Question about Dell Dimension 2400 PC Desktop
Windows xp recognizes that my dvd rom drive is there but when i place a disk in to the drive it trys to load up the disk but doesnt do anything it just tries to load then you hear a clicking noise and then it tries to load again
  • 2 more comments
  • Anonymous Dec 07, 2008
    the exact same thing is happening to me!
  • micheal8143 Mar 21, 2009
    I added a samsung ts-h522 dvd/rw to my dimension 2400 in the lower driver bay and leaving the existing cd drive hooked-up as it was. The manual says to make sure the jumper setting is on cable select which is also what the existing cd drive jumper is set to. The problem i'm having is that the computer recognizes the dvd drive but can't tell that there is a dvd in the dvd drive. It says insert disc into tray when there is already a disc loaded and trying to be read. The existing cd drive seems to work fine.Am i missing something i need? A download? A setting? Any info would be appreciated. Thanx
  • micheal8143 May 11, 2010
    what does he mean by drive lance or what is a drive lance?
  • MRTech40 May 11, 2010
    If it does it with every disk, I would replace the drive. And while you are at it, get the newest and fastest.
  • 51 Answers
Your drive lance and preset settings are damge.you have to change a preset position if you know how to do else you must repair your drive.
Posted on Dec 10, 2008
How can i install xpon pavilion dv63109tu
Load the Windows XP installation disk/disks into your DVD/CD rom drive reboot from DVD/CD rom, follow instructions.
Apr 26, 2013 | HP Pavilion Computers & Internet
I have an Acer Aspire 5332 and the CD-Rom/DVD Drive (Optiarc DVD RW AD-7580S ATA Device) is not working properly...every time I put a disk of any kind (i.e CD/DVD/Game) it doesnt recognize it and load
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Mar 22, 2012 | Acer Computers & Internet
Sony vgn a-150 not recognizing empty dvd media of any kind, but will read it.
You could try this tool for resetting your DVD-Rom. If this does not work then it could be you need a new Optical burner.
ClickMe
Dec 21, 2011 | Sony VAIO VGN-A150 Notebook
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
May 02, 2017 | Computers & Internet
My pc won't boot from cd-rom... Bios recognizes both cd-rom drive and hdd, and boot sequence is set to boot from cd-rom but when it comes to boot from the windows XP install dvd it shows the message...
you are saying two differnt things here.. CDROM and DVD if its a dvd in a CD ROM it will not boot a windows disk if somehow this is written to a DVD Is it original?
Secondly is the Cd ( or DVD drive) actaully working. Being listed in CMOS does not guarantee that.
I know you have listed the drive as DVD but do you have 1 or two drives installed and not have the disk in the recognised drive.; have to eliminatge all possibilities of werror in interpretation here.
So assuming everything appears as it should, then the medial in the drive has to be considered at fault .. dirty disk.. drive needs iris clean, not an original disk, damaged disk, not a boot disk.. just a windows cvopy.;
Nov 23, 2009 | Intel D865GBF Motherboard
Trying to boot from windows CD and not working
If its the full windows xp cd by booting it from the cd drive it will erase everything and ask if you want to upgrade or advanced install I think. Your correct in choosing the atapi cd-rom as 1st boot device. The cd should be in the drive on startup. IDE is the type of hard disk drive. I'm guessing the FDD stands for floppy disk drive which you might not have that many but you have that many bay windows available.
Put disk in, shut down computer, Start computer and it should give you the xp disk contents. Be aware of data loss though.
Nov 14, 2009 | Microsoft Windows XP Home Edition
Lite on DVD Combo disk read failure
You could take the drive out of the encloser and hook it up. There could be a flaw in the enclouser ive had that happen before to me. I just took it out and put it in standard if this dosent work then there is a flaw in the dvd burner
May 20, 2009 | AMD Duron 1.3 GHz (cpu-amd-1.3g-o)...
WINDOWS XP WON'T LOAD TO HARD DRIVE
1) If you are trying to install from a bootable disk and trying to make a fresh install, you will not come across this error.
2) If you are trying to repair the existing installation, you might need to use FIXBOOT command and try. Please refer the below link before you try this.
http://support.microsoft.com/kb/314058
Apr 21, 2009 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
46 people viewed this question
Alun Cox
