Question about M2K Garfield: It's All About Math Math (Ages 7-9) (GRF16AM201) for PC
-8 is less than or greater than -3 - M2K Garfield: It's All About Math Math (Ages 7-9) (GRF16AM201) for PC
    Problem Solver:
  • 19 Answers
Less
Posted on Dec 08, 2008
I need help on homework of greater than less than or equal than.
In mathematics, if there are 2 numbers being looked at as an inequality, the greater-than symbol usually goes in between the two and symbolizes that the first number is greater than the second number (For example: 4 > 2, or 102 > 100).
Greater-than sign - Wikipedia
https://en.wikipedia.org/wiki/Greater-than_sign greater than less than or equal than Google Search
Dec 01, 2016 | Computers & Internet
Does the symbols stand for greater than or less than
This is 'greater than' >, eg X is greater than 3......... X > 3
This is 'less than' <, eg Y is less than 3......... Y < 3
Jan 13, 2016 | The Learning Company Achieve! Math &...
I am greater than 3 hundreds, 2 tens, and 2 ones. I am less than 3 hundreds, 2 tens, 4 ones. What number am I
Let's build the two numbers in question.
HTO for hundreds, tens, and ones
322
324
What number is greater than 322 and less than 324?
Good luck.
Paul
Nov 12, 2015 | Office Equipment & Supplies
Is 2/12 greater than or less than 2/3
Reducing 2/12 to lowest deliminator equals 1/6. 2/3 equals 4/6. Therefore 2/12 is less than 2/3.
Mar 04, 2015 | Computers & Internet
How do I round 439.96479 to the nearest cent
take the figure immediately after the decimal point (disregard the rest) and see if it is less or greater than 5. If it is 5 or greater then round up to the next figure before the decimal point
if it is less then round down to the whole figure before the decimal point
example if the figure is 439.5 or 6 or 7 or 8 or 9( disregard the rest of the figures) it is rounded up to 440.0
it is 439.4 or 3 or 2 or 1 then it is 439.0
Feb 12, 2015 | Computers & Internet
Solution for "in math what
9>2 (Nine is greater than 2) 1<5 (one is less than 5) 5>1 (five is greater than 1)
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
Jun 21, 2011 | Computers & Internet
I have a 02 dodge grand caravan sport with 0351,0352,0700 codes...car runs good then shakes and even stalls at times,but not all the time...i have replaced ignition coil,wires,plugs,and catalytic...
po700 code just means you have codes
P0351-IGNITION COIL #1 PRIMARY CIRCUIT
WHEN MONITORED
With battery voltage greater than 8 volts during engine cranking or greater than 13 volts with engine running. Engine RPM less than 3000. No coil in dwell during test.
SET CONDITION
Peak current is not achieved with battery based dwell plus 1.5 msec of diagnostic offset. It takes less than 3 seconds during cranking or up to 6 seconds while running to set.
POSSIBLE CAUSES
- Ignition coil
- Intermittent condition
- ASD relay output circuit
- Ignition coil driver circuit open
- Ignition coil driver circuit shorted to ground
- PCM
P0352-IGNITION COIL #2 PRIMARY CIRCUIT
TEST NOTE
This symptom is diagnosed using the test P0351-IGNITION COIL #1 PRIMARY CIRCUIT.
WHEN MONITORED
SET CONDITION
POSSIBLE CAUSES
- Ignition coil
- PCM
var classElements = new Array(); var node = document; var tag = 'a'; var els = node.getElementsByTagName(tag); var elsLen = els.length; var pattern = new RegExp("(^'\\s)specs_note(\\s'$)"); for (i = 0, j = 0; i
Jun 14, 2011 | 2002 Dodge Grand Caravan
I want to create an if else statement with regards to this problem for ms excel 2007. the conditions are if month&gt;=3 plus 1/2 but if not then minus 1/2.
It seems to have botched your sign before the =3 but lets say that you used "less than" or equal to 3.
(if you used Greater Than, then simply replace "less than" with "greater than" in the example here)
The easiest thing to do is subtract 1/2 no matter what and then say if month is less than or equal to 3 then add 1.
this way, if the month is NOT less or equal to 3, it has already subtracted 1/2, satisfying the "if not" part.
If the month IS less or equal, it adds 1 which compensates for the 1/2 we already subtracted, plus another 1/2 giving an end result of plus 1/2.
This makes it a simple, single if statement that is satisfied in the other direction without having to overcomplicate the issue.
Apr 27, 2011 | Microsoft Computers & Internet
Fault codes p1757 p1762 when i doing smoke for dmv when i doing smoke test this code show fault on transmision
CODE P1757 - GOVERNOR PRESSURE GREATER THAN 3 PSI WHEN REQUESTED TO BE O. CODE P1762 - GOVERNOR PRESSURE SENSOR OFFSET VOLTS TOO LOW OR HIGH.MEANING SENSOR INPUT GREATER OR LESS THAN CALIBRATION FOR 3 CONSECUTIVE NEUTRAL PARK OCCURANCES.
Sep 01, 2010 | 2000 Jeep Cherokee
M2K Garfield: It's All About Math Math (Ages 7-9) (GRF16AM201) for PC Logo
118 people viewed this question
Top M2K Computers & Internet Experts
David Payne
David Payne
Are you a M2K Computer and Internet Expert? Answer questions, earn points and help others
