Question about Panasonic DMR-E50 DVD Recorder
DVD problems It won't read the disks at all
  • bandit1372 Feb 08, 2009
    Any disk inserted prerecorded or blank can not read .
  • ERFITUP May 11, 2010
    What type of disks are you trying to use?
  • 67 Answers
Ok. I just corrected that problem. You need to take it apart. There are 5 screws, 2 on the side and 3 along the back. Remove same and slip the top off. You will now see a plastic cover which is over the laser. Once again, there are 2 screws. Carefully remove same along with the front portion ( their are 3 clips on the bottom and 2 on the side. The eye ( laser) is now visible). Simply saturate a q tip with rubbing alcohol and clean the laser. Reassemble, and let it set for about 15 minutes. Slip your DVD ram disc and it will read it and allow you to record, just like before.
Posted on Dec 13, 2011
    Problem Solver:
  • 13 Answers
There is a problem with the disks
Posted on Dec 07, 2008
Won't read the dc
First, Try another DVD to be sure its not just a scratched disk. Make sure the disk is spinning (you will hear and feel it spin up). If its spinning but still wont read you can clean the lens inside the DVD player with a air compressor or can of compressed air. The better solution would be to use a CD designed for cleaning the lens that read the DVD. They are quite cheap and are very nice to have around. If it still will not read then you are much much better off just junking that DVD player and buying another. They do not make replacement parts for DVD players and they are getting very cheap to replace. Good Luck. Thank You
~Kyle~
Aug 16, 2012 | Coby Televison & Video
Panasonic DMR-EZ48V won't read disk
Either a dirty or a bad optical pickup in the DVD unit--one or the other.
May 25, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
Disney d-style karaoke won't read disk or spin disk
The problem is in the laser pickup assembly, the pladder motor is not working that spins the disk, and unfortuneately the only way to correct this is to replace the entire assembly which probably won't be cost effective.
Mar 06, 2012 | Televison & Video
Gateway m-1625 CD/DVD-rom won't read any disc. Its spinning but no read. any thoughts?
you might try taking a q tip and some alcohol and clean the eye ( a little glass looking circle ) that reads the disk. Do not touch it with your fingers. Sometimes dust or dirt can get on it and it will not read the disk. This also works on cd players as well as dvd players.
Aug 30, 2011 | Gateway T-1625 Notebook
My laptop aspire 5740 is not able to read the dvd & cd...so i am not able to installed any softwares though cd & dvd..please solve the problem..
Try opening your disk tray and cleaning the lens with a tissue and all of the drive from dust. If it still won't read you may have to buy a new optical drive as your current one has broken.
Have fun :)
Aug 21, 2011 | Acer (KV.16X04.007) DVD Drive
My portable dvd player will not read any dvds
  • I would give it a good cleaning with a disk player cleaning. Those disks have little bristles on them that "sweep" the lens and clean it real well. Remember that if the lens is so dirty that it won't play any DVD you may need to run that cleaner disk a few times to get the lens back to normal working condition.
  • A lens cleaner disk should be ran one time a week to avoid problems with playing disks be it CD or DVD or Computer.
  • Sometimes players go bad so keep in mind this could be the problem as well but I have had the DVD player in my garage get so dirty I had to clean it a few times to get it to work normal.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 11, 2011 | Sylvania SDVD8732 Player
My Sony CDRWDVD CRX880A ATA Device won't read Dvd's I'm trying to make burn a movie on there and it won't load the disk it says " Let windows help me choose a disk" because D:/...
The
CRX880A is a cd writer and DVD reader it doesn't record dvd only plays them
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 03, 2011 | Sony CRX880A CD-RW/DVD-ROM Combo Drive
My laptop has a strange problem. CDs and DVDs do work fine but when I put in 1 particular DVD the drive does not recognise it. The DVD is working on other computers though. I have an ACER ASPIRE 6530 ,...
This is not uncommon at all.
There are slight variations in drives and the tracks of data on the disks are extremely small. A disk may be off a tiny amount and may not work in some drives but will work in others. This seems to be particularly true of user recorded disks.
One thing that sometimes works is to make a copy of the disk. Even making a copy with a drive that won't read it normally may sometimes work. The disk copying software will usually warn you and refuse to try if it really can't read it. Try copying it in another machine, that should solve the problem.
HTH
Jun 16, 2011 | Computers & Internet
My RCA RTD317 has problems recognizing most DVD movie disks. It will play some disks most of the time and all audio disks, so I figure the lasers are working. What could be the problem?
If you've tried cleaning the Laser with a Lens Cleaner Disk or directly with Lens Cleaner Fluid and a QTip without any improvement then the Laser is Failing.
It takes less power to read some DVDs than others and a lot less power to read an Audio CD. The Laser will continue to deteriorate until it won't play anything.
May 08, 2011 | RCA RTD317 Theater System
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Panasonic DMR-E50 DVD Recorder Logo
197 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
