Question about Neff 24 in. S5456 Built-in Dishwasher
Pumping out continuously part 3
The part i thought to be the solenoid was a motor with an impellor on it (water pump) so i haven't got a clue where to look next for the solenoid can somebody please advise me? thanks and kind regards shacarmaman
  • dave frizzell Feb 25, 2007
    this was the exact problem but now i have a further problem with dishes not drying properly and program does not finish completely it sticks on 1 minute left ?? please can anyone help??
  • 30 Answers
It sounds like its in flood mode. the dishwasher will pump out all the time. Remember a dishwasher will always pump out at the start to find its water level, second step is incoming water. If its not doing the first two step you will have to pin point the problem??? Check to see that no water is lying on the base of the dishwasher???
Posted on Feb 25, 2007
My grundfos200 sqflex displays a couple of dashs and a 3. What is wrong?
check that the impellor is not seized or that there is not water in the motor.
Sep 08, 2014 | Cars & Trucks
Ge 2800 dishwasher
Try to start the pump with a kick on blades. If it starts, the start capacitor is broken.
Nov 18, 2017 | Dishwashers
Canot get the diswasher to drain. Tried CLR-no
Hi, please check to make sure which style d/w you have as outlined above. The direct drive dishwashers have a drain solenoid attached to the motor and pump or a separate drain valve that must be checked with a ohm or volt meter. The drain solenoid and valve energize and opens the drain port to allow the water to pump out. For a "no drain" problem, always start with the common stuff first...a kinked or clogged drain hose. The drain hose must be checked and cleaned out and if you have to, remove the drain hose(s) to fully check and clean them. Don't forget the drain system sometimes consists of a self cleaning body that also can get clogged and stop the dishwasher from draining. If your drain hose needed to be lengthened a hose connector was probably used, these hose connectors are slightly smaller than the drain hose and food bits often get clogged there, also the tail pipe piece that connects the drain hose from your d/w to the house drain is also another popular place to get a clog. On the forward/reversing style of dishwashers that won't drain, make sure the motor is reversing to drain the water out. If the motor does not reverse to drain, the motor, wires ( especially where the doors bends to open and close ) and timer will have to be checked. If the motor is reversing and running, the pump impellor inside the motor and pump assembly may be damaged and is incapable of pushing the water out to drain. If the drain solenoid or drain valve checks ok on the direct drive motor and pump, the impellor inside may also be damaged as mentioned above.
Always check the drain spout under the sink for a d/w that will not drain, also if the Air gas is leaking this is a clogged air gap or drain and normally not a d/w problem.
Feb 22, 2010 | GE Nautilus 24" Built-in Dishwasher
Asko D1706.The washing arms have stopped turning.
Can you hear the motor running? If the motor is runningand machine is full of water, but not pumping water around, you have one of the following problems:
-a blockage in the filters or sump preventing enough water getting to motor impellor,
-blocked jets in spray arms themselves,
-or I have had cases where the impellor has broken off the motor, hence motor runs but doesn't pump any water around. Check for blockages first, wouldn't suggest you take motor out and disassemble unless qualified or confident to do so (it's not an easy job if you haven' done it before!!)
Aug 04, 2009 | Dishwashers
The pump only hums when plugged in. Any suggestions?
It sounds like the impellor is locked. Take this part off and then see if the pump is turning but before you do, some of them have a big screw driver slot in the shaft. If it does, turn it to see if you can free the impellor. I have done this many times and they will continue to work for years after. They just get stuck from rust, etc. and also being frozen a little. Hope this helps.
Jul 06, 2009 | Hayward 1.5hp Pool Pump Motor Motor A O...
MIele waterproof system reacted
That means that there is a leak that passed throught the waterproof system, and the water protection system had reacted putting the machine on error mode, as the water can damage electric parts, and cause serious hazard.
Sometimes you can reset the error by unplugging power cord, however you should call immediately a technician, as using the appliance when there is a problem with the waterproof system, you can be seriously injured by electric shock.
Operating instructions for Washing machine W 3923 WPS
Nov 16, 2008 | Washing Machines
Water not draining
Usual causes are: 1. Something in the drain path blocked. Symptoms: You can hear the drain pump running at the appropriate bits of the cycle, but if you you open the door the instant the pump stops, there is still a pool of dirty water in the bottom. Solution: Follow the path from strainer through drain pump to drain hose, find and eliminate the blockage. Most likely points are the strainer and the inlet to the pump. Hint: You can identify the drain pump by following the drain hose and seeing what it's attached to. 2. Drain pump broken. Symptoms: Usually, you won't hear the pump running at all at the appropriate times; if it does run, it won't sound right. Solution: Take it off and open it up, see if something is blocking the impellor (in which case, fish it out). Spin the impellor with your fingertips; If it won't turn at all, you need to find out why it has siezed (may be fixable) can you feel it turning the motor (a very magnetic, "flippy" sensation). If you can't, the impellor has probably become unstuck from the shaft. You may be able to glue it on, but this fix is unlikely to last very long. Use a multimeter to measure the resistance of the motor windings. If madly different from a few hundred ohms, again a new motor might be necessary. Hint: The pump motor and impellor can usually be bought separately from the pump housing as a much cheaper unbranded part. 3. Back-siphoning from the waste plumbing. Symptoms: You can hear the drain pump running normally at the appropriate times, and if you open the door the instant the pump stops, the machine appears to be empty, but then quietly fills up with dirty water. Solution: There is meant to be an air break (or in some installations and anti-siphon valve)where the machine's drain hose enters the domestic drainage drainage system. Unblock/unjam this. Hint: After fixing this, run the machine empty on the hottest, longest cycle it has; some of that dirty water may not originally have come from the dishwasher. A.
Apr 21, 2007 | Candy 24 in. CD623 Free-standing...
Neff 24 in. S5456 Built-in Dishwasher Logo
140 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
