Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
Error code ee2
My stove quit burning and will not reignite
  • Erik Willyerd Dec 23, 2008
    i dont have the laser 30 i have the toyostove laser 56 (type I). i ran my fuel tank out and sucked up the gunck on the bottom. i got that cleaned, filters cleaned.i also bought a new fuel pump. its max psi is 3.50. i was woundering if i needed more psi. any thing will help.thx.
    Novelist:
  • 126 Answers
Johnny, If there was dirty and water when you cleaned the filter you may need a new igniter. When you try to start the stove, feel around the two red wires to see if it gets hot. Be careful as it could be very hot. If it does not get hot you need a new igniter.. If it gets hot and still no flame be sure the fuel is getting to the burner. Remove the copper line at the burner and put something under it to catch the fuel. Try to start, this will tell you if you are getting fuel.
Tom Hakwins
hawkins111@gci.net
Posted on Jan 06, 2009
  • 57 Answers
How long has it been since you last had it cleaned. There may be soot build up in it, including the burner pot keeping it from igniting. When was it last working properly?
Posted on Dec 13, 2008
After my stove runs about two cycles, it shows E E 2. we relight and it ignites and then shuts back down with the error message. The tank is full, no air in the fuel line or filter. suggesations?
Has this unit been serviced. Sounds like the Flame Sensor is dirty and not sensing flame OR this actually isn't any flame due to an ignitor or fuel issue. Here is a complete explanation and diagnosis of the EE2 problem: Toyostove Error Code EE2
Feb 07, 2016 | Rinnai Toyostove Direct Vent Heater:...
Sharp RCD2200M error code ee2
this mean shortes thermistor you must replace, but before you must test with VOM.
see the video .God bless you
Jul 10, 2012 | Sharp RCD2200M Microwave Oven
Lazer 30 error 22 on panel
The stove quit three times with an ee2 message. The stove is trying to save you from flooding. You may have a fuel problem that is causing the ee2 problem. After three time the stove locks out and won't let you try again. Find out whats up with the fuel. Unplug the heater for 20 minutes and you will be able to try again. Also make sure the igniter is getting hot. Two red wires going into the burner should get hot.
Tom
Sep 25, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Lost manual stove is blinking code ee2
No ignition. Check the igniter by feeling around the two red wires when you try to start the stove. They will get very hot so be careful. If the igniter gets hot you have a fuel problem. No fuel, low fuel or dirty filter.
Keep us posted,
Tom
May 10, 2010 | Rinnai Toyostove Direct Vent Heater:...
Gettin an EE2 error - replaced the fule filter at the tank, removed and cleaned the sump screen, no luck. Does the sump screen on this stove fit into the sump with the open aspect of the screen facing the...
The open end goes toward the back of the heater.
Next try cleaning the flue.
Other potential causes for an EE2 are malfunctions of the circuit board, flame sensor or or fuel pump.
-Helping Hands Services
Fairbanks, Alaska
Oct 11, 2009 | Rinnai Toyostove Direct Vent Heater:...
Error 22 whats that?
The EE22 message means the stove quit with an EE2 three time in a row. In order to clear the EE22 you must unplug the unit for 20 minutes. Then you can try again. It sounds like you have the fuel problem figured out?
Tom Hawkins
hawkins111@gci.net
Apr 01, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
EE2 code for toyo laser 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? If you let me know the sequence of events, I can trouble shoot the problem for you. toyotech
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
EE2 code for toyo 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? The firing process is the burner button blinks green for 7-9 minutes, then it clicks up to the medium, yellow light which starts flashing. That is when the fuel pump starts pumping. If you hear a fairly audible tic tic, or thump thump coming from the fuel pump then that is your indication that the fuel pump is starving for fuel. You either have a fuel line restriction, too little fuel, a clogged filter, a clogged sump screen, or rarely, a failing fuel pump. Usually, it is a fuel line restriction.
If you hear no tic tic or thump thump and it just goes off on EE2 then the problem is in the burn chamber. You may have a carbon chain in the chamber causing the flame sensor to temporarily short out. You can clean the flame sensor, fuel nozzle, and igniter to resolve this problem until you can get your Toyo tuned up.
EE2 code for toyo 3
What Does EE2 Mean? Laser 30, 56, and 73 model Laser heaters cease operation and display
the EE2 code on the control panel (instead of the clock or temperature settings) when the primary
flame rod on the heater fails to sense a flame during the first 5 minutes of the Ignition and Pre-
Heat cycle. On the Laser 55 and 72 the heater will stop and the red Reset lamp will light rather
than the EE2 code. (Note: There may be other reasons for the reset lamp to come on but much of
this information will apply.)
What Can Cause An EE2 Error? The primary flame rod is the only sensor in the heater that
can cause the EE2 error. Thus, if it occurs, either there is (1) no flame to detect, or (2) the
sensor failed to detect the flame. The flame rod is located on the lower 1/3 of the burner. It is a
heavy wire with a ceramic insulator. A single white insulated wire connects this device to the
main circuit board.
Dec 12, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
194 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
blender719
Level 1 Expert
Kenneth Wilson
Kenneth Wilson
Level 1 Expert
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
