Monitor has great difficulty starting up-
Flashes on and off for several minutes then eventually starts up
Try this
1. Check if it's plugged in (if it's not too obvious)
2. Make some space on your hard drive
or 3. Get a new computer. Thats all you probably can do
Posted on Dec 10, 2008
Dell 1704FPVs 17
Check you video cable ..if loose tight the screw..if still the problem presist try changing the video cable.
Sep 26, 2012 | Dell 1704FPVs 17" TFT LCD Flat Panel...
Monitor takes anywhere from 15 minutes to more than an hour to produce a display after starting the PC. It starts by flashing briefly on the screen, and eventually produces a display. It works fine after...
Sounds like you have an LCD inverter going out there might be some leaky compasitors on the main board. Its probably cheaper to buy a new one then to have a repair center fix it. Unless you know someone who is good with a sodering iron.
Best of luck and have a happy and safe 4th of July!
Jul 02, 2010 | eMachines E17T4W 17" Monitor
I have a Sony kf-50we620, It started having problems this week. Sometimes, not always, I turn it on, the green light flashes and the TV will eventually start but it takes over 2 minutes to start. I will...
Its symptoms of weak lamp that need to be replaced.
How old is this TV and did you replaced its lamp recently?
lamp replacement is easy and would be written in user manual. Please buy Sony original lamp for TV safety.
Thanks.
Jan 15, 2010 | Sony Grand WEGA KF-50WE620 Television
Engine light flashes when accelerator pedal is applied accompanied by severe power loss and trouble revving up
the check engine light is flashing to alert you to the fact that the engine has a missfire in the ignition system, don't continue to drive this with the condition or u can overheat and damage the catalytic converter.
May 11, 2009 | Mercedes-Benz E320 Cars & Trucks
LG1717S - Power light flashing - no image.
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Sep 03, 2008 | LG L1717S-BN 17" LCD Monitor
Monitor image flashes off and on
Sounds like you've done all the trouble shooting. If you just need that extra nudge, I would agree... it sounds like you'll be needing to shop for a new monitor.
Jun 29, 2008 | Dell E153FP 15" LCD Monitor
Sony KP-57HW40 Error Codes 6 & 8
ITS PROBABLY THE RED PICTURE TUB (CRT). IT LOOKS EASY TO INSTALL, BUT YOU NEED TO MAKE ADJUSTMENTS TO THE SCREEN ONCE IT IS INSTALLED. THE PART IS $3OO. TRY TO FIND SOMEONE TO INSTALL IT FOR $150 OR LESS. HERE IS A WEBSITE TO HELP YOU MAKE ADJUSTMENT IN THE FUTURE ON YOU OWN.
PRIDAH
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 10, 2007 | Sony KP-57WS500 57" Rear Projection...
Flashing monitor
the ram itself is not related to your problem, but check the VGA lead connections at both ends and see if the connection is loose and also check the power cable. Other than that it may be the monitor circuitry or CRT itself thats the problem and after warming up the problem goes away, so a repair may be needed or a replacement monitor.
Jul 13, 2007 | Acer AC 713 17" CRT Monitor
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
