Question about Nokia Cell Phones
Restore deleted pictures on nokia 5610
I bought a new nokia 5610xpress music... unfortunately it cames to be stolen. But I had many chance and we found it back after some weeks... But all the pictures I've made are (of course) gone.
As I plugged the phone in my PC, it is found and I can browse the folders.
I've some software for restoring datas, but they need to have a drive lettre... what doesn't give me my computer for my phone...
The pictures were saved directly on the phone and not on a card...
So my question : is it possible to set a drive lettre to the phone, so I can try to restore my pictures ? or do you know another way to solve this ?
my system : Window XP SP3
my phone : nokia 5610 xpress music
5 Suggested Answers
  • 26 Answers
SOURCE: nokia 5610 memory card
5610 back cover has a peg or spike that push down one pin on the right of the camera lens, if your back cover is not properly closed, warped or you have something (such as a spare simcard) wedged inside, the memory card will not be detected. To save the hassle to get a new cover, wedge something tiny on that pin before putting back your back cover. If this does not solve your problem, better send your phone to a service center.
Posted on Oct 22, 2008
  • 42 Answers
SOURCE: Can I restore deleted messages from a Nokia95.
you go at second last colum at your n 95 8gb massege box an delete this
Posted on Apr 04, 2009
  • 7 Answers
SOURCE: Nokia N70 restore to default how to get data back up
if he has successfully restored your phone settings it impossible to get you data back. But hoping for the best just go to your messages- settings-others-memory in use and select phone memory. its actually not possible for restoring the phone just playing with it or pressing buttons . it seems like his curiosity killed the cat. all my condolences with you.
Posted on Jun 09, 2009
  • 58 Answers
SOURCE: i have nokia 5610 xpress music , today i did
If you forget your memory card password, there is nothing either you or a service point can do. It is not possible to read the password from the memory card or from the device. Passwords cannot be disabled.
When you lock your memory card with a password, your device will remember it. Therefore, the device does not have to ask for the password every time you access the memory card. However, when you insert your memory card to another Nokia device, you are asked to re-enter the password. The password is asked because the memory card remembers the password protection settings, including the password.
Note: After you reflash your Nokia device and re-insert the memory card, you are asked to re-enter the password, as it has been erased from the device during the flashing process. You have to re-enter the password to get access to the memory card, and after that the device will remember the password again for future use.
If you have forgotten the password but you still want to try to use the memory card, try formatting it. If the formatting process is successful, the memory card is usable but all data on the memory card is erased.
To avoid unnecessary risks, write down your password somewhere and backup your memory card data regularly.
Posted on Jun 20, 2009
SOURCE: Cannot restore backup files (.bm3) on my SE w960i
Hi Guys,
I use SE W960i adn usually face these problem and I have over a period of time learnt these:
1) Try deleting any of the old version of backup that you may have from the backup manager (if you still need the old one then import them to your PC)
2) another usually reason may be that you are trying to restore a lot of stuff at once so may be try restore only setting, multimedia, contacts, at first and the rest later.
These things worked for me, hope it does for you also,
Cheers Aravind - reacharavindnow@gmail.com
Posted on Jul 21, 2010
Can u restore deleted pics stored to phone memory on nokia c3?
unfortunately, the answer is no.
You cannot restore deleted pics.
Phones do not have recycle bin like computer.
Once any file is deleted from a phone, it is wiped off and gone forever.
I hope the above is clear.
Regards.
Sep 12, 2011 | Nokia C3 Cell Phone
I accidentally deleted all photos from sony camera..how can i restore these photos?
First of all remove the card from you camera as the more new pictures you take the less chance there is of recovering the old ones. do not worry though as you will be able to recover at least some of your pictures fro the card using a free program called recuva(linked below). download and run recuva and use the instruction on the website and you should have most of your data back in no time. please feel free to let us know if you need any more help with the use of the program.
http://www.piriform.com/recuva
Jun 17, 2011 | SanDisk 2GB microSD Memory Card
Nokia 5610 xpress music camera on standby
Use factory reset (remember to backup your data) which u can find under settings if this does not work then i recommend you to update your phone's firmware version.Steps for updating firmware version is as follows:
To connect your phone to a PC:
Fully charged, compatible Nokia phone
Compatible Nokia USB connection cable
Compatible USB port on your PC
Step 2/2: Back-up data
Personal data such as contacts, photos and messages stored in the phone memory will be deleted during phone software update. It is strongly recommended that you backup this data to your memory card before updating your phone software.
To backup to your memory card:
select Tools > Memory from the main menu
select Options > Backup phone mem.
To restore info to phone memory:
select Options > Restore from card
Now use any link below to proceed with the update
http://europe.nokia.com/A4577225
http://europe.nokia.com/softwareupdate
If the problem still persists, take your phone to your local Nokia Care Centre for them to have a look
Feb 06, 2011 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
My nokia 6300 keeps saying memery full unable to receive messages ive deleted all i can
You will have to restore the factory settings of Your phone to be able to stop this problem. Since deleting all the messages did not solve the problem. First of all, be sure that the message you are trying to receive is not a multimedia message, like pictures, music/songs and videos, because those files require a larger space to be able to receive such messages.
To restore The factory settings of Your phone,
  1. Properly charge Your phone,
  2. Go to the menu,
  3. Select the settings,
  4. In the settings, scroll to restore factory settings,
  5. It sometimes prompts You for the phones security code,
  6. Enter the security code of the phone,
  7. A page will come on showing a loading page, once it has completed its loading,
  8. The phone will be restored to the way it was when You first bought the phone.
Hope this was helpful. Thank You for using FixYa!!!
Hope this information helped You. Thank You for using FixYa!!!
Jan 12, 2011 | Nokia 6300 Cellular Phone
The program has deleted its self but my laptop has not been booting up properly and running at crazy funcations if I do a basic restore would it delete anyy photos or music on windows pictures and media
no it should not delete any of photos or music depending on your restore point make sure that the restore point has your photos and music also it is reversable you can choose another restore point in xp pro
hope this helps
Sep 24, 2010 | Computers & Internet
Deleteing music on ipod shuttle
unless you used the same computer when downloaded music, then you should be able to delete. Otherwise, you need to sync new music. It will erase all of the other music that is in the shuffle. this really sux. i had that problem. Couldn't even keep the same music.
Aug 04, 2010 | Apple iPod shuffle MP3 Player
Nokia 5610 earphones not working
probably try changing your headphones and put a new headphone and try
Mar 26, 2009 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
Reinstalling Vista and Acer Tech
The restore disk should be available from Acer Suppport here https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer if they no longer support it then you should be able to get it from restoredisks.com
Feb 08, 2009 | Acer Aspire 5610-4648 Notebook
No unlock code for Garmin Nuvi 660
Sorry but that is a security feature. There is a chance you've purchased a stolen unit from ebay. Unfortunately, only Garmin can unlock it and they will require a receipt from a Garmin dealer.
Jan 10, 2009 | Garmin Nuvi 660 GPS Receiver
Cell Phones Logo
Top Nokia Cell Phones Experts
IT Solution
IT Solution
Shehu Pro
Shehu Pro
