Vcr and dvd seem to play but don't send picture to tv
  • Anonymous Dec 12, 2008
    no picture after connecting
    Problem Solver:
  • 13 Answers
There is a problem with the connection
Posted on Dec 07, 2008
Tv has only snowy screen. Used the remote to
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 24, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
When tv is turned on with cable channels picture is snowy. when dvd or vhs tape played through tv the picture is snowy
Try using the video inputs
Nov 13, 2009 | Televison & Video
Rca 20F514TD blue screen
Nov 05, 2009 | RCA 20F514TD 20" TV
No signal, no channels coming up. other TV's on same ariel working ok??????
Nov 04, 2009 | Goodmans Televison & Video
Blue screen. No audio or video through the cable hook up. RCA model #32V420T
Oct 25, 2009 | RCA 27F534T TV
We moved tv from living room to bedroom and the screen says "unusable signal"
Oct 05, 2009 | GE 31GT720 31" TV
Correct hookup from satilite receiver to dvd/vcr to tv
Av out from sat to AV1 on TV.
AV2 from tv to av in on dvd/vcr .
( if you can pick what av2 on the tv sends out set to send av1 out to record)
OR
AVout from sat. to AV1 on TV, AVvideo on sat to vcr/dvd.
The sat. system will act as a "play through" device so you can play vcr/dvd without changing the AV on the TV.
If you connect another lead in either option you may get a feedback loop causing audio "squeak" and video problems.
Post back to let me know if this helps.
Aug 12, 2009 | Televison & Video
Picture is not on the screen. I cannot seem to
Alot of times you have to back up the TV to something like LINE 1 or LINE 2. It will not show up with the TV on channel 3. When I attached my VCR, I hit input and line 1 and 2 came up and then the DVD player would play just fine. Try that.
Jul 18, 2009 | GoVideo Go Video DVD/VCR Combo
I am unable to get my vcr to record. To use my vcr i have to turn my tv to channel 3. Our cable company uses channel 4. Please help
If the tv is working with the cable box with the coax to channel 4 ( then with this configuration to send any signal to the VCR actually it is posible to use a splitter with coax and send the signal to the tv and vcr after the cable box. vcr has tobe in channel 4 also, all channel selection is done in the cable box then anything you see in the tv is recorded in vcr. BUT guess what: You maybe can try something else:
If you send the cable from the wall straight to the splitter and then from splitter to the TV and to VCR, now you can record differnt channel than you are watching in the tv but in this case scenario you need to send the vcr to the video input 1 of the tv to play what is record. Any way to install this TV and VCR you not always need to depend in the cable box.
May 01, 2009 | Sanyo DVW-7000 DVD Player/VCR
No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Aug 02, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
