Got a goodmans lcd tv model GTVL32W27HDF , it has started flickering a lot, i am told due to backlight issue probably, how much to repair this////
    Genius:
  • 2,920 Answers
Have the video board checked
Posted on Dec 07, 2008
Fuse keeps blowing on power board. It is the 3.15 amp fuse on the goodmans xpro tv
Most likely you have a short on the front side of your power supply. You will either need to have it repaired or replaced!
Oct 22, 2012 | Goodmans GTVL32W27HDF 32 in. LCD TV
I have a vestel tv but screen changing to bleu red green how can this be done
The problem you have described occurs due to a faulty LCD controller(T-CON) board. The board is inexpensive(costs around 40$) is easy to replace. Let me know if you wish to do it yourself so that I can help you find a replacement part and fix it.
Aug 14, 2011 | Goodmans GTVL32W27HDF 32 in. LCD TV
Sound but no picture on my goodmans 32inch lcd tv was working ok then screen turned off
The LCD backlight is faulty. it may be due to bad capacitors or a faulty inverter controller. Bad capacitors can be easily replaced. A faulty inverter controller is a bit more tricky but it can also be replaced.
Mar 01, 2011 | Goodmans GTVL32W27HDF 32 in. LCD TV
I've owned a Vizio VT420M for just over 13 months. About a week ago the tv started flickering when I turn it on. The picture is visable, but the area around the actors is flickering. After about 7 to 10...
The flickering is most likely due to a faulty fluorescent backlight. Once the bulb heats up the flickering usually goes away. Some bulbs are easier to replace than others so I would contact your local TV repair shop.
Mar 01, 2011 | Vizio VT420M LCD TV
Hello, I have a Goodmans TV.model no GTVL32W27HDF. I need a remote control and an instuction manual.Where can I purchase these.I live in Wolverhampton England. Thankyou. kennypage@hotmail.co.uk
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Jan 13, 2011 | Goodmans GTVL32W27HDF 32 in. LCD TV
Red standby light is on (Goodman flat screen). When remote is pressd light light flickers as normal but t.v. does not come on. No picture. No sound. Screen does not even light up.
Kept trying to switch on, then mid-afternoon it worked. Had already phoned repair man and phoned back to cancel. He said that it may have been due to the extreme cold during the night and once the room warmed up it was O.K. Whatever, it is still working. Does that make sense ?
Jan 08, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Sound but no picture on my goodmans gtvl32w17hdf lcd tv
MY GTVL32W17HDF TV HAD NO PICTURE BUT SOUND, SWITCHED IT OFF THEN ON, NOW IT HAS NOTHING
Nov 21, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
Goodmans gtvl32w27hdf - screen is flickering and picture is darker than it should, but sound is fine. Have tried turning off and on. doesn't matter what channnel you're on and its the same for video so i...
It is most likely the screen backlight. LCD TVs have thin fluorescent lamps and a part called an inverter board which is a transformer similar to a light ballast.
Inverters are typically a $50-100 part and are trivial for any technician to replace. The backlight lamps themselves tend to go pinkish when near the end-of-life, and are a low-cost part, but it requires a lot of work to change the lamps.
IF the LCD display itself is good, then the screen image should remain perfect and undistorted...if the backlight fails altogether, you should be able to see the image by shining a bright flashlight directly on the screen (only as a test, not as a long term solution, obviously :) )
Oct 16, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
