Question about Janome Memory Craft 10000
Bobbin thread won't pick up and tangles up in a mess.
It seems to happen when the bobbin is half full. The machine starts making a clicking sound and a stutter.Then the balled up mess underneath. I took it in for cleaning and told them what was happening but obviously they didn't check it. I have rethreaded the top of the machine, have removed the bobbin and put it back in and have put in a new needle. When the bobbin is full it seems to work fine.
  • Anonymous Dec 24, 2008
    I can't fix your problem, but I feel for you. I took my machine in- they did not even call and tell me when it was ready. They told me they cleaned and realigned it. Well, if they had cleaned it there would be no lint in the bobbin case. $110 and 10 days later took it back to the shop with thread balling on the under side. Now it is 3 days later and no call and when I do call they act like I am bothering them... Can't wait to get it back hopefully fixed and I am finished with this dealer....
    Hope you got yours fixed...
    President:
  • 2,692 Answers
Here is the Janome website with many good FAQ.
I had previously read thet the bunching on the bottom of that fabric is caused by the tention on the bottom thrread is not enough . Increase the bobbin tension slightly. You may have to download a manuaol to learn how,if you don;t alrewad have one?
http://janome.com/index.cfm/Search
Posted on Jan 07, 2009
Singer advance 7422 bobbin jumps
Did you get it fixed? Here is a video that may help.
Mar 20, 2014 | Singer Advance 7422 Electronic Sewing...
LS-1520 Brother sewing machine hook pick thread up takes it around half way and gets stuck...any ideas. the timing seems to be right??!!
try changing needles
clean under the needle plate & in the bobbin area for loose thread or lint
make sure the bobbin is inserted into the bobbin case correctly--if the
machine won't pick the thread up from the bobbin correctly take the bobbin
out of the case & turn it around & try it that way.
Apr 13, 2012 | Brother LS-1520 Mechanical Sewing Machine
Bobbin thread tangles
when this happens have you check to see if the thread has come off the thread take up lever?
Feb 09, 2012 | Brother CE5000 Computerized Sewing Machine
My Brother XL-5021 sewing machine has stopped working and won't pick up the thread from the bobbin.
it's called being out of time,,and the machine can only be timed by a sewing machine repair technican,, because they have the tools for job
Feb 01, 2012 | Sewing Machines
The macine said it was an E6 error thread jam which I completely cleaned the bobbin area (not much there anyway) but I still cannot get it to not jam the thread on the botom. I have changed needles also.
Hello
This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
It could be that the bobbin is being put in upside down check to make sure that you do not need a bobbin with a magnet on one side. also make sure there is no thread tangled inside the bobbin housing it will cause the timing of the machine to be off and cause issues with your needle picking up the bobbin and thus cause a mess inside you bobbin housing
Jul 11, 2011 | Brother CS-100-T Computerized Sewing...
My machine is a designer 2 but I encounterd a problem with my stich getting all tangled. tryed to clean the bobbin case and under, stich is still tangling bad.
Be absolutely sure that the machine is threaded correctly, with the upper thread clicked into the tension discs (the presser foot MUST be raised when you thread so the tensions discs are open to receive the thread) and bobbin thread clicked into the bobbin tension slot. Change the needle - a bent or blunt needle can cause tangles. Hold onto the thread tails for two or three stitches when you first start sewing to avoid them being drawn down under the fabric and making a mess.
Dec 19, 2010 | Husqvarna Designer I
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled....
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled. I cleaned underneath the bobbin holder but it didn't help.
Oct 13, 2010 | Husqvarna Viking 1
Thread is tangling on the lower bobbin
check the needle first.Bent or spurred needles will result in this action.
May 30, 2010 | Brother XL-3510 Mechanical Sewing Machine
I keep getting an E6 error message - tangled thread. I think it's the bobbin thread that's getting tangled, and I can't figure out why, or how to fix it. Any ideas?
Apr 02, 2010 | Brother BC-1000 Computerized Sewing...
Bobbin thread
Make sure that you have your thread going through all the proper thread guides when winding your bobbin. It sounds like the bobbin is getting wound with little or no tension and this can make a horrible mess when trying to sew. Take a look at your bobbins and make sure they look nice and tight. If they are too loose and you feel like you are following the thread path properly, just use your finger to tug on the thread a bit during the bobbin winding process to apply some tension and that should help.
Jul 06, 2008 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
121 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
