Question about Motorola Mobility KRZR K1m Cellular Phone
Front screen is blank and won't display
If I take the battery out the front display works for about 10 minutes or so and then goes blank again.
  • 61 Answers
I think your flex ( the one w/c connects the lawer and upper part of your phone has a problem). you need to realine ore totally replace the flex. you can ask with celphone cervice center near you. good lack,,,,,,,
Posted on Dec 18, 2008
My HTC Touch display goes blank and phone doesn't ring
Ok,
Good to read the detailed description. You said, the battery is full but did u checked the battery healthiness. Is it really full. Put the battery in another set if you have because the true picture will be in front when u check the battery on load condition. You can check the battery voltage but it might show you the full desired volt but without load. So, the better way has mentioned.
Tell me one thing that was it going off when u swap/filip ist screen. If this is the case, then u need to check the strip that connects the keypad of your phone with the LCD. This can be the issue...
good luck...
Sep 15, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Blank Screen but sound works on samsung HPS-S5053
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Jul 14, 2009 | Samsung HP-S5053 Television
A/c in front did not show read out on the thermostat this am. I thought it had been turned off. I checked the switch, turned it off and then back on and the numbers etc. came up but then it went blank...
depending on the brand of digital tstat usually when the display A/C it usually means that you lost control power to the tstat if the tstat has batteries in it pull the batteries out and display goes blank then there is no control voltage depending on the unit most have a fuse in the inside air handler newer units use a flat automotive 3 or 5 amp fuse same as a car. if you replace fuse and blows again there is a elsctical short
Jun 04, 2009 | Heating & Cooling
Nokia 3230 screen goes blank after a few minutes of turning on.
hello !
replace the LCD theres a posibilty of it being foulty , the IC on the lcd is damaged and please check the lcd socket on the MB .
Thank you
May 28, 2009 | Nokia 3230 Cellular Phone
the problem on it is the crystal IC on the display,, replace it
Apr 04, 2009 | Nokia 3230 Cellular Phone
Blank Laptop Screen
unplug everything from your laptop unplug the power from the laptop close it and turn it over remover the battery open and hold the on button(battery is still removed) for a 10 count, replace the battery
turn on you can plug the power cord if needed the prob. should be fixed
Dec 26, 2008 | Gateway MX6956 Notebook
Sporatic problem with Stereo and Stereo Display
I have had this problem intermittently since I purchased the vehicle in 2004... the dealer could not fix but showed me that there is a relay that you can pull and re-install. It's under the hood and must be done with the ignition and lights off. Pull the relay, wait 10 secs and re-install and pblm goes away. If you are standing in front of the vehicle there is a relay box on your right/vehicle left. The relay is located in the lower left-had corner of this box. Not a permanent fix, and in my experience the problem goes away when the vehicle is parked for an hour or so but if you have a long drive and want to use the radio, this 60-second fix is worth knowing...
Oct 25, 2008 | 2004 Dodge Durango
Monitor displays breifly then goes to blank screen
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Motorola Razr front screen blue, inside screen white/blank
this i did find a guide to opening the moto up .
http://themotoguide.com/razrdisassembly.php
hope this helps you out.
riz.
Nov 12, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Mobility KRZR K1m Cellular Phone Logo
145 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
