Question about Kitchen Ranges
When we lite up the wood burning stove the smell and the fumes are really strong the fires has been lit about 6 times any help?
    Habit-Forming:
  • 171 Answers
The chimney pipe most be the same sides all the way out , it can not begin big and then small as it goes out. that's the problem with, your wood burning stove. it can be small and then big but not the other way around.
Posted on Dec 10, 2008
The fireplace no longer produces a flame, i do not have the manual to trouble shoot and fix it
Gas Fireplace Manual - Gas Fireplace Instructions: Mendota ...
mendotahearth.com/gas-fireplace-stove-owners-manual.php
Mendota gas fireplace manuals and gas fireplace instructions for Mendota ...Mendota Gas Fireplace Insert FullView Model FV33i PF2 - Installation Manual
[PDF]FIREPLACE HEATER - Crane
crane-usa.com/assets/.../Fireplace_Heater_2013.pdf
by C Care - ‎Cited by 2 - ‎Related articles
your fireplace heater, please contact Crane. Customer ... This instruction manualapplies to the following models of the Fireplace Heaters product line: Color.
Nov 29, 2015 | Heating & Cooling
Can't keep the wood burning in stove. How does the buck stove take in air?
To burn properly, it needs proper combustion air and proper draft. Draft is effected by the size and height of the flue the appliance is connected to and by how much combustion air is available. The appliance flue connection should not be reduced to fit a smaller chimney size. That is, an 8" flue should not have an 8 x 6 reducer to vent it into a 6" chimney.
The wood you are burning could contribute to a poorly burning fire. To burn properly, the wood needs to have been "seasoned" for a minimum of 1 year or close to it. Two years is even better. "Green"
or freshly cut wood contains an unbelieveable amount of moisture in it and a tremendous amount of the heat is wasted just "preheating" the wood to the temperature that causes it to release gasses for ignition.
I don't know the style or model of your Buck, but all wood burning appliances should have combustion air dampers of either a sliding design, rotating round design or hinged design with handle at the bottom front of the firebox. I'm sure there are some fancy new designs that have air piped in from outside the structure.
Every wood fired stove, fireplace or furnace has its own idiosyncrasies and its up to the user to determine what's required for making it operate as designed.
Dec 06, 2014 | Buck Stove Home
How is air supply regulated in wood burning stoves?
To regulate air flow, there are damper devices built into the stove, flue and stove pipes. Keeping the air flowing correctly through a wood-burning stove is essential for safe and efficient operation of the stove. Fresh air needs to enter the wood compartment to provide oxygen fuel for the fire; as the fire burns, the smoke must be allowed to rise through the stove pipes, and exit through the chimney.
May 07, 2013 | Home
There's a strong smell (fumes) coming from the printer. I felt high the first day and I had a funny feeling in my throat on one side. Some say it smells like a hot blow dryer or burning smell. I need to...
The odor is coming from what is called the 'fuser' which heats and bonds the toner to the paper stock. There may be some light residue from the manufacture of the fuser roller which is heated to a high temperature to enable the fusing to take place. It may linger for several days but is unlikely to be hazardous in nature otherwise Samsung wouldn't allow it to remain on the assembly. Laser printers often smell 'hot' due to this process but I have not heard of any hazard caused by fumes. One caveat though; the fuser roller is coated with Teflon or an equivalent coating. I nearly died from Teflon which was in a gaseous state many years ago but it was exposed to temperatures of greater than 450F which is dangerous since the effect is that of a nerve gas called phosgene. Since that is a temperature one can easily reach on a stove-top, we have NO coated cookware in our home.
If you notice that the plastic near the warmest place on your machine feels uncommonly hot, it might be best to shut it down since it may be possible for the thermostatic control to fail so the fuser is heated to an abnormally high temperature. I'm fairly sure there is a thermal fuse to prevent catastrophic failure but wouldn't count on it.
Mar 29, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Wood burning heater when putting wood into stove lots of smoke comes into the house when door is opened.
It ain't drafting right or you have the damper closed. Look for obstructions in the smoke stack.
Wood burning tips
  • Burn only wood. No garbage, plastics, rubber, paint or oil, briquettes, paper, etc. Burning these items releases harmful chemicals into the air.
  • Burn Wise Program from EPA: Emphasizes the importance of burning the right wood.
  • Build small, hot fires instead of large, smoldering ones.
  • Don't "bed the fire down" for the night. Holding a fire overnight is a fire hazard and can create serious indoor and outdoor air pollution problems.
  • Open your damper if the smoke is dark. Dark smoke indicates more pollution is being produced and fuel is being wasted.
  • Keep your stove clean and well-maintained. Follow manufacturer guidelines; replace catalytic stove filters every 1-4 years. Have your chimney checked and cleaned at least once a year.
Use seasoned wood The best fuel for woodstoves is dry, "seasoned" wood. Seasoned wood has a moisture content of about 20% or less. It tends to be dark in color, cracked on the ends, light in weight and has bark that is easily broken or peeled. Here are some tips for preparing seasoned wood:
  • Split the wood to help it dry. Wood will dry out more quickly and burn best if the wood is cut to about 3 1/2 inches to 6 inches in diameter.
  • Cover the split firewood to protect it from the weather and stack it loosely in alternating layers, at least 6 inches off the ground.
  • Time must be given to allow the wood to reach 20% or less moisture required for seasoned wood. This process takes approximately 6-12 months. Think ahead and buy next winter's wood well in advance.
It is recommended an annual chimney cleaning to remove creosote build up and to identify potential problems. Things to consider:
  • The Chimney cap may be plugged by debris.
  • Catalytic combustor and baffles are exposed to very high heat and deteriorate as used. Replace every 1-4 years depending on use.
  • Stovepipe angles and bolts are subject to corrosion.
  • Gaskets on airtight stove doors need replacement every few years. Gaskets and seals are used by the appliance designer to control the location and flow of air into the appliance.
  • Check seams on stoves sealed with furnace cement. Seams may leak and cause you to loose valuable heat and reduce the efficiency of the unit.
  • Replace broken or missing firebricks.
  • Keep the floor of your stove clean of debris and ash.
-from the web
Nov 02, 2010 | Heating & Cooling
Exhuast smell(odor)
J,
If your Laser 56 is giving off fumes it is probably coming from the igniter gasket and the igniter guide gasket. The igniter gasket has broken and needs to be replaced with the new style. The new style cost about $12. The guide gasket is the fiber gasket around the hole the igniter goes in. It has seperated and all you have to do is smash it back together. If you have high temp silicone or furnace cement, you can use either to seal the crack. Any toyotomi dealer can get you the new igniter gasket # 17185580.
Good luck,
Tom Hawkins
hawkins111@gci.net
Feb 28, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Bad odor from vent free gas logs.
it could be leaking when the fire place is on you said you checked for leaks was this to the burner as well ? it sounds like unbrunt gas check the burner , hope this helps , are you feeling sick or headaches as this would b e fumes ?
Jan 14, 2009 | Heating & Cooling
Kitchen Ranges Logo
122 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
