Question about HP Officejet 6310 All-In-One InkJet Printer
I can't install my HP 6310 to my computer. It goes just so far, and then hangs forever and doesn't install. Does my USB port need to be updated?
  • 1 more comment
  • father_tom Dec 26, 2008
    I've been searching for an answer to an issue that is nearly identical.
    1. Using the drivers provided on the disk or downloaded does not matter in my experience.
    The symptoms:
    Stick disk in or install from downloaded files.
    - The install starts but is extremely slow. It goes into the 2nd step of 4 saying "Overall Progress - Preparing to Install (Step 2/4) 94%"
    My computer laptop has been running for 4 days and its' at 94% which is beyond ridiculous.
    Computer Specs:
    Dell D620 dual core processor
    160 or 180 gig drive
    4 gig ram.
    the other symptom is the speed at which the driver says it is operating at as it is "Searching for installed applications" ranges between 2KBps and 9KBps.
    I just don't understand it.
  • axiagramps Jan 03, 2009
    I have the same issue as Fr. Tom. I have Dell D620, the HP software load disc just hangs. I have tried dis abling firewalls to no avail. Also direct download from HP website seems to just start the same ridiculous slow process.
  • father_tom May 11, 2010
    1. I installed the drivers for the printer a while back, and it didn't take this long, but now I am trying to install the entire software package for the 6310 Officejet All-in-One so I can use the scanner and other picture software, namely the scanner.
    Frankly I'm loath to stop the install process after 4 days with the suspicion that it's going to take longer if I abort it now.
Try removing the printer (i.e. disconnecting the usb or network cable), then uninstalling the drivers in Device Manager (ignore any warnings about being unable to use the device, etc). Next, remove the logical printer icon from My Printers.
Then try a fresh install following the instructions precisely and in the correct order and see if that helps.
Is this hooked up to the network or usb? Did you install it with usb first and now trying to change to network cable?
Good luck.
Posted on Jan 23, 2009
    Guru:
  • 558 Answers
Have you connect it prior to installation? Is the Setup Disk is new and have you checked it if not worn out with any scratch on it. Check also if you get any error message of missing file in it.
If the CD is culprit, Go Online to download the Software and Driver for your Printer.
For more info check out my Tips posted on FixYa: Driver and Installation problem?
Posted on Dec 07, 2008
My 6310 will not print from the computer
Might be printernUSB port faulty, remove USB cable from the printer end, un install the drivers from system, re connect the cable. If system found new hardware, run the drivers, if printer not recognized, definitely its printer mother board faulty...
Dec 22, 2011 | HP Officejet 6310 All-In-One InkJet...
My HP OfficeJet J6450 stopped working after getting a paper jam. It is connected with a USB cable. I have tried deleting the printer and reinstalling the software without success. The software...
When installing the printer click on local printer and uncheck the box below it. I think it says something like locate my device. then on next screen click create new port, you should see USB001 in there.
Jun 09, 2011 | HP OfficeJet 6310 All-in-One Printer...
HP Pavilion zv6000: USB ports are inop. USB port on rear of computer works fine. USB port on left/front will power my flash drive, but the light stays on constantly. The flash drive is does NOT show up in...
After reading the description, I think you need to try updating BIOS and latest device drivers for USB. Because USB are getting power on that means there would not be any fault to from the motherboard.
So please try updating latest BIOS for your notebook.
If you can provide me the product no for your notebook and the operating system which you are using currently then I can find the one for you.
Otherwise you can also do the same.
Type in the product no. on www.hp.com. Then go to software and driver download page, select the proper OS and search in BIOS ROM pack available for your notebook.
I hope this will help.
Jun 11, 2010 | HP Pavillion ZV6000 Notebook
HP Officejet 6310 drivers will not install
When you install the printer wait till you are prompted to hook up the usb cable. If you hook it up sooner that is the problem. You can have the usb cable to printer but not to the computer. Then run your install disc and you should be fine.
Mar 01, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
HP KQ246AA USB Web Cam causes hang on boot
1) I guess the problem is that u need to install the patch and try, u can download the patch from below link and follow the directions
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?os=228&softwareitem=da-66961-1&lc=en&dlc=en&cc=uk&lang=en&product=3737180
else
Unistall the drivers and reinstall the drivers again it will work and Update windows xp sp2 to service pack 3
Dec 29, 2009 | HP KQ246AA Deluxe Webcam
My HP 6310 printer / fax is too far away from the phone line. Is there a way to fax wirelessly using this printer?
Only if you have fax software on your computer and scan an image to the computer to fax, otherwise you need a really long phone cable you can buy at Radio Shack or Best Buy.
Oct 29, 2009 | HP OfficeJet 6310 All-in-One Printer...
I need to install my new HP Officejet 6310 and set it as the default printer . I don't have a Installation CD Rom
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER WITHOUT CD-Rom
STEP 1: In your computer window click the Start button and select the option Devices and Printers.
STEP 2: A new menu Devices and Printers appear on the screen. Then click the option Add a printer.
STEP 3: After clicking the Add a Printer option two options appears on the screen.
Add a local printer
Add a network & wireless or Bluetooth printer.
Select the option that suits to your printer
STEP 4: If your printer is not a wireless then select the Add a local printer and select the option Use an existing port then click next.
STEP 5: Scroll down to select the HP in the manufacturer section.
STEP 6: Select your Hp printer model in the printer section then click next.
STEP 7: If your model number is not present then click the windows update it will automatically add your printer model.
Note: You must need internet connection to update the printer model to your computer.
STEP 8: Then click next and finish.
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER FOR WIRELESS CONNECTION:
Add a local printer
STEP 4: Select the option Add a network, wireless or Bluetooth printer and click your printer name and address.
STEP 5: After the HP officejet 6310 printer installation of your wireless printer next step is to add your printer name and click next.
STEP 6: Set default printer as your HP Officejet 6310 printer and select the option print a test page.
STEP 7: A new popup window appears on the screen, then close it and finish.
Jun 11, 2009 | HP Officejet 6310 All-In-One InkJet...
"NO SCAN OPTIONS" in HP Officejet 6310 all-in-one
You need to install the software and driver for the version of windows that is on the new computer.
Link to you model printer/scanner below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1119598〈=en&
Mar 19, 2009 | HP OfficeJet 6310 All-in-One Printer...
All in one 6310 -- reset power with lights
Normal 0 This doesn’t help fix all printers because each situation is different and in most cases we don’t have enough information to determine the fix. So hope this will provide some help.
Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 29, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
391 people viewed this question
Seeker5211
Seeker5211
