Question about Mercury Marine Mercruiser Gen Ii Alpha I V6 4.3 Outdrive
Why does my mercruiser 4.3 sputter and backfire after hot
After the engine has been running and it is hot, if I slow down and then give it gas again, the engine sputters and backfires. it does not quit. but I have to speed up slowly through the sputtering to get up to cruising speed.
    Habit-Forming:
  • 76 Answers
It sounds like a fuel vapor lock, check that the fuel line to the carb is not coming contact with any metal surfaces of the engine for this will boil the fuel in the line before it enters the carb. If this is the case, just stand the fuel line off from where it is touching. I hope this helps....GOD BLESS....Randy...
Posted on Nov 07, 2017
Why is it hard to start my Mercruiser 7.4L MPI after a hot run?
Electric choke? Try retrofitting a manual choke. I think the electric choke is closing over a hot engine, thinking that the engine's cooler than it really is. A manual choke will allow you to start it with no choke at all when you know the motor's already warmed up.
Jul 25, 2014 | Mercury Marine Mercruiser 350 - 454 - 5.7...
Why does the engine slows down when engaging the blade
check fuel filter and pump pressure starving for gas
Jul 02, 2014 | John Deere Garden
Sputtering and stalling
Have the fuel pressure tested, running out of gas will destroy the fuel tank moumted fuel pump or cause it to run slow with the resulting loss of power.
Dec 15, 2013 | 1999 Saab 9-5
4 wheeler backfire on start
incorrect air fuel mixture or a leak check for damage to the intake boot or airbox
i need to know more about how its running at low mid and high rpm to help you troubleshoot and you need to check for leaks especiely the intake boot if the intake boot is leaking that will need to be fixed before running the bike asumeing that is ok or fixed run the bike listen to it at idle standing is it surgeing with a good fast acceleration off the line with you siting on the quad ? or just realy rough ticking over with little guts off the line ?
midrange rideing how does it feel is there a bwarrr noise as u accelorate hard or does the engine roar up fast
is it reaching a good top end with good pulling power or poor pulling power
are the backfires constant or mainly whyle slowing down from high revs
if all are effected but there are no leaks then it may be float / fuel level that needs ajustment fuel level in ur float bowel effects all stages of rpm low mid and high
A rich problem gets worse as the engine heats up.
A lean problem gets better as the engine heats up.
hope this helps if u dont fix it your self first try and do them little rpm backfire tests for me itl tell me a lot
Dec 05, 2012 | Yamaha Motorcycles
Vanguard V Twin 18 hp. monted in Cushman Motor scooter, runs great at W.O.T and at on quarter throttle, misses at range inbetween
Sounds like your carb needs the fuel/air mix adjusted..uses all the gas at high speed but has excess at low speeds...find your adjusting screw and at med throttle slowly screw it clockwise until the engine starts to sputter then back it out until it starts to sputter again then continue to do this until you reach ideal mix where it runs the best it can..then go slowly through the throttle up and down..when set..unjust your idle speed screw to your ideal idle speed..if this dies not fix ..carb will bed cleaned or rebuilt. Good luck.. Note always push or pull your throttle handle slowly to position avoids gas load up causing sputter and backfire.
Mar 15, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Engine backfires then sputters and dies
Sounds like your culprit is the fuel pump my friend
Mar 30, 2010 | 1993 Chevrolet Suburban
93wrangler6cyl,auto when cold backfires, sputters until warms up
Check EGR value, clean or replace. Also PCV valve replace it is cheap.
Dec 16, 2009 | Jeep Wrangler Cars & Trucks
93 buick lesaber car ran fine engine locked up so
have you checked firing order on plug wi92717856res? could be problem.
May 05, 2009 | 1993 Buick LeSabre
Vn800 running fast on tickover
I am not sure what you mean on the "running fast" statement. If idle speed then turn the idle screw outward to slow down the idle.
The backfire is caused by turning off the ignition key when the bike is at high revs. let it idle down THEN turn it off. The backfire is there because the carb idle circuit is active anytime the piston is in motion. Gas goes into the cylinder as the bike revs down then a hot spot in the exhaust pipe finally ignites the built up gas. There is your backfire.
Is the running fast question answered? Give me more information on the problem if it isn't.
Please rate this answer. Thanks njv6!
Apr 15, 2009 | kawasaki KX 250 Motorcycles
Mercury Marine Mercruiser Gen Ii Alpha I V6 4.3 Outdrive Logo
1,749 people viewed this question
Top Mercury Marine Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Mercury Marine Science and Laboratory Expert? Answer questions, earn points and help others
