Question about KitchenAid KERC507 Electric Kitchen Range
I would like to clean the inside of my oven window do I have to take the door off and remove the cover.
  • Anonymous Dec 22, 2008
    I lost my manual and need another one, where can I get one
    Habit-Forming:
  • 171 Answers
Yes, you have to take the frame off, to get to the inner part of the glass. many new stove doors can come of by puling the door up, and it will lift of the hinge.
Posted on Dec 09, 2008
How to I clean between the glass door panels
Why? Mine looks to be almost a "sealed" panel, similar to the sealed Thermopane for windows and Doors, only the outside surfaces can be cleaned. If there is a decorator cover, that can be removed via the surround and remove. But I'd leave it alone. Consider it's age, your age, when will you move or not move, when or if you will replace it, or remodel. If it's a critical issue, I'd look for a nice looking used replacement door.
Mar 03, 2015 | Ovens
EUEE63AS 80l HOW TO REMOVE OVEN DOOR
remove cover on the door ( inner) to expose screws.
Jul 26, 2014 | Ovens
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Door glass is lose and seal is leaking..moisture is forming on inside of glass
That is normally caused by the clear plastic adhesive cover either having been removed or missing. It covers the perforated door inner and stops condensation and food particles from getting inside the door cavity where is cannot be cleaned.
Feb 14, 2011 | Goldstar MV-1526 Microwave Oven
Cleaning oven window
remove the screws on the perimeter on the inside side of the door and the door will open up to clean in between the two halves,but make sure to get the seals back into place the right way
Apr 14, 2010 | KitchenAid KEBC107 Electric Single Oven
How do I clean the inside glass on the door - GE Profile JVM1870
I have a Kenmore with similar issues.
Model 665.61639100
Anyway, good luck with this. Hope someone has an answer for you (and me).
Mine has a open slot on the top front of the door. Kinda like a double plate window execpt for the opening in front. Why is this there? I don't know. Weird design. But it leaves for the possibilty of liquid to splash in there leaving it hard to clean (like impossible).
I'm thinking I have to completely remove and disect the door.
Jan 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How to clean inside glass on oven door
If you can, usually it is possible, remove the door from the oven. open door to the first open position..(broiling) about 6" open then (make sure any screws are removed from hinges holding door in place) lift up and out at the angle the door sits.place on counter and start removeing screws. can be a whole bunch of em..
Oct 24, 2009 | Ovens
Can't clean the inside of the glass door--the screen blocks it
Have to replace the door. You probably removed the protective plastic cover inside the unit intended to keep material from passing through the screen into the area where the glass is located. That was my problem. I thought the plastic was shipping material. My Bad! No way to clean the glass from the inside because they "never imagined" someone would remove the plastic cover.
Nov 10, 2008 | GE XL1800 1100 Watts Microwave Oven
Glass window cleaning!
You have to remove the inside skin of door, pull door up and off of hinges and lay on floor to make this easier. Then you remove clips or brackets that hold the glass to door and clean. Very simple, but time consuming, mainly lining skin back up on reassembley.
Jan 27, 2008 | Ovens
Oven window
SAME PROBLEM WITH STAINING BETWEN DOOR GLASS
Dec 07, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
KitchenAid KERC507 Electric Kitchen Range Logo
113 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
