Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Will not turn on
I bought the tv used, brought it home waited about 6 hrs before plugging it in because it was cold out. I plugged it in and turn it on and it made a loud snap and it smelt like wires burning. What could be wrong with it?
It Is a Rca HDTV 52". model # d52w20 Serial # d396c307n
    Genius:
  • 1,199 Answers
Sounds like your flyback has want out (cheap part around 70.00) but the labor will cost ya unless you do it yourself
Posted on Dec 07, 2008
55" model. Why does it play for a couple of hours, then shut down?
Sounds like you have a parental setting on the tv that is set to only allow 2 hrs then shuts down... try going into the menu and looking for parental settings or sleep settings... if that isn't it try spacing the tv away from the wall to allow circulation... it may be over heating... next would be to get a circuit checker for the wall plug and make sure the polarity is right at the power source... you would be surprised at how many homes are wired bkwards... usually sign of this problem is electronics in your home seem to burn out with in 6 months or sooner... tester has 3 to 4 lights on the bk of it and looks like a wall plug.. costs about 5 $
Jun 09, 2015 | Vizio Televison & Video
I just bought this thing and it worked at the guys house and now dosent turn on at all help thank you ...
Kevin, first check the wall outlet it's plugged into, to make sure it has power. It may have a loose wire connection or the circuit breaker for that line has been tripped. If you brought the unit home, sitting on it's rear or side, rather than on it's bottom, you will need to wait 6 to 8 hours before using it. As the refrigerant fluids and oil in the compressor need to run back in place.While you're waiting, check the outlet and the circuit breaker in your home's breaker panel.
Hope this helped you & thanks for choosing FixYa.
Aug 11, 2011 | LG Electronic Window Air Conditioner
How many hour I need to wait to plug my freezer after I broth it home?
If you brought it home on it side you need to stand it up for 24 hrs befor you plug it in. If you brought it home standing up you can plug it in right away
Dec 30, 2010 | Danby Refrigerators
How to program a intermatic outdoor timer/photo control hb51rc
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb51rc.aspx
1. Turn dial selector to the "off" position and
plug timer into three conductor outdoor outlet.
2. Turn dial selector to timing interval
desired (i.e., 2 Hrs, 4 Hrs, 6 Hrs, 8 Hrs,
dusk to dawn, etc.).
3. Plug outdoor lights into Easy-Set™ Timer -
lights will turn on automatically at dusk.
4. Lights turn off 2 4 6 or 8 hours later
depending on dial selection
Dec 07, 2010 | Intermatic Outdoor Timer/Photo Control...
Just brought a second hand freezer for garage. It worked at the house but when I brought it back home and plugged it in it didn't get cold I had a green light on and a red hazard light on. Should I have...
The green light means it has power . The red light means the temp is not satisfactory . If the freezer was laid on its side anytime and did not sit for 24 hrs before plugging it in , then it's no good anymore due to compressor pumping solid oil into the lines instead of refrigerant . The oil causes restrictions not allowing the refrigerant to flow .
Sep 26, 2010 | Refrigerators
Just bought a used GE chest freezer model FH5DSAWH from friends. Brought it home plugged it in and it doesn't get cold. Can hear it running and the compressor gets hot. Any ideas? Was told it worked great....
your ptc overload relay on the compressor is bad,unplug it off the compressor and get a replacement at an appliance parts store,plug in the replacement and this will solve your problem
Apr 27, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
We have nothing on the screen and the power, temp and lamp lights are flashing. We purchased this as a display and think we may have put it in to bit of a tight spot restricting air flow. We have only had...
First try to unplug it from the wall outlet, wait 5-10 min and plug it back in. If same problem continues - next step is to replace the lamp.
Any DLP projection TV needs at least 2"-3" "breathing" space around sides, top and back of the set for proper airflow.
But most likely case - lamp died because of too much hours of use in previous location. Lamp designed to work around 4500-5000 hrs. in realistic environment. Looks like having it on display, store used most of those hrs up.
Sorry for bad news.
Russ.
Apr 06, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Just had a new upright Frigidaire freezer delivered two days ago. Plugged it in immediately. It did not get cold after several hours. Turned it off then back on. Unplugged it. Unplugged it for several...
Whenever you get a frig or freezer delivered it is best to wait at least 24hrs (some say 8 hrs) before you plug in. It maybe unknown to you if this was shipped to you in the laying down postion. If it was and you plugged in it will not work because laying down the oil migrated away from the compressor.
Other than that the freezer could have (possible chance but still possible) problems that are out of your control. If you brought it at a retail store you have at least 2 weeks to exchange. Do that a.s.a.p.
Dont bother trying to figure out just exchange!!!
hope this was helpful
Apr 04, 2010 | Frigidaire Freezer Refrigeration White...
Refrigerator-lights on not cold
If has a electronil controlboard i would say it is faulty.Cheak on warranty.
May 11, 2009 | GE PSC23NGS Side by Side Refrigerator
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
