Question about Roper RS25AEXLQ Side by Side Refrigerator
Ice maker gear tabs RS25AGXNQ01
I read your one of your best fixes saying check to see if the tabs are not broken off of the gear that turns and controls the ejector and other timing functions----My tabs are broken and the gear just sits and slips. Can I get just the connector between the ejector and the gear(ie new tabs) or the whole motor assembly? Does something get too solidly frozen in the machine and cause the gear to break? Thanks.
  • Anonymous Jul 05, 2008
    ICE WONT EJECT, MOTOR IN BACK TURNING, BUT DOES NOT ROTATE THE SCREW INSIDE THE ICE BOX. THIS IS A BRAND NEW MACINE . WHIRLPOOL ED5VHEXVBOO
    President:
  • Roper Master
  • 2,651 Answers
Not worth getting a repair kit for the gears, i reccomend purchasing the entire ice amker as a whole, replacing just the gear wont correct the reason that it craked in the first place
Posted on Jul 09, 2008
Ice maker not making ice
Hello there:
There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: bullet.jpg If your ice maker has a small red plastic lever, lower it to lower the wire. bullet.jpg If there's no plastic lever, simply lower the wire. bullet.jpg In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it. Please try these and see if it helps if not let me know and i will do my best to further assist you ok?
Best reagards mike
Sep 26, 2010 | KitchenAid Superba® Architect® KSRP22FS...
Icemaker will not work. water will not fill the icemaker
Hello there:
If there There's no ice Please read this entirly to assist you in troubleshooting this problem. If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try
Aug 07, 2010 | LG Refrigerators
Ice maker
Hi
Please check the link bellow and read the article therein thoroughly to diagnose the problem to your refrigerator…you need to check the mentioned few things that is causing the refrigerator not to make ice….
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jun 30, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My ice maker is not dumping the ice it just freezes and stays in there help
You need to replace the ice maker . It is a lot less time consuming to replace the ice maker , than to try and repair it . But , if you want to try , you have a bad thermostat , or broken gear . If the gear type , pull the cover off the ice maker , and you will see the motor running ( small gear ) , but not turning the large gear . In this case , replacing the large gear , would be the best thing , instead of replacing the whole ice maker .
Nov 21, 2009 | Admiral Refrigerators
ICE MAKER HAS QUIT WORKING
take off the cover to the ice maker. make sure the 2 tabs in the middle of the main gear are in tack and not broken. if one of those tabs is bent or broken, the gear will not make a full rotation. if the gear is fine, check your fill tube in the back of your freezer that goes to the ice maker and make sure it is not frozen. if it is, it will need to be thawed. does your unit have a water filter? if so,it may be plugged and need to be changed. the last thing would be an issue with the water value itself. Joe
Nov 18, 2008 | Refrigerators
Ice cube maker
IF NO WATER IN ICE MAKER, CHECK FOR RESTRICTION IN FILL TUBE SUCH AS FROZEN OFF WITH ICE. REMOVE FILL TUBE AND RUN HOT WATER OVER IT TO MELT ICE IN TUBE.
WATCH FOR WATER COMING SLOWLY OUT PLASTIC FILL LINE ATTACHED TO TUBE ON BACK OF REFRIGERATOR.
IF WATER SLOWLY DRIPS OUT OF FILL LINE, REPLACE FILL VALVE( LOCATED WHERE HOUSE WATER LINE ATTACHES TO REFRIGERATOR.
IF ICE MAKER HAS WATER/ICE IN IT, PULL FRONT COVER OFF ICE MAKER TO ACCESS CONTROL HEAD. INSPECT LARGE WHITE GEAR ON FRONT OF CONTROL. IF THE RETAINING TAB IN THE CENTER IS BROKEN, REPLACE MODULE OR ENTIRE ICE MAKER. THERE SHOULD BE TWO
RETAINING TABS HOLDING THE GEAR IN PLACE.
THE FREEZER TEMP NEEDS TO BE A MINIMUM OF 10 DEGREES FOR THE ICE MAKER TO CYCLE. IF THE FREEZER TEMP IS NOT COLD ENOUGH WE WILL NEED TO FIND OUT WHY.
Mar 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refridgerator ice maker not making ice
actually it should be blinking when door opened, try closint the little flap on left side of freezer liner, does hte light then become solid??? if so the electronic control is working correctly.. open the flap acessing to ice maker itself is there any ice in the machine now?? perhaps an ice cubes is jammed and not allowing hte icemaker to advance.. ck the little black nozzle(fill tube) crush it with your fingers is it full of ice???if so your fill tube is frozen and needs to be thawed. this is a pretty hard ice maker to trouble shoot. lastly theres ascrew under the rt corner if ice machine 1/4 nut driver. remove htat screw it releases acover for wires. the ice maker will pull out (youl need to push up a little tab along the left siderail inwhich the ice aker sits , after removed pry off the white cover if ice maker and look at the center gear. sometomes the tabs holding that gear on are broken in which case hte ice maker wont work and needs replacing(you cant sevice the main gear replace the entie assy. let me know what you find( iknow it sounds like a lot but youll be alright!!!!!
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ed2fhexnq00 icemaker will not dispense filled with ice
can you see the ice maker's white cover?? try to pry that off , usually a little space for a ***** driver to be inserted into where the body of ice maker and the cover meet in lower right corner. after removing check the gear in center of ice machine. there should be 2 little tabs that hold that gear on." picture trying to snap that gear on , the tabs would hold it in place" do those tabs appear tobe broken?? at least one anyway(although small ther should be a distinct space between the tabs where they sprung back into place) if theyre broken, theres your problem you need to replace the ice maker assy,(entire unit)
Mar 13, 2008 | Whirlpool GD2SHGX Refrigerator
I have a Whirlpool Gold side by side frige Model # GDYHA Ice maker stopped working tried to troubleshoot it but still does not work...Have any idea how to fix it. Thanks
THE ICE MAKER CYCLES WHEN THE INTERNAL THERMOSTAT REACHES 10 DEGREES. IF THE FREEZER IS WARMER THAN 10 DEGREES, FIND THE REASON FOR THE WARMING TREND.
CHECK THE ICE MAKER TO SEE IF IT HAS ICE OR WATER IN IT. IF NOT, CHECK THE FILL TUBE TO SEE IF IT IS FROZEN. REMOVE THE ICE FROM THE FILL TUBE IF IT IS FROZEN OFF. IF THE FILL TUBE IS O.K., CHECK THE WATER VALVE ON THE BACK OF THE REFRIGERATOR TO SEE IF IT HAS GOOD WATER PRESSURE COMING TO IT.
ALSO, CHECK THE FRONT OF THE ICE MAKER BEHIND THE PLASTIC COVER. THE WHITE GEAR IS SUPPOSE TO BE HELD IN PLACE WITH TWO TABS IN THE CENTER OF THE GEAR. IF ONE IS BROKEN OR BENT INWARD, THE GEAR ISN'T MAKING CONTACT WITH THE CIRCUIT BEHIND IT. THE CONTROL MODULE WOULD NEED TO BE REPLACED. OR IT MAY BE JUST AS WELL TO REPLACE THE ENTIRE ICE MAKER.
Mar 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
pull the front cover off of the icemaker and see if the drive gear is broken (there are 2 tabs in the center of the gear make sure these arent twisted or broken as well) if so replace the module on the fron of the icemaker. if that checks fine check for frozen fill line..
Dec 16, 2007 | Refrigerators
Roper RS25AEXLQ Side by Side Refrigerator Logo
264 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
