Question about Sony VAIO PCV-W20 PC Desktop
PCV-W20 monitor won't come on
I turn the computer on and the monitor won't come on. The fan comes on but there is nothing on the monitor. The num lock light comes on the keyboard, but nothing else. Any help would be great
  • MEZ1952 Nov 03, 2007
    I had the same problem. I cleand the power supply and the inside of the computer with compressed air. I put things back together and everything worked for a day and then same problem started again. the system comes on, but the screen is balck. Sometimes if I push the ON/OFF button the yellow light comes on and if I push it agian I see the screen for a few seconds and the it goes dark.
    I think it may be related to the system getting hot, but fans are working
Actually its not any of the above solutions. The W20 is Sonys all in one unit answer to apples iMac. I have a PCV-W20 and the computer will boot up show the windows logo for a split second and the backlight goes out, if you hit del and f4 to go into the bios it will get to the bios screen for a fraction of a second and turn off aswell. I pulled the backpanel apart and reset the cmos, nothing changed so I thought it was a bad backlight and replaced it. Actually its the video inverter board that is bad. Its a known issue with these because they run hot, however the part to replace it from sony is $375.... I have been looking on ebay and around for a 3rd party part but havnt been able to find one for the last 6 months.
Posted on Aug 15, 2007
    Scholar:
  • 113 Answers
What is the color of the led on the monitor?
Posted on Feb 22, 2007
    President:
  • 2,961 Answers
This could be the bios looking for the boot.ini file or a faulty driver, try pressing F8 on boot up and when prompted with an options screen, select 'Last Known Good Configuration. and press enter. The pc should restart and boot into windows. If no boot then try, if you can using your monitor on a friends pc to check if the monitor is faulty or the software.
Posted on Feb 20, 2007
    Sergeant:
  • 310 Answers
Hi, if you dont get any picture on the monitor except no signal or blank, could be a couple of things, 1 the monitor try a spare if u have, or another common problem could be graphics card, try removing graphics card and refitting it, :-) John
Posted on Feb 25, 2007
SOURCE:
My Sony Vaio PCV J100 turns on but no nothing comes on the screen/monitor. I have checked the monitor but it works fine on other computers. What could be the problem?
If your monitor works fine on another computer then most possibly its your video card since you said nothing comes on. Usually if its the operating system you should see the computer info before it goes to a blank screen. If you have an add on video card try using the integrated video card or vise versa. You can also use a known good video card from another computer.
Jul 18, 2011 | Sony VAIO PCV-J100 PC Desktop
My pcv-w20 has been sitting over a year, the lcd monitor show's the desktop and operates normal except that theres no light to the screen (had to use a flashlight to see it) just went dark one day! ...
There is a $20 part called the "inverter" that has failed.
Add $50 to $75 for a qualified video/TV technician to disassemble the LCD, replace the part, reassemble, and test it.
Sep 03, 2010 | Sony VAIO PCV-W20 PC Desktop
My Sony Vaio PCV-RX860 won't boot and makes a clicking sound.
It's usual that new desktop PC's have fans sounds and keyboard LED's flashing during booting..There's nothing wrong on that, as long as you can get in to your PC OS.
Jun 06, 2010 | Sony VAIO Digital Studio PCV-RX860 PC...
When i turn on my computer it come on but it don't show any thing it just bring the turn on sound pls what can i do. sony pcv-9913
Interesting. Can you hear the hard drive starting up at all? Has the laptop been used in any way that may stop it from functioning?
Dec 29, 2009 | Sony VAIO PCV-W20 PC Desktop
Noisy fan when downloading larger files
Well this really isn't much of a problem, as the fan turning on shows that it is doing its job. It turns on due to processor having to run faster, naturally raising its temperature, so the fan keeps the processors temperature within operable limits.
Apr 26, 2009 | Sony VAIO PCV-W20 PC Desktop
Sony pcv w20
Turn off computer. Unplug Keyboard. Plug keyboard back in. Start up computer.
Jan 03, 2009 | Sony VAIO PCV-W20 PC Desktop
Dennythedon3003 may have learned spelling by now - after 10 years.
this computer does not have a slot for an aftermarket video card ,Regards and sry
Regards, and thank you for using fixya.
Oct 23, 2008 | Sony VAIO PCV-W20 PC Desktop
PCV-W20 Partition sizes
Have yout tried to recover without any partition defined? Try to execute with your hard drive clean.
Dec 17, 2007 | Sony VAIO PCV-W20 PC Desktop
Display shows SONY sign and goes black
Are the fans still runnng when the screen blank out? If not so the power supply is dying most likely. Did you add more devices, and wattage might be enough, when did it start happening? Can you trace back when it started and any changes you have made. It might be a problem in the monitor part of it. Marcel
Jun 26, 2007 | Sony VAIO PCV-W20 PC Desktop
Sony VAIO PCV-W20 PC Desktop Logo
748 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
