Question about Slant Fin GF-240 1.9 Ga Germ-Free Cool Mist Evaporative Humidifier Humidifier
How do I clean the wick filter of the slant fin GF-240
I can't find the instructions
My Slant/Fin GF 350 suddenly will not heat the water and has the "fill/clean" red light on even though it is clean and has a new filter in it. there are no mineral deposits in the well, and no...
the rusted sensors are the cause of your problem - as soon as the sensors do not conduct an electric current through the water (either because there is no water or because they have decayed), the humidifier shuts itself off. You will need to replace the sensors. var viewReq = new Array();function vu(u) {var i=new Image();i.src=u.replace("&","&");viewReq.push(i);} vu("http://googleads.g.doubleclick.net/pagead/adview?ai\x3dB3Oe4m7gKTa-UBNCi6Qbh1uhIjbTQzgH1yJ29FJ2PiKQXABABGAEgADgBUIDH4cQEYMn-vYzYpOARggEXY2EtcHViLTMzODQ5NDYyODUzNTE5NTayAQ13d3cuZml4eWEuY29tugEKMzAweDI1MF9hc8gBCdoBTWh0dHA6Ly93d3cuZml4eWEuY29tL3N1cHBvcnQvdDY2NzU2OTctc2xhbnRfZmluX2dmXzM1MF9zdWRkZW5seV93aWxsX25vdF9oZWF0mAKsG8ACBMgCtZzVEeACAOoCIzYxNTMvZml4LmhvbWVnYXJkZW4vaGVhdGluZ19jb29saW5nqAMB6AO8BugDgQn1AwIAAATgBAE\x26sigh\x3dDErSUArfSlA") body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; }
Nov 03, 2010 | Slant Fin Warm Mist GF-350 Humidifier
I need to know where the filter goes on a slant/fin GF-200 humidifier. I don't have a manuel.
by what i have found for your model it doesn't have a filter persay. it has pads and they go right under the tank.
Aug 18, 2009 | Humidifiers
No instruction manual
FILLING THE WATER TANKS
1. Before filling the water tanks, push the POWER switch to the “OFF” position and
unplug unit. Refer to cleaning instructions.
2. Remove water tanks from base, turn each tank upside down and remove tank cap
by turning counterclockwise. Fill tank with clean cold tap water.
Replace the tank cap by turning clockwise. Tighten firmly.
3. Carefully pick up tank, since it will be heavy when full, and slippery if wet.
4. Place water tanks on base. Make sure tanks are properly placed, otherwise, the
humidifier will not work correctly.
Feb 11, 2009 | Slant Fin Cool Mist GF-220 Humidifier
Crust of sediment in hot water pot
Hi, Go to your grocery store and buy some cream of tartar which you can find in the spice section, it is a white water soluble powder. Dissolve about a teaspoon full in a pot of your coffee water, put in a filter with nothing in it and cycle the water through the coffee maker, if it is really scaled up do this a couple of times, discard the filters which probably will have some little white and yellow chunks in it and this should clean up the inside, you may have to soak the pot in the warm water with a little stronger solution. Good Luck!
Feb 04, 2009 | Slant Fin GF-240 1.9 Ga Germ-Free Cool...
Slant fin gf-210 needed part
slant fin sold the humidifier biz to another company.  info at the slant/fin site http://www.slantfin.com/contact.php
Nov 18, 2008 | Slant Fin GF-210W 2 Gallon Humidifier
Need a replacement tank
http://www.humidifierfilters.com/parts4models.php?brand=slant%20fin&model=gf350
You'll be able to order a replacement tank through this link. They are currently out of stock for your tank but the site says they are getting more in. I would write to them and find out how long.
Good Luck.
Apr 20, 2008 | Slant Fin Warm Mist GF-350 Humidifier
Leaking rubber boot
Mine did the same thing at the end of last winter. I did not discover it to be one of the rubber tubes (boots as you say) until I went to use it this past fall. The manuf. said send it back for a replacement (they do not fix these or offer parts) which I did in Nov. and still have not received the replacement. Nice deal for them.
Feb 05, 2008 | Slant Fin Warm Mist GF-350 Humidifier
Clean/refill light
My Slant Fin humidifier has a floating, ring-shaped magnetic level that isn't replaceable. You can't even tell it's magnetic until you cut off the piece that prevents the white plastic float from rising past a certain point. It turns out that there is a ring-shaped magnet in the float.
I found that the Refill light would go off when I held a strong magnet near the float device.
So, I have suspended the magnet with string from the top of the humidifier outside the humidifier.
Caution: This fix disables the safety feature inherent in the low level shut off. I wonder why the manufacturer uses material that corrodes?
Oct 14, 2007 | Slant Fin Warm Mist GF-350 Humidifier
Lost instruction manual
Slant/Fin has sold the humidifier and PC-55 air purifier business to KAZ USA Inc. If you need replacement parts, repairs, or have any questions regarding the products, please contact them at: KAZ, Consumer Relations Dept. 250 Turnpike rd., Southborough, MA 01772 Phone: 800-477-0457 email: info@kaz.com also worth a look is: http://www.achooallergy.com/slantfin-operating-instructions.asp seems to be best forum for humidifier stuff
Feb 14, 2007 | Slant Fin Cool Mist GF-220 Humidifier
Slant Fin GF-240 1.9 Ga Germ-Free Cool Mist Evaporative Humidifier Humidifier Logo
381 people viewed this question
Top Slant Fin Humidifiers Experts
Jim London
Jim London
Matt Olenzek
Matt Olenzek
Rich Brown
Are you a Slant Fin Humidifier Expert? Answer questions, earn points and help others
