Question about HP Pavilion a420n PC Desktop
Just installed 2 gb pc 3200 in hp pavilion a 420n
Computer does not boot after turning it on, just makes a beeping noise.
    President:
  • 1,073 Answers
Remove the sticks and put them back again, make sure you hear the "click", the click means that the sticks are where they should be in possion,¨
Btw, you bought sticks that are suported by your Mobo i asume?
Posted on Dec 07, 2008
OS Vista. 2 short and 1 long beep repetitive - will not boot at all.
2 short beeps and 1 long beep (repeats 5 times)
Unable to initialize video or video card required but not installed.
if you have a video board add on card, reseat after unplugging power cord.
If built in, time for new computer
Nov 02, 2013 | HP PAVILION A6230N DESKTOP PC
Makes beeping noise
Remove and reseat the memory card(s).
Jun 09, 2013 | HP Hewlett Packard Pavilion 23-1030 23"...
Installed 2 GB of Ram (both 3200 1 GB chips). PC would not boot coorectly with 2 GB installed (errors galore). However PC runs fine with only one 1GB installed. Running XP ?
Both ram sticks must be identical to work together. A different manufacturer of one can cause all kinds of problems. Did you go to 'setup' to make sure the machine recognized the second stick? The cure is likely to be purchasing another stick identical to the other new stick. Hope this helps!
Dec 27, 2010 | HP Pavilion a450n PC Desktop
I turn on my computer and i get a box that sais adjust screen and gives a resolution and then goes black, nothing else happens no beeps no booting noise. F10 pops up another screen for 2 seconds then goes...
try to boot in safe mode.To do that.
restart your computer continues press F8 key it will show the option select safe mode
and you can work with that and change the reasoluition and restart the computer work with normal mode..
Nov 13, 2010 | HP Pavilion A610n (PC106A#ABA) PC Desktop
HP pavillion DV 2000 cant boot and with 1 long 2 short beep
I found some info on a forum, it says the 1 long and 2 short beeps is a problem with the graphics chip. You may need a replacement motherboard.
Check this post out
http://www.computing.net/answers/hardware/1-long-2-short-beeps-hp-laptop-/52894.html
Aug 16, 2010 | HP Pavilion dv6000z Notebook
HP Pavilion a384x PC, 8 beeps, doesn't boot up
This beep code indicates a possible motherboard fault.
Some components may not be making proper electrical connection.
Open the desktop and remove the cable connectors and components one at a time and insert them on back on the motherboard.
Also remove the various PCI cards etc. and insert them back into the various slots.
If it still doesn't boot up or cannot go into the BIOS configuration, then it is a faulty motherboard. The hard drive should be OK but you won't know for sure until you test it by connect it to an USB hard drive adapter and plug it into a working computer's USB port.
Dec 20, 2009 | Computers & Internet
Memory upgrade problem
try the new memory one by one and the memory should be PC2 3200 MB/sec and DDR2 SDRAM and as there r 4 slots try diffrent slots also
Jun 26, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
Computer will not boot. was making some loud noise before it stopped working
I just had the same problem to deal with. My computer automatically turned on, and just when you thought it was gonna work, there was a single, loud beep. I immediately unplugged the computer. Make sure all the cords and chips are properly and securely connected. My problem was that my memory cards were loose. Maybe that'll help.
Jun 17, 2008 | HP Pavilion A1050y (PU131AV) PC Desktop
Boot up problem
youre hd needs an os installing on it.first partition,then format ,then install os(windows)
the system is looking for a os not a hd ;the beeps indicate no os found(no drive by default)
if there is no hd,memory,or video card or stuck key the pc will beep.also with video card not connected the screen will be blank also with many models no memory will result blank screen.In ur case its only the hd.make sure all items are fitted insert os disk in cd drive start pc and boot from cd,to create partition,format and install
Mar 04, 2008 | HP Pavilion dv6000z Notebook
3 beeps at start
hmmm...that's not good. works fine with no battery. I suspect your motherboard may be taking a vacation from working soon.
got backup for your HP?
Feb 12, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion a420n PC Desktop Logo
137 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
