Question about Polk Audio AMR50 Computer Speakers
My polk audio speakers volume wont go up
Polk audio speakers volume wont go up why
  • davykunz Dec 27, 2008
    i cant turn up the volume
I have 2.1 creative sound speaker .after system formattednosound observed.pse solve the problem.
Posted on Dec 09, 2008
3 Suggested Answers
  • 1584 Answers
SOURCE: my polk audio speakers the volume wont go up
Have you altered volume control in the PC to MAX.
Double click on little speaker in task bar lower right of screen and check that speaker volume is maxed.
Posted on Dec 20, 2009
Open SKy
  • 620 Answers
SOURCE: Polk Audio Speakers
hi Hubbell2008
And Happy Holidays
well, as you can see depending on your audio card, and output power, and sound settings on control panel, if is all up, or down.
you can try that first. But if not work is and Audio Card, type of power output, ....in that case you can change your audio card, if an onboard audio, place a PCI and will be ok, Creative labs models makes diff.
Posted on Dec 04, 2007
Polk audio sound bar 4000 comes on no sound
try to re-installing the driver .
if not solved , may be the speaker damaged .
May 25, 2014 | Polk Audio SurroundBar 4000 IHT Virtual...
My speaker volume is very low no matter what i play. All volume controls are up as high as they will go
Have you checked your system audio volume?
If you are using Windows XP go to Start menu -> Accessories -> Entertainment -> Volume Control
Make sure that the volume is set to the highest value.
Mar 04, 2011 | Polk Audio AMR50 Computer Speakers
I have a pair of polk audio speakers for my pc. They are 4 inches tall and 3 inches wide. There is no volume control on either speaker and would like to know how to raise the sound. Thank you,
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 08, 2011 | Polk Audio AMR50 Computer Speakers
How do I install Polk audio speakers on my computer?
plug the speakers into the speaker outlet usually at the back of a computer then
control panel sounds and audio,volume,advanced,speakers select the appropriate speakers
hope this helps
Oct 26, 2010 | Polk Audio AMR2 Computer Speakers
Hi, I have a pair of Polk RT1000i powered towers and one now makes a constant loud humming or buzzing sound. It is not hooked up to the receiver. It does it as soon as its pluged into the wall. Any...
the volume on the speakers are too high. try to put make the speakers the master volume(whatever device you plug in into your speakers make that device's volume go all the way up and then adjust the volume on the speakers to what ever volume you desire.had the same problem with my computer speakers
Jan 16, 2010 | Polk Audio RT1000I Speaker
My polk audio speakers the volume wont go up
Dec 20, 2009 | Polk Audio AMR50 Computer Speakers
Changed computer but using same speakers but no volume
Hello there:
if the volume controle is not on the taskbar try to go under controle panel and go to sounds and the adjustments for the speakers will be there. than click on add to taskbar and click apply when finished ok?
best regards mike
Aug 18, 2009 | Polk Audio Audio Players & Recorders
Exact same problem; low volume
1st check your PC if audio is fine with headphones or some other speakers , then check your control panel and test sounds compatibility might that you are using wrong speaker setting in the PC.
The below is the company web link to your speaker set , try this too
http://www.polkaudio.com/homeaudio/specs/recent/amr50/
if nothing works please msg me the exact config of ur PC
Aug 02, 2009 | Polk Audio AMR50 Computer Speakers
Open Questions:
Polk Audio AMR50 Computer Speakers Logo
544 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
