered repair. There was a safety bulletin on that. Call Sears and complain. Tech should have known that.
Posted on Jan 12, 2010
Testimonial: "Thanks so much I did get a fix for this time but I guess they won't take care of the first time. I appreciate your help."
TheMobilian
  • 8220 Answers
SOURCE: French door LG refrigerator with freezer on the
It might be something simple like the water faucet is not open all the way
LG FRENCH DOOR SERVICE MANUAL
Posted on May 21, 2010
Lg French door inside ice maker stops working but water flows out the back of the fridge where the water line gores in. Water line is fine and just had a new ice maker put in but it still does not produce...
Sounds like you have to have a leak in the water line somewhere. The water line goes to the top hinge in the door, so the water has to come from somewhere below that point or it would be collecting inside the door and leak out the front. A leak would prevent water from getting to the ice maker, or a leak at the valve could have this effect as well. Check the water valve that gets a call to send water to the ice maker.
Jul 07, 2014 | LG LFX25960ST Stainless Steel French Door...
Water dispenser very slow
Check the filter and replace if necessary.
Oct 26, 2012 | LG LMX25981ST Four-Door French Door...
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
May 15, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
I have a LG 3-door french refrigerator that will not dispense the ice. It makes the ice just fine and it dispenses the water just fine. PLEASE HELP!
the most be a chunk of ice stuck since this refrigerator cool way much it freezes the water in the dispenser area i have cleared wit a bit of hot water and emtying the ice bucket
Oct 05, 2009 | LG LFX25960ST Stainless Steel French Door...
Leak in the left door (water dispenser)
ck container to rule out simple leak ck for cracks in container make sure lines are secure and free of breaks also part can be ordered. first ck all basics lines and conections in compartment
Aug 18, 2009 | LG LRFD25850 Stainless Steel French Door...
Water leak from dispenser
The reservoir inside has to be replaced. After numerous calls to LG, I finally got the LG Mobile Service Tech to service it, and the water reservoir has been completely redesigned....can you say "design flaw?" Now, since the new "tube" has replaced the "reservoir," I have little green things floating in my filtered water! I hate LG products.
Dec 11, 2007 | LG LRFD25850 French Door Refrigerator
Apr 12, 2007 | LG 22.4 cu.ft. French Door with External...
LG LRFC25750 Refrigerator French Door Logo
312 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
