Question about Acer Aspire 3000 Notebook
Aspire 3000 HELP PLEASE IM GOING INSANE!!
My problem.......
I was downloading updates, when the wifi stopped working. Several attemptrs to repair it resulted in...still not working! So I put the ethernet cable into the side and wayhay it worked, so went back to updating. About 2 hours later of internet surfing, the ethernet stopped working! After several hours of trying to solve the problem I gave up and formated the drive. Put good old xpS2 back in, went and got all the drivers off acer's site every thing checks out ok in sytems, no nice yellow conflicts, yet i still cant get it to open a web page. If I search for a wireless point it cant find any, yet the wireless says its got good signal and speed is showing 54mbps, the same happens if i use the ethernet side, it shows its connected at 100.0mbps but i cant get on any web pages and if i use the network setup wizzard it says a network cable is unplugged!! go figure, as it showing its connected. If I go to a web page I get http 404 error, oh and check to see if its unpluged!! der!! its pluged in you stupid ********** laptop!! lol It seems no matter what I try I can't get it to go on the internet....any ideas folks?!?!. Thanks in advance for your replys.
Ady
  • 3 more comments
  • ady_genesis Dec 07, 2008
    HI
    Nic
    Here's the spec's
    mobile amd sempron 3000+ 1.8GHZ 448mb ram
    ill go to that site and download them onto to my desktop then burn them to disc so i can put the files into the laptop.
    Ive got it to find the wireless conection now but it wont connect to the server ive been on acer's site again and dowloaded all the files i needed and still no joy STRESSED LOL
    Yep correct drivers of acers site no conflicts in sytem hardware kinda got to the stage of chaseing me own tail lol
  • ady_genesis Dec 09, 2008
    Hi
    JT
    Still got the problem ive updated the java re installed ethernet drivers wirless drivers got that to work at least that some thing but i still cant get it to accsess web pages it says its connected and it doesn't make any diffrence if it's on wireless or ethernet the strange thing is if i load bt broadband disc you get a section that tests the router on the ethernet after its done it says it cant find the router and go's onto say about checking your ip address setting are set to auto mine are i just checked but it still cant find the router yet my desktop is on the same router as i type this sa lol any ideas JT
  • JON T
    JON T May 11, 2010
    THERE IS A CONFLICT WITH TWO THINGS ON YOUR LAPTOP FROM WHAT YOU ARE DESCRIBING, YOUR JAVASCRIPT MAY NEED TO BE UPGRADED FOR ONE, I HAD THE SAME PROBLEM ON A ACER ASPIRE 5050 AND THE EUROPEAN SUPPORT SITE HAD THE PROPER DRIVERS AND FIRMWARE UPGRADES THAT I NEEDED, ACER IS A EUROPEAN BUILT COMPUTER SO GO TO WWW.ACER.COM/EURO FOR THERE EUROPEAN OR UNITED KINGDOM SUPPORT WEBPAGE, GO TO WWW.FILEHIPPO.COM AND GET "JAVA RUNTIME ENVIOURNMENTS 1.0, 2.0, AND 3.0 IN THERE DRIVERS SECTION, EVEN THOUGH YOU RE-FORMATTED WINDOWS DOE,S NOT HAVE THESE APPLETS BY DEFAULT WHEN YOU RE-INSTALL. MOST WEB PAGES GO BUY JAVA SCRIPT AND HAVE APPLETTS THAT ONLY ADOBE FLASH PLAYER AND THESE PLUGINS CAN RUN, YOU DEFINATELY HAVE A DRIVER CONFLICT, ALSO LET ME KNOW WHAT PROCESSOR AND MEMORY YOU HAVE BECAUSE IF ITS NOT ENOUGH THIS CAN CAUSE PROBLEMS TO... JON T
  • Nicolas
    Nicolas May 11, 2010
    Are you sure you installed the right drivers for the ethernet card?
    It sounds like the problem is there
  • 20 Answers
Inside the advanced payne for your wireless setup in windows try setting it for "infrastructure networks only" as follows, you should see an icon to the right of your screen thats looks like a little computer with an x or small waves to the right of it, click that, when the little menu pops up hit "veiw available wireless networks", then hit "change order of preffered networks" now when that menu comes up hit the advanced tab that you see to the right, now you should see three choices, check off the second one " infrastructure networks only" , close that then on the other menu hit close again, when you see that icon with small-dots under it it is aquiring your network adress click onto it again and hit "veiw again like i said earlier and see if there is any networks there with alot of bars, if you named your network it should come up on that payne hit connect and see if it connects then if not then i will show you how to name and secure your network through your router ...jt
Posted on Dec 11, 2008
    Scholar:
  • 86 Answers
Forget about the wifi for now and connect via an ethernet
go to start/run and type cmd and enter
in the next panel type ipconfig and enter
If the router is connected to the computer
the information displayed will give you the IP address of the router
note the lower set of figures eg 192.18.2.2.
Open a browser window and type the figure set in the url bar and hit enter.
If all is well with the ethernet connection this should now display access to the router firmware. If it does then that proves you have a connection between the laptop and router.
if you have that connection then check that your digital line is actually working by running any diagnostics you find within the router firmware. Usual router default log in is admin admin, admin password or with sky ite admin sky
Posted on Dec 09, 2008
  • frank murray Apr 06, 2011
    have a acer 3000 and my wireless button and light both not working have to plug in cable to get online any clues how to fix it tried everything
I need a wireless connection on my acer aspire 3000. I also need a PCI Modem and USB Controller DRIVER. Please how do i get these free. Thanks.
Hi, you may download the drivers through this link:
http://www.driverstock.com/acer-aspire-3000-driver-download/4-21-12851/index.html
You may want to update all your drivers, just click on "start download"
eibraz_17.jpg All the necessary drivers for your Acer Aspire 3000 is here. I hope this helps.
Aug 06, 2011 | Acer InviLink 802.11b (91.49C10.002)...
Dont work any sound
If you have the cd installer of the acer aspire 3000 PC. Insert it to your cdrom drive and the autoplay will execute and load the cd installer. Install only the audio driver so that your hardware will be fix.
In case you do not have the cd installer, you can also download the driver installer from their official website and install the audio driver after downloading or visit this acer support website.
After installing the audio driver but still no sound, download this codec this will play all the multimedia format. Click this link and click the download latest version for mozilla firefox browser click save, for internet explorer after clicking the download latest version click the (To help protect your security) then click download file then click save button. After downloading, install the program just next, next and after installing play any multiplayer format. Have a nice day.
Apr 04, 2011 | Acer Aspire 3000 Notebook
How do i reset the wifi password on my PSP 3000?
hmm im guessing you update the psp!! just try to update unless its 6.0 or upto date already so yeah try to update and it may work im not saying it will tough and if it does please leave positive feedback
Jan 17, 2011 | Sony PSP-3000 Black Console
Laptop WiFi card stopped working
Well, again, if it doesn't work, connect your laptop to the internet via an Ethernet cord, and download any updates you find at Windows Update. Continually do that until no more updates show up.
Jul 29, 2010 | IBM Computers & Internet
D:my phone just wont turn on please help me im going insane :(
First of all please indicate the mode or phone unit next time. Here's my tip have you pressed the power button longer than 24 seconds? If you have and it still not turning on try it while the charger is plugged with it. If it still not turning on then contact the companies technical team department so they can assist you if your unit still have warranty you can exchange the unit to them for a brand new or refurbished one.
Aug 07, 2017 | Samsung Memoir SGH-T929 Cell Phone
I just put XP Pro on my Acer aspire 5050 and I downloaded all the drivers and my wireless internet will not work.
If You downloaded the correct wifi drivers and still didn't get wireless...
Choose a different series... Try acer aspire 3000 wifidrivers... then Acer Aspire 5000 wifi drivers, if still no luck... Choose the acer ferrari 3000 wifi driver.. or the acer travelmate 5530 wifi driver/..
I've had alot of Acer Aspire models.. including yours... and I too would have to jump around to different models to get all correct drivers,...
Dec 15, 2009 | Acer Aspire 5050 Notebook
I've lost my WIFI drivers on my Acer Aspire 3003LC.
go to device manager then network adapters then right click on your wifi device and select update drivers and tell the wizard to search online for drivers device manager is located:right click on computer(mycomputer)-->properties-->device manager:steps are a little different in xp but about the same.it is important to put in your operating system
Apr 23, 2009 | Computers & Internet
Please Help -- Acer Aspire 3000 Wireless Stopped Working When I R
If your wireless network adapter is OK then :-
If your wireless connection is on the Task Bar the right click on this Icon and left click on REPAIR.
If no Icon on Task Bar the click on Control Panel - Network Connections - then right click on your LAN Connection and left click on REPAIR.
This will get your wireless router to issue your wireless card with a new IP address.
Apr 22, 2009 | Acer Aspire 3000 Notebook
NX-3000 Flickering Problems
check your display settings and make sure the color is set at 32 bit true color. Do this by going to your desktop screen, right click, then click on the 'settings' tab and make it as high as possible. try that first
Dec 01, 2008 | Microsoft LifeCam VX-3000 Web Camera
I av reistalled windows xp to my acer aspire 3000 laptop and how my wifi wont work how would i fix this thanks
you will have to install the driver for wifi please go to microsoft.com and type wifi driver in the search box and download the driver > restart the computer and it should work
Aug 14, 2008 | Computers & Internet
Acer Aspire 3000 Notebook Logo
193 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
