Question about Canon P23-DHV Calculator
Cannot Laod the paper
I do not know how to load the paperv Can someone please tell me ? i feel Dumb but I really just cannot seem to do this... Thanks Shey
  • 14 more comments
  • Anonymous Feb 18, 2008
    cannon p23-dhv- how do you load paper??????
  • Anonymous Mar 20, 2008
    I can't load the tape and do not have the instructions, either.
  • Anonymous Jun 14, 2008
  • Anonymous Jul 02, 2008
    CAN'T LOAD PAPER
  • Anonymous Jul 05, 2008
    cammpt get paper to feed
    no instructions and I cannot load the paper
  • Anonymous Jul 18, 2008
    steps to reload paper
  • Ann Edgar
    Ann Edgar Jul 18, 2008
    forgot how to load paper
  • adennings Jul 24, 2008
    How do I load the paper?
  • Anonymous Jul 25, 2008
    how do i load the paper
  • Anonymous Jul 30, 2008
    ive tried cutting the paper so its extremely thin, the feeder wont catch it- hopefully im sticking it in the right direction to even begin feeding it?
  • Anonymous Aug 11, 2008
    how do you enter the paper for the P23 Canon to add a new role?
  • Anonymous Jan 24, 2009
    how can put the papaer in the canon p23-dhv calculator
  • holister Feb 03, 2009
    how do you put paper in a canon P23-DH V calculator
  • yulieanna Feb 23, 2009
    how do u laod the paper
  • Anonymous Mar 17, 2009
    welder now:
    thank you for the tip! it worked like a charm!! thanks again! :)
1. The end of the paper roll can be cut on either a straight-edge or angled slant. 2. Remove the top cover of the calculator. 3. Insert the paper into the narrow back slit on the back of the calculator so that it feeds under the black plastic plate. The slit is located on the outside of calculator. 4. Use the Paper FEED button to advance the paper up. 5. Replace the cover and feed the paper through the cover opening. Hope this helps. Slit for paper is not immediately obvious, so don't put yourself down.
Posted on Mar 12, 2007
  • Kelly Bueckert Sep 23, 2011
    I can't thank you enough! I was an hour into this before I found your solution...you just saved me from having to buy a new calculator! lol Thanks again!!!
The only problem was finding the slot. It is on the back of the calculator just below where the bottom of a new roll of paper would go. The roll hides the slot and this is why the instructions tell you to insert the paper in the slot b-4 you mount the roll. The slot looks like nothing more than a crack in the case. Given enough effort, one can totally overthink and complicate the simplest of tasks.
Posted on Dec 06, 2013
Thank god this was on here! i was sitting at my desk for an hour trying to figure this out!
Posted on Jul 20, 2009
Thanks for the help. Also might note to have the switch in the top right in the ON position instead of the other options for that particular switch. Thanks again
Posted on Mar 13, 2009
Thank you sooooo much! This is the only post that explained the insert was on the BACK of the machine. I inherited this machine from the previous admin assistant and sans instructions as well.
Now I can actually get back to my job, pretending to know what I'm doing :)
Posted on Apr 28, 2008
Take the darn thing back like I will do tomorrow after just buying tonight. Piece of junk.
Posted on Jul 30, 2007
Thank so much. I knew there was a place to put the paper.
Posted on Jul 21, 2007
Thanks for your help. I knew there was an answer, but I forgot what it was. We really appreciate your help.
Posted on Jun 13, 2007
Cut the paper so it's shaped with a center point like an arrow. This worked for me.
Posted on May 18, 2007
SOURCE:
I am trying to print but its telling me to laod paper in the bottom tray. I have always loaded from the top. I cant even get the paper to fit in the tray. Help Please
check the setting on your printer properties on the computer. Check paper source setting.
The bottom paper tray can be extended to allow longer paper (page 8 in user guide ) also there is a button on the printer to select either the cassette or from the top loader. This is explained in the user manual on page 11
http://gdlp01.c-wss.com/gds/1/0900005381/01/ip3000quickstartguide_us.pdf
Apr 13, 2015 | Canon PIXMA iP4000R InkJet Printer
What does Er and uF mean. My dishwasher was linking water.
On mine it was Er meant "error" just generic for somethings wrong, (dumb I know!) and the uF means unit failure. I know it sounds so dang dumb. It is merely the computer\'s way of telling us something is not right. Hope it helps, but please don\'t ignore those codes they really are put there for OUR safety, Be Well.
Sep 29, 2014 | Frigidaire Dishwashers
I am unable to make photocopy on laserjet m1132 mfp
i have paper and ink but mu photocopy can make anything can't laod any paper so tell me the solution
Feb 17, 2014 | HP LASERJET PRO M1132 MFP
Please can someone tell me what power lead I need to buy for Imac G3 model M5521 ? Sounds dumb but cannot find the info xx
A normal PC power cord fits your iMac. The kind of three connectors to the wall and three connectors to the iMac.
Jun 09, 2012 | Apple iMac G3 15" M5521 Desktop
I lost my manual. My oven is over 10 years old and has 2 dials for automatic on/off. I never use these dials. Somehow, someone turned them and now I cannot manually turn my oven on. I feel really dumb. I'm...
Hi, You are NOT DUMB. Believe me, It has happened to every person I know that has an oven with one of those timers. It has happened to me and I am trained as a professional technician. Why, it even says here I am a Guru. The day your problem first stumped me, I didn't feel like I was a Guru.
There are several variations to those timers so I will try to cover all of the bases. If the clock has three dials, two small ones and 1 big one. Turn one of the the pointers of the two small dials to the same direction as the other. You will hear a clicking sound. Alternately push each one and then try the oven.
On the Fridgidaire, if my memory serves me correctly, there is a small know that is for time bake. It has a spot on it opposite the Zero that should say "MAN" OR "MANUAL". The that timer pointer to that position. See if that works.
Please let me know what happened.
Best Regards,
The dumb guru,
Mark
Jan 04, 2011 | Frigidare Kitchen Ranges
Craftsman Model 917.276641.
Do you see a belt diagram posted on the deck somewhere? If you do follow it. One very important thing to remember with belts is the v-pulleys accept the v-portion of the belt and the flat pulleys accept the flat side of the belt. If I can be of more help please feel free to mail me.Donnyb60
Mar 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Which way to laod paper to fax on Brother 560 plain paper fax
Does not matter.
If you mean when sending, make a copy, then you'll be sure.
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
IT GOES IN THE BACK, AND HAS TO BE PERFECTLY STRAIGHT. (CUT IT). HOPE THAT HELPS!
Jul 16, 2008 | Sharp EL-1801P Calculator
Where is tray one?
I reported the same problem and decided to check one last time before I scrapped the printer. I pulled out Tray 1 (the bottom (large capacity tray) to really check closely. I discovered that there seemed to be a space between the end of the paper and the printer tray. I simply squeezed the space closed and NOW IT WORKS! I keep kicking myself for being dumb.
Jul 11, 2008 | Brother HL 1850 Laser Printer
Canon P23-DHV Calculator Logo
2,157 people viewed this question
Clive
Clive
old marine
old marine
