Question about Maytag MSD2756G Side by Side Refrigerator
Refrigerator caught on fire.
It sparked and caught fire at start device combination relay and overload.
Can it be fixed or are there other problems that may have caused this to occur.
Im a little reluctant to fix it, thinking the problem my reoccur when I am no
not at home and cause a major house fire. I had the same problem. Luckily the fire was contained to the fridge. Mine is six years old. I can't decide to fix it or replace the whole thing. I am waiting to hear from Maytag. Has this been recalled? I have read that this has happened to many people.
  • berubejjt Jan 11, 2009
    Our Maytag Model # msd2754grw Serial #21656578c9 Refrigerator caught on fire this morning. We were home, with kids. Unfortunately kitchen wall is black, and the house was filled with a bad electrical smoke smell. The bottom of the refrigerator had flames spewing from underneath and was minutes from burning down the wall behind it. Is this normal for a 4 1/2 year old appliance?
  • dawsoncrash Feb 25, 2009
    I woke up late this evening to the smell of electrical smoke in the hosue. I traced it to my Maytag MSD2754GRW fridge. Although I could see faint smoke in the air witha flashlight, there appeared to be no flames. I checked the motor and connections and found nothing hot or burned.
    Novelist:
  • 124 Answers
Tough call but. the entire start relay kit and cap can be replaced. it is usually surrounded by metal and if it does fail is not a major source of concern as far as a fire. stink yes, but nothing around it to flame up and cause a major fire. performance can be checked immediately after parts are replaced, and if it starts ok then you are as safe as you would be with a brand new unit if it had the same problem!good luck
Posted on Dec 07, 2008
  • bob7rob7 Nov 18, 2010
    There is a recall in the relay for this fridge. Call Maytag and they will replace!
How to get free ECU circuit diagrame complete with fuel injector?
helps to know what type of car. check body ground. if car was jumped with reverse polarity, can cause a wide variety of problems. it controls all parts of run. it uses senser data to adjust for best performance. water or fire damage can cause one or more items to not work in ECU. ICM is on distributor it controls fire, no fire ECU will not allow fuel injectors to open and close . this also can be injector relay . remember if ECM is not bad the relays it controls may be bad. one bade relay or senser can stop ECM, it is computer that is set to shut down if there is a problem with circuit, good luck. please let me know what the problem was if you get it fixed.
Jan 31, 2018 | Cars & Trucks
I already replce the new battery that also is showing in overload pls solve that problem
UPS in overload. Try removing some of the attached devices one at a time to determine which on is causing the overload... it may also be a combination of devices causing the overload.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Nov 07, 2013 | APC Back-UPS RS 1000VA UPS System
Every thing runs but the compressor wont fire i think its the compressor start up capacitor how do i test the capacitor
first discharge the capacitor for safetys sake,then touch the meter leads of a multi-meter set to RX100 to the caps leads if the needle stays on 0 the cap is shorted(but that would trip the wall breaker),if it doesnt move at all its open,if it goes to 0 and slowly climbs back towards infinity its good,i believe you will find the ptc overload relay on the compressor is defective,its in combination with the capacitor,the cap is only on there to take the power spikes off the relay contacts during start-up,the ptc overload relay is what aids in compressor start-up/run/and overload protection if compressor wont fire,change them both and it will run
Mar 22, 2011 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
When getting water from the front of the fridge there is a leak at the bottom from the hose...how do I fix it?
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. A hung up ice maker was the culprit for this overload most likely. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 10, 2010 | Maytag MZD2766GES Side by Side...
Pump humms and barely turns. Fan blade caught wire caused huge spark. wire has been replaced.pump does not really seem to get going and trips safety after a minute of running.
hi there!
short circuited at start damage motor compressor
if you have a service center for motor compressor have checked this one, motor compressor has thermal overload protection mostly on single phase motor inside the motor,in the absence of overload protector the winding of motor on start and running maybe shor circuited.this should be rewind by motor rewinder.check the cost of motor rewind to a brand new motor.have choose n it.have a nice day fix my rate.
May 07, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Bad overload relay
The compressor is usually fitted with a thermal overlload switch. It is usually secured to the compressor with some sort of spring mount so it maintains physical contact
The parts guy was probably talking about a hard start kit. They typically are a universal fit, and come with instructions. Be sure to check the electrical supply to the outlet for the fridge. Excessive voltage drop when it tries to start will cause such problems, and will eventually cause damage to the compressor.
Dec 16, 2009 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool fridge not cooling gone warm air blowing
more than likely the compressor is not starting, it has a starting device on the left side of the compressor which has a relay/overload called a relay, remove the relay and shake it , if it rattles it has gone bad. the relay/overload combination has gone bad and can be replaced with pro41 relay. if the compressor has a run capacitor just eliminate the capacitor when replacing with new relay. connection of the two wires makes no difference.
Jan 16, 2009 | Whirlpool GS6NBEXR Side by Side...
start relays smoking is a common fault and does not usually indicate a fault elsewhere. parts are reasonable cost so give it a try
Sep 25, 2008 | Refrigerators
Refrigerator stopped cooling
I have the same problem on my GE model :
GTS18FBMERWW
It is a 18 cu ft, top freezer model.
If you get an idea please let me know.
TK
May 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
HOTPOINT RLA30 FRIDGE
is the noise like a hum? touch the compressor if it is really hot, suspect relay/overload combination defective touch the little line that comes out of compressor if cold, suspect the above. if you change the relay/overload combination, and works fine there's your problem. hope to se of some help.
Apr 21, 2008 | Hotpoint RLA30 Compact Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
500 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
